Home › Forums › Chat Forum › 9/11 documentary
- This topic has 1,455 replies, 118 voices, and was last updated 6 years ago by jivehoneyjive.
9/11 documentary
WhathaveisaidnowFree Member
But why should we take the official line as gospel?
What if the official line was controlled demo? Could you prove otherwise?
I like this….
Look how it came down just like a demolition, case closed.
jonnyboiFull MemberOr you can set a few floors on fire and you’ll get the same result.
Add impact damage from an enormous collapsing building, failure of sprinkler systems, withdrawal of the fire department and let the fire burn unchecked for seven hours and yes, that’s what happens in the case of WTC7.
Thermal expansion is a bitch eh?
nedrapierFull Memberapparently so. enormous collapsing building did not have a significant effect though. so office furniture equipment, fixtures and fittings burning for as long as they take to burn. Do you know how long the individual fires burned for?
jivehoneyjiveFree MemberThing is though, surely if fire does cause damage to the steel, at best it will only cause localised buckling of the steelwork, which would mean only a small portion of the structure would be likely to collapse…
Even with the additional damage sustained from debris and seismic shock, such complete collapse is surprising, if nothing else.
However, let’s not forget:
The thing is it really doesnt matter if it was a controlled explosion or if it was just the planes.
The only question is: Was anybody in on it?
jivehoneyjiveFree MemberFor some reason, that reminds me of AIG (American International Group)’s role in the 2008 global financial collapse, but that’s not likely to be relevant here, is it…
outofbreathFree MemberWhat if the official line was controlled demo? Could you prove otherwise?
If demolition was the official line I think people *might* be asking difficult questions about the 4 missing planes with passengers on board, 2 of which crashed into the towers and started massive fires before they collapsed… Don’t you?
TurnerGuyFree MemberPlease stop disrespecting and tarnishing those 3000 ordinary people who died that day, in an effort to get attention for yourself!
go f*** yourself.
As I said, two weeks to collect and examine the site does not seem like it will lend itself to a very thorough examination and reconstruction.
Steel framed buildings like that are not suppossed to collapse as a result of office fires – a lot of qualified people were surprised by it – I would have thought that it would warrant more examinsation in that case to fully understand exactly what happened.
jonnyboiFull MemberDo you know how long the individual fires burned for?
Nope, but from the available evidence it seems like they were burning when the building was evacuated and continued to do so until the building collapsed.
If there’s a sensible alternative hypothesis that explains the collapse of WTC7, I’m genuinely interested.
jonnyboiFull MemberAs I said, two weeks to collect and examine the site does not seem like it will lend itself to a very thorough examination and reconstruction.
I genuinely think that at the time they didn’t consider that it had been necessary. The world had witnessed what happened. It’s easy for us to judge in hindsight
cheekyboyFree Member@Amedias, @Maxtorque, assuming you have looked into the construction of WTC 1&2 are you happy that both airplanes(aluminium framed and skinned) hit both towers with sufficient force to not only penetrate the steel outer skin of the building but to also penetrate through the building to sufficiently damage the inner core of the building to such an extent that it would cause a complete collapse, a collapse so similar between both building that its hard to differentiate between each collapse, bearing in mind 1 and 2 were actually struck in different positions.
Regarding the core of these buildings there is plenty of info out there referencing the core construction, are you confident that the aircraft that hit the towers could damage the cores enough to ensure the collapse ?Heres a nice vid from the 70`s showing construction.
Fuel fire ! the south tower which was probably the most spectacular of the hits and shows a massive fireball, what proportion of the fuel onboard would have not have ignited at that point and was therefore left to fuel the raging inferno that wrecked the structural integrity of that building?
slowoldmanFull MemberThing is though, surely if fire does cause damage to the steel, at best it will only cause localised buckling of the steelwork, which would mean only a small portion of the structure would be likely to collapse…
Well apparently not.
jonnyboiFull Memberassuming you have looked into the construction of WTC 1&2 are you happy that both airplanes(aluminium framed and skinned) hit both towers with sufficient force to not only penetrate the steel outer skin of the building but to also penetrate through the building to sufficiently damage the inner core of the building to such an extent that it would cause a complete collapse
The fire caused the collapse, not the plane impact. That’s been well established.
We’re just going back over old ground again and again now. If your going to jump in, at least read up in the debate so far
WhathaveisaidnowFree MemberJust the heat and the smoke from all the other
? buildings on fire, you couldnít see anything.
So it took us a while (i.5 hrs) and we ended up backing
p
p everybody out, and thatís when 7 collapsed.Lieutenant William Ryan, Ladder 85
Yet they could see well enough to carry out a structural inspection to determine when it was going to collapse?
WhathaveisaidnowFree Member3 massive skyscrapers completely disappear due to fire…, on the same day…
gotta be…
maxtorqueFull MemberDo i think a 100 tonne aircraft doing 500mph could damage the towers?
Seriously? No, i’d expect it to just bounce off without even scratching the paint……
(back of an envelope calc suggest around 4GJ of energy stored in the planes mass at that speed, or about the same as an entire tonne of TNT going off. so yes, plenty enough to damage a building! In fact, it’s more amazing that the Towers even survived the initial impact at all!)
jonnyboiFull MemberWhathaveisaidnow – Member
? buildings on fire, you couldnít see anything.So it took us a while (i.5 hrs) and we ended up backing
p
I’m really sorry, but you appear to be struggling to make any kind of coherent point in your posts.
cheekyboyFree MemberThe fire caused the collapse, not the plane impact. That’s been well established
So answer my second question then !
I call that reviewing !
Ive been here since page one Johnny boy
sbobFree MemberWhathaveisaidnow – Member
fire……terrorist attack you mentalist.
