Home › Forums › Bike Forum › DIy 700 lumen batteries inside light
- This topic has 1,254 replies, 94 voices, and was last updated 13 years ago by stevemorg2.
troutFree Member
Still got plenty of leds and reflectors
had a few mails paying but cant put a stw name to them so if you want some then mail me
thesurfbusFree Memberstayhigh – What type of drill bit did you use to drill the two holes in the black plastic cover for the LEDs, I want to go down this route but need to buy a suitable drill bit?
thesurfbus
bobblehatFree MemberFlicker … just for info, the switch will operate off/high/low (or low/high/off depending on which way you wire it), but can’t be set up for off/low/high with the normal switch. The centre position of the switch isn’t connected to anything and that gives “high” with this driver.
LuminousFree MemberStayHigh.
I see from your pics on page 20, that you appear to be using the half clamp and rubber ring for a handle bar mounting solution.
How is that wokring out ?.
bigjimFull MemberFinally picked up my trout pack from the office – thanks so much trout.
Such tiny LEDs. I wonder if I could upgrade my Joystick maxx to use one of these instead of the P4….
stayhighFull MemberHere are some beam shots from my ride to work last night. The quality isnt great as its a camera phone but you get the idea.
Low beam
Full beam
thesurfbus: I used a 20mm flat wood drill bit to do the holes in the plastic bezel. Its kinda fan shaped with a point sticking out. I had considered getting a cone shaped one but the flat bit was to hand at the time.
IIRC on CK’s light the holes are chamfered which I think looks neater b ut not sure what would give you that finish. I only have access to a cordless power drill but I imagine a pillar drill would also give a better finish.
Luminous: The bar mount seems to work ok. It was used like that for a short ride and seems stable enough however the light is currently helmet mounted (cateye helmet mount)which is very good.
XyleneFree MemberAnybody tried mobile phone batteries for something like this.
Four batteries strung together would be small still, even six together would be small.
I presume a charger would charge them up.bigjimFull Membersurfbus, I’m going to make holes in the plastic front too, was thinking of drilling them out roughly then filing/sanding down to a smoother finish. I’m making this to see where I’m going, not to look at, so not too fussed.
going to make a start on this this weekend! not got the driver kit yet but will cut the case down, drill holes etc.
mau00149Free MemberAll bits arrived safely, just need to sort the box, batteries, soldering, etc. Thank you very much troutie and BCT for all your efforts helping us all.
flickerFree MemberBobblehat……Cheers for the heads up. I’m considering wiring it up to give Hi/med/low and off using two switches. I’m looking to use the setup for commuting, as well as leaping about like a damn fool in Delamere forest 😀 , so the three settings could come in handy.
jazidFree MemberI’m planning on implementing this using two switches as when racing its the only option and you don’t want to turn it off accidentally!
bobblehatFree MemberSorry flicker … but even with 2 switches, I can’t think of a way of doing high/med/low using the 3 way on/off/on switch! You can do med/high/low (or low/high/med) easy enough and have a separate switch on the battery lead somewhere to do the “off”.
If you look at the schematic I posted here, well one half of it anyway, you can see the med/full/low set up (I called it low/full/dim – same thing!)
With the switch we are using (Maplin or Rapid or Farnell etc) the centre position can not be connected to anything, there is no connector that connects to the “common” when the actuator is in the centered position.
If you have figured a way around this then please post as it would make a lot of people happy on this thread!
You could easily do it with a 3 way rotary switch …… or with a 4 way rotary switch of suitable power rating, you can do the on/off as well as high/med/low (or low/med/high!)
puntopeteFree MemberTrout + BCT, emails sent.
Might have to call into maplins tomorrow for a hammond case, although i’m tempted to dig though the scrap box at work for some billet to mill into a case 😀
GarySFree MemberFinally gave my light a test on thursday night and it worked a treat. It ran for over an hour on 8x old 2000mah batteries i had kicking around, right up until i ran out of talent on some steps 🙂
I fell forward and managed to bend the 2.1mm power connector and broke it, maybe flying leads would be better.
Oh, and my 4 way 18650 holder has arrived so cheers for that.
