Home Forums Chat Forum Rate my Brickie….
Viewing 40 posts - 561 through 600 (of 749 total)
  • Rate my Brickie….
  • Jamie
    After the nuclear winter has passed, the only building standing will be Fortress Footlaps.
    NORAD will be flattened, but Fortress Footflaps will still be standing.
    p.s NORAD is built under a friggin’ mountain.
    footflaps
    Cheers Matt, looking for long fixings was next on my to-do list….
    footflaps
    manufacturers details apparently,had it pointed out to me by building control surveyor
    Nothing in the 96 page product guide building control gave me when I asked about it. I did all my U value calculations using Celotex’s online calculators and it was quite happy with 100mm block.
    The only possible relevant reference, in the 96 page guide, is: “Please note that where existing walls are subject to the ingress of excessive moisture, it is recommended that Celotex PL4000 should be installed using mechanical fixings rather than a direct bonding technique.”
    Jamie
    *glitchy bump*
    trailmoggy
    Jeez that celotex must of cost more than my garage
    slimjim78
    Pink? I don’t geddit? It’s twistin my melon man
    althepal
    Footflaps, how much has it all cost?
    “something insane like..”.
    JoeG
    Bike shed (over)built by a Footflaps ancestor a long time ago:
    kingkongsfinger
    Must be into at least week 13 of this build (mega-structure)
    mikewsmith
    having not really looked since page 2… did he sack the first brickie? This thread needs a “Previously on Rate my Brickie” at the top of each page
    slimjim78
    Don’t listen to them Footflaps, I love your bunker.
    Seriously, great thread – over engineering porn.
    footflaps
    Yes. The replacement was most excellent.
    footflaps
    You know you talk so hip man
    dantsw13
    I’m having a large episode of Man-Jealousy towards your workshop flaps!! It makes my new 18′ cedar workshop look very insignificant!!
    On the plus side, I ordered it after you started, and have been in for nearly 2 months 🙂
    footflaps
    OK, Thanks to matt_outandabout , I’ve been looking at fixings and have found a whole range which mean I can fix 150mm Celotex + 12.5mm plasterboard direct to concrete with no stud framework:
    200 of something similar to these turn up tomorrow (215mm long, 10mm pilot hole in concrete and hammer in).
    [/url]
    Untitled[/url] by brf[/url], on Flickr
    markrh
    Footflaps, you are having a ‘Grand opening’ when its done? 🙂
    footflaps
    These grand projects are never really finished, they just slow down exponentially as the ‘designer’ gets worn down by the whole thing…
    nealglover
    Flaps, those fixings are great. I have used those for 150mm insulation loads of times and they are really fast and easy.
    Very strong too. Get a slightly smaller pilot bit just in case though, depending on the substrate a smaller hole than specced sometimes works better.
    And don’t forget to tape over the heads 😉
    matt_outandabout
    For airtightness? We did not bother in woodfibre…
    They are fab things and much under-known about. None of this daft dot n dab or studding out.
    trusslebabes
    Can you put some pics up of those fixing things in action can’t get my head around the collar bit unless it comes off?
    wrightyson
    Go steady with the drill, set a depth guide up or youll be through the other side!
    footflaps
    I’ll try them out in the spare blocks I have first to suss them out. Will post lots of photos. I’ll tape over the heads and then skim over the lot (but probably not this side of xmas for the skiming).
    footflaps
    If you mean the plastic circle thing – that stays in the foam, slightly indented, to spread the load. Anything narrower will just pull through as the foam is so soft.
    NB Had the PB lined Celotex boards arrive today and I can’t carry them on my own as their weight to strength ratio was too high so my hand pulled through the board when I upped them on one edge to get through gates, leaving a massive hand sized dent in the side of them. Have to be carried by two people to spread the load enough to not deform them. Mrs FF was very helpful and shifted 28 of them with me into the WS. The first two I did on my own and are hand print deformed.
    [/url]
    Plaster Board backed Celotex (PB4050) arriving – two palletes worth![/url] by brf[/url], on Flickr
    footflaps
    I think my DeWalt SDS is dying, as it really struggles with the concrete blocks, so over drilling is not a concern at the moment. It really didn’t like fitting the fixings for the door – 150mm x M10 was really slowing it down.
    matt_outandabout
    As said above, drill with depth stop/guage, hold up insulation board, drill holes (usually 5 per board, then screw in fixing and pop wee insulated end cap over screw head to prevent cold spots in plaster or render.
    footflaps
    OK, fixings have arrived:
    You drill a 10mm hole 50mm into the concrete, push outer (white) nylon shank into the hole (through 165mm of Celotex) and then hammer the orange rod in to splay the end of the shank and fix it in the concrete.
    [/url]
    Celotex fixing bolts[/url] by brf[/url], on Flickr
    Will see how many I can get done tonight!
    Tom-B
    To take this thread back to the OP and talk of brickies, I encountered a guy towards the less productive end of the scale today. I teach guitar in a variety of school, the school that I teach at today is having the existing arts block extended. Today there we’re architects/engineers/builder types in assessing the current structure. At some point the builder removed 4 breeze blocks from a wall to check what insulation was in place (at least I think that was why they were removed). At 1.30 I had to teach in the room where the blocks had removed, and a few minutes into my first lesson, the builder (who was a lovely chap!) popped in to replace the 4 blocks that he had removed. I left school at 3 to go and teach elsewhere and he’d only managed to put two in! 🙂
    Scienceofficer
    You’re insulating inside and out with celotex?
    Jesus man! What U value are you aiming to hit?!
    matt_outandabout
    The OP is only insulating inside – that pic is one from net to show how the fixings work.
    wrightyson
    Seriously tho flaps set the drill guide accurately to say 55 mm and clean each hole out thoroughly. You head to the latter stages of the 60mms and you will undoubtedly be requiring some render and more pink paint!!
    Scienceofficer
    Ah, thanks. Missed that bit.
    bruneep
    Got a roof on yet?
    footflaps
    Bruneep, exterior was completed a few weeks back, insulation and fitting doors are the current tasks.
    [/url]
    Workshop front[/url] by brf[/url], on Flickr
    Did all the complete sheets (13) tonight, the rest all involve cuts, which I’ll leave for the WE.
    [/url]
    12 Dec 2012 20:17[/url] by brf[/url], on Flickr
    qwerty
    Have you in built an electronic safe into the floor for contraband items? That’d be cooooool.
    Coyote
    The whole building is a safe!
    footflaps
    I don’t fancy cutting into the floor, it’s rather well built!
    [/url]
    Pumping concrete[/url] by brf[/url], on Flickr
    footflaps
    F@@@ing new page glitch!
    Jamie
    True. When his insurance company see it, they will pay HIM money to store his bikes in there.
    wwaswas
    glitchy bump
    Jamie
    *Glitchy doo-daa*
    Edit: I think that got it guys. Good job!
The topic ‘Rate my Brickie….’ is closed to new replies.
