Home Forums Bike Forum DIy 700 lumen batteries inside light
Viewing 40 posts - 321 through 360 (of 1,255 total)
  • DIy 700 lumen batteries inside light
  • trout
    having looked at the ape parts that trouble sent,
    Eh ????
    Heatsinking a sort of rule of thumb has been 1 square inch of surface area per watt of power going in
    as long as there is a good thermal contact from the led angle bit and the case either drilled and tapped or bolts and nuts .
    and an airflow is present a case of about 50 mm is fine .
    Though on hi in still air it will heat up .
    Cree rates the leds to 150 degrees C and as long as a good thermal path is present the leds will be about 30 degrees hotter than the case near the leds .
    too hot to touch is about 70/80 degrees meaning the leds are 120 .
    thing with leds is the cooler they are the more lumens come out of the front .
    Make the case too small and it becomes more difficult to build too .
    lipseal
    £12 for that bracket on Wiggle 😯 God help us all!
    Luminous
    £12 for that bracket on Wiggle God help us all!
    Yeah, I know, I was just brain storming on a solution for the mount.
    There seems to be quite a few making this light now, and I’d hate to see you all thwarted for not getting a feasible mount.
    Just trying to help.
    trout
    Thanks Lumi you sparked an idea that is very Eco warrier .
    I use the botton half of the electron mount for my Liberators
    and chuck away the top half now look at the pics .
    I ran into the garage and in 2 minutes had a Lupine style mount sorted .
    The postage is going to cost me a fortune but will chuck in a half mount
    as well for free .
    You will have to find your own Oring though
    smudge
    I can see a ‘what ‘O’ ring’ thread coming along very soon 😆
    lipseal
    Do I use a Viton,Nitrile,PTFE,Silicone, EPDM or Neoprene? Just can’t make my mind up? Standard black or colour match my frame? :mrgreen:
    smudge
    lol @ lipseal
    LoveTubs
    That bracket looks heaps better than the Lumicycle job sent with my hid lamp (sure they must have upgraded that by now?)
    BlackCatTech
    I’m posting the second batch of driver kits at the moment and they are now all taken until I can locate an alternative source of switches.
    A few people haven’t included their address and unfortunately Paypal doesn’t let me access this for gift payments so I’ve emailed them – please check your inbox!
    I can still supply all the other parts of the kit except the switch so anyone who hasn’t got their order in yet can still get most of their stuff. Unfortunately, the switches are now on backorder until December. The only immediate alternative I can spot would be to use the double-pole version of the switch. If I can’t find anything else and there is call for more kits then I’ll order some of those in.
    trout
    hows about in Mcgyver form a bit of old innertube
    as the light head weighs 99 grams inc innertube
    and grips like a good un
    lipseal
    Have sent address to trout and bct
    lipseal
    Forgot to mention butyl 🙄 😆 Notice that there no boot over the switch Mr trout?
    trout
    Yes I know didnt have one to hand but the back of the switch is silly coned well so no water can get in the case .
    couldnt make a boot from the innertube 😥
    smudge
    These any good from maplin BCT?
    BlackCatTech
    Smudge, The drawing on the Maplin site is a bit useless but I suspect they aren’t suitable. The boots I have are M6 thread, most switches seem to be 1/4 UNF (or UNC? can’t remember for sure, but certainly 1/4″).
    nockmeister
    Made a slight boob ordering the wrong hammond case from Maplins, even after Trouties case post..Ordered one with solid end caps, which is fine for the switch end but bloody stupid for the LED end..doh!
    Anyone want to swap one??
    Luminous
    Trout.
    Hey !, what a team. That mount idea looks excellent. Even better that you’re using spare parts.
    I reckon thats got to be the way to go.
    Good work.
    EDIT: I’d go with the piece of inner tube for an O’ring.
    Rubber O’rings are prohibatively expensive when bought in small numbers. ime.
    sv
    I planned to bolt a piece of Alu tube to the bottom of the box and use a Deal Extreme Velcro torch holder.
    thesurfbus
    The problem with the DX Velcro torch holders is they waggle around when the going gets rough, and you get a strange strobe effect on the trail (work fine on the helmet).
    I have a Bastid light with the rubber O-ring style handlebar mount and it doesn’t hold the light secure either, I might try a bit of Innertube.
    thesurfbus
    I guess if you used a longer piece of alloy tube and two (in-line) velcro mounts then that should hold it pretty tight.
    MarkyG82
    doh! sorry troutie. predictive text messing about.
    VanHalen
    nockmeister – Member
    i think they all come with solid ends hence why trout uses lexan cut to shape in the destructions on page 1 or 2. I think he is sending out some lexan with hte kits but i cant remember.
    lipseal
    No there are two types one with black plastic ends the ones we should be using have metal ends with the plastic already cut out.
    VanHalen
    cunning. no way of differentiating this on the website though!
    lipseal
    That’s true VH you just have to inquire, Ive got the 80X54x23 part number 1455C801 HTH
    nockmeister
    Guys there is a way to tell off the Maplin numbers, the numbers below are for the same sized box, with different finishes/plates
    1455C801 = two piece blanking plate
    1455C802 = one piece blanking plate
    1455C802BK = Black, one piece blanking plate
    Appreciate if someone would swap one end out with me, there is no difference to the finish of the light!! You could argue that the solid blanking plate is less likely to leak!!
    lipseal
    Just cut a hole in the blank
    jazid
    I’ve just seen that with Top Cashback you can get 4-5% cashback from RapidOnline.
    I have been using TCB for a couple of years and have a time limited joining offer on my account where new people who sign up will get £2.50 joining bonus after they have accumulated £5 of cashback.
    Its free to join and you don’t pay to use the service (unlike Quidco who take the first £5 of any cashback).
    Chainreactioncycles & Wiggle also offer 4% cashback.
    FWIW this signup bonus expires on 12th October, but its still worth joining anyway as every little helps.
    http://www.topcashback.co.uk/ref/Jazid
    BlackCatTech
    Well Spotted, I’ll have to be taking advantage of that as I generally spend a few hundred quid with Rapid monthly.
    I only hope I have more success with Rapid on TCB than with my last two or three transactions as they have all failed to pay out…
    runswithscissors
    Just recieved my little box of goodies from BCTech (thx) now to try and avoid stuffing up the assembly phase!
    lipseal
    Got my box also, let the games begin 8)
    sv
    Can I be the first to wire the driver the wrong way?
    jazid
    TCB have been fantastic – I have only ever had one transaction not track, and that was because I had AdBlock Plus for Firefox turned on which stopped the tracking cookie being saved to my PC (my fault).
    lipseal
    Dumb ass question but does the driver need a heat sink?
    PS BCT just double check the resistors as I’ve got a 50K one? brown red black(might be blue) blue yellow
    trout
    Here is a virtual delivery cos I have no leds yet Parcel force has them somewhere .
    this is what will be in the package from the Trout
    of course there will be 2 leds too
    yes the driver will benefit from being cooled and that is what the small bit of Ali is for .
    steelfan
    Just received my little package from BCT. Cheers BCT your a star!
    Cant wait for the stuff from troutie now!
    Curly68
    I also received my parcel from BCT today. Nice little package I have now waiting to go together.
    Thanks all your help BCT
    fozzyuk
    It’s late, it’s Friday
    Which one 😉
    Xylene
    Has anybody made a wiring schematic for this yet?
    thesurfbus
    There was a wiring schematic on one of the previous posts, I think it was a link to some photos on Flikr.
The topic ‘DIy 700 lumen batteries inside light’ is closed to new replies.