XyleneFree MemberI bought the wrong case, it’s slightly too small for the heatsink, so I either chop it or return it, but feeling lazy….so most likely will chop 2mm off the heat sink and do my best with that.
filtertipsFull MemberTrout and BCT, just wanted to thank you guys for the effort you’ve put in. I finally managed to get out and use mine Friday night. Compared to the Niteflux Photon 4 I’ve been using it’s a whole world of difference!
Cheers 🙂
bobblehatFree MemberWhat case did you buy, Quirrel?
While waiting for silicone to dry on the dip/main pair of lights, I started on the Dynamo light …. Boy! It’s so much quicker doing it again once you’ve done one before!
+1 filtertips … big thanks to Troutie and BCT(Stephen). 😀
Anyone got a plastic end cap either open or closed one off a Hammond case going spare? Cash waiting 😉
Kev79Free MemberHi,
Been keeping an eye on this thread for a while now as quite fancy giving this a go.
Trout could I please get a LED kit and BCT could I please get one of your kits and a 3 way holder (4 way if that’s all that is left).
I’ll send emails to back this up, but if you could let me know how much I owe both of you and I’ll get the payments sent to your paypal accounts.
Many Thanks
KevXyleneFree MemberMy case has two plastic ends, quite small and the two reflectors fit in ok, might just use it.
bobblehatFree MemberWill the two LED stars fit in it … side by side …. they are just a little bigger than the reflectors?
nockmeisterFree Memberbobblehat – Member
Anyone got a plastic end cap either open or closed one off a Hammond case going spare? Cash waitingYou can get the end bezels from Farnells, the link below is for solid black bezels
http://uk.farnell.com/hammond/1455cplbk/enclosure-1455-bezels-black/dp/1415009Guys my experience with having two switches on the end of the can for power/mode is that if you use the same type of switch, it can be confusing!!
bobblehatFree MemberThanks nm …. looks like they don’t keep stock, but can get them in with a 14 day lead time …… best offer I’ve had yet! I’ll see if I know anyone that orders from Farnell …. I think the postage/minimum order would kill the deal for 2/4 end caps from a punter like me!
No switches on my cans (cases), just one pigtail coming out of each light. Switches go the bars next to my thumbs. The on/off for battery will go near the battery probably ….. if I use one. The thumb switches can be configured for off/high/mid (without battery switch) or dim/high/mid (with battery switch). I might go for off/high/mid initially ….. because ……
….. I’m working on an option to give off/mid/high … from one toggle switch! Or … if you don’t mind a separate power switch, you could go dim/mid/high. More on this when I’ve confirm it’s feasible, waiting for a guy to get back to me.
troutFree MemberBit puzzled here Quirrel the heatsinks I sent out were a little over sized as just rough cut and would need finetuning to fit in the hammond box .
😆 This thread just keeps going 😆
VanHalenFull Memberyes just trim the ali angle. i also had to file my leds a tiny bit to fit.
bigjimFull MemberQuirrel you have the right box, you just need to file the heatsink down a bit to take account of the bits inside the box the screws go into. I’ve also had to file the stars down. Didn’t quite get the holes mm perfect as I was rushing with a borrowed drill. Getting there though! Just waiting for the driver kit and then the batteries from dx and we are away.
BlackCatTechFree MemberAssuming all requests result in payment I’m now out of 4-way holders so only have 2-way and single holders left. Only got 2 of the single holders, still plenty of the two-way ones though.
For those who don’t want to scroll a few pages back, the single holders are £2.25, twin are £1.75. Drivers are £5.20, the full kit including switch and power leads is £8.
Postage is £1 for drivers or the kit alone, £1.50 for holders and £2 for holders and the kit.
For those wondering about alternatives to the 2.5mm power plug, how about something like:
http://www.rapidonline.com/Cables-Connectors/Connectors-Audio-Video/DIN/Plastic-locking-DIN-connectors/74883Only problem is that they only have the 4-way readily available. I’d suspect these aren’t water proof but should stand a few splashes.
BlackCatTechFree MemberSpeshpaul – it’s not the drivers that are the problem, I have plenty of those, it’s getting heatsinks made that I’m struggling at! It is looking like I can’t get them done at work so I need to find another way to get them machined.
SpeshpaulFull MemberOk BCT, but might want to comment on the Lumi thread.
Whats the brief for the heat sink, as an alternative is it something that could be turned up easily?adamdv8Free MemberMine was a very tight fit, I had to file the stars, and the bolt heads connecting them to the heatsink – and herein lay my problem. once fitted and tightened up i had to take a tiny bit off the bolt head, and also trimed the insulating washer and i think I must have nicked the edge of the washer and created the smallest bridge across there, but it was enough!
Everything else worked fine, I had properly fitted the led end, but loosllely fitted the driver components, and they all tested fine. Only when I screwed it all together – it didnt work properly (lights dim and switch not doing anything). Turns out, as Blackcat mentioned, that I was shorting out as soon as I screwed on the backplate, it created a circuit between the power socket outer and the case which was now connected to the LEDs. I didnt have a mulimeter at the time of assembly, just trusted to close inspection of everything, so inevitably failed. Definately worth borrowing one to do this build! Anyway, Im going to re-build this week, so hopefully it will finally get to see the dark of a night ride by the weekend. Thanks to Blackcat for all the help on this one!
And how about a roll-call of all those finished, how many are out there now? Look forward to joining you.
lipsealFree MemberSee the rains finally arrived and it’s time to check how sealed my light is now. I was going to do the jug of water test but bottled it. I will try and get out this week in the rain but it will depend on my toe getting a wee bit better.
BlackCatTechFree MemberJust found a problem where not all Paypal notifications are making it to my email account – they aren’t even making it to my spam folder so no idea what is going on. I was relying on the emails for addresses etc. I’ve tried to check back through my Paypal history to make sure I’ve not missed anyone but as this contains all my eBay orders as well it is possible I have overlooked someone.
If you’ve not received your stuff (bearing in mind the last time I posted anything before tonight was Friday) then please let me know and I’ll look in to it.
norcbotFree Membertrout do you have any extra reflectors that i can buy as i have damaged one of mine (melted it a little with a soldering iron) . I will also have another kit off you if you have one. As i would like another go and try to not make it look like a five year old had made it.
bigjimFull MemberBlackcat – not received mine but if you posted it on friday I wouldn’t expect it before today.
bigjimFull MemberMy top tip to anyone yet to commence building is to take time to accurately drill the holes for the stars in the alu L piece. Mine were about a mm out but thats enough to cause a few headaches!
bigjimFull MemberI drilled one of the outer holes too far inboard by a mm or so, so had to file the stars a bit where they meet, and do a bit of cunning redrilling of the dodgy hole with the star in place which was a bit scary. I would have flipped the L piece over and started again, but I’d already done a worse job on that side 😆
Just doing it in a rush without thinking it through properly as i had borrowed a drill for the weekend, I should have used a centrepunch to help guide the drill bit but I don’t have one. If I was to do it again I’d get it right though. Its OK, just slightly asymetrical.
bobblehatFree MemberYeah! I see!
I’m using 20mm ali channel that is a very tight fit in the case and the LEDs needed trimming top and bottom slightly to stop them catching on the edge of the case when I slid the channel in. Also, to stop the screw holes being too close to the edge of the ali, I trimmed the points off the stars where the two touch over the centre hole. No problem centering the reflectors and there is still enough spacing between them after trimming the stars.
I wonder if it would be a good idea to spin the star around 30 deg and mount them flat to flat in the middle instead of point to point? It would mean drilling 4 holes instead of 3, but would keep the holes well away from the edges? Still have to trim the top and bottom a tad (the little points near the screw indentations that would stick over the edges) in this 20 mm height case.
bigjimFull MemberThey aren’t load bearing holes so I was comfortable with the couple of mm of alu left outside the screw hole, its enough to allow the screw to hold the star in place. If I decide to make another I’d probably either be more careful or think of something more cunning like you suggest.
I also had a brain meltdown and marked & drilled the holes in the case in the wrong place first time round, so I’ll need to araldite them closed, in the mean time I shall refer to them as case ventilation aperatures , or CVAs, and make them a feature of the light and charge more accordingly 😆
The topic ‘DIy 700 lumen batteries inside light’ is closed to new replies.