Care to comment on the fireproof explosives used?No, because in the words of Mhairi Black, you’re chattin’ shite hen.
Completely disappear?
Didn’t happen ya shitehawk.You’re not suitably equipped for this discussion pet.
maxtorqueFull MemberTurnerGuy
go f*** yourself.Hit a nerve did i? Imagine how angry you’d be if someone you loved had been killed and some other idiot was talking total rubbish about the way they were killed…….
Have some respect.
jonnyboiFull MemberIve been here since page one Johnny boy
Well do me a favour and pay attention, or at least read up on the previous answers.
cheekyboyFree Member(back of an envelope calc suggest around 4GJ of energy stored in the planes mass at that speed, or about the same as an entire tonne of TNT going off. so yes, plenty enough to damage a building!
So a thin skinned aluminium airplane can penetrate to the core and cause sufficient damage, could you scan in and post your back of an envelope calc, keep it simple eh 😉
So was it the fire or the impact that caused collapse ?
Johnny Boy has established it was fire !
nedrapierFull MemberImagine how angry you’d be if someone you loved had been killed and some other idiot was talking total rubbish about the way they were killed…….
If you read about what the relatives of those who died are still dealing with, and not being able to deal with, you’ll realise that people discussing their feelings about explanations of the day on a UK mountain bike forum are the least of their worries. Could even be that they’re not worried at all.
And some of them are truthers anyway. So I refer you to TGs response, you’ve been quite happy to get stuck into the discussion too.
jonnyboiFull MemberJohnny Boy has established it was fire !
I can’t take the credit, but you’d know that if you were paying attention rather than trolling
Nearly every large building has a redundant design that allows for loss of one primary structural member, such as a column. However, when multiple members fail, the shifting loads eventually overstress the adjacent members and the collapse occurs like a row of dominoes falling down.
The perimeter tube design of the WTC was highly redundant. It survived the loss of several exterior columns due to aircraft impact, but the ensuing fire led to other steel failures. Many structural engineers believe that the weak points—the limiting factors on design allowables—were the angle clips that held the floor joists between the columns on the perimeter wall and the core structure (see Figure 5). With a 700 Pa floor design allowable, each floor should have been able to support approximately 1,300 t beyond its own weight. The total weight of each tower was about 500,000 t.
As the joists on one or two of the most heavily burned floors gave way and the outer box columns began to bow outward, the floors above them also fell. The floor below (with its 1,300 t design capacity) could not support the roughly 45,000 t of ten floors (or more) above crashing down on these angle clips. This started the domino effect that caused the buildings to collapse within ten seconds,
WhathaveisaidnowFree Member…terrorist attack you mentalist.
the explosives could have been strategically placed below the impact zone, the drone planes hitting exact spots. Entirely plausible.
the rest of your post leaves a bit to be desired.
wobbliscottFree Memberook how it came down just like a demolition, case closed.
No it didn’t. Nothing like a controlled demolition. Nothing like it at all. In a controlled demolition the entire building falls at the same rate. The WTC didn’t. There was a failure over a couple of floors, the top part of the building clearly fell before the bottom part of the building did. Not sure how heavy the top part of the building was – maybe around 10,000 tons? traveling at 20mph, it is going to be pretty hard to stop and can easily over stress steel and reinforced concrete.
The fact aircraft are made of aluminium is utterly irrelevant. A ton of aluminium weighs the same as a ton of steel and has the same energy at the same speed. The fact is 100,000kg of material slamming into the side of the building is going to do some damage no matter what material it is. But what about engines? 10 tons each of pretty much solid titanium, what about undercarriage, again pretty substantially solid projectile, all the motors, systems, boxes of equipment, avionics etc, seats, luggage, they’re all pretty solid structures which became projectiles. The towers were designed to withstand the impact of aircraft anyway. Maybe not a fully laden 747, but upto 727/737 size at least.
The building didn’t have a steel outer skin. It was not armoured in any way. It was a steel girder skeleton so perfectly feasible for the aircraft to penetrate the building – girders are designed to withstand forces in compression and tension – not in bending from a side impact. Have you not seen the footage? aircraft clearly penetrating the side of the buildings. You’ve seen it with your own eyes and yet you doubt it.
Anyway the towers are mostly fresh air with a very skeletal structure. So not that solid or sturdy in relation to impacts from the side:-
Erm, yes….localised ‘buckling’ will do it. A buckled girder no longer has strength in compression. The failure mode of the collapse was an initial collapse localised to one or two floors. The sheer weight of the top part of the building did the rest. Perfectly understandable and explainable with simple engineering principles. The north tower was hit first, but at a higher level, so about 14 floors above the crash level. The south tower was then hit lower down with about 30 floors above the crash level. The South tower collapsed first because of the higher weight of the upper part of the building. Again, perfectly explainable by engineering.
Only to those ignorant of basic structural engineering principles. Steel is not a very good material at elevated temperatures. It looses a significant amount of its strength at a relatively low temperature of 500 ish degs C. Why is it so difficult to grasp the concept that if you significantly weaken the structure of a building it will collapse??? Really, what is so difficult to grasp with that concept?
WhathaveisaidnowFree MemberAs the joists on one or two of the most heavily burned floors gave way and the outer box columns began to bow outward, the floors above them also fell. The floor below (with its 1,300 t design capacity) could not support the roughly 45,000 t of ten floors (or more) above crashing down on these angle clips.
wow was this guy in there? How did he survive?
jonnyboiFull Memberwow was this guy in there? How did he survive?
You really don’t have a coherent argument to make. That is clear
WhathaveisaidnowFree MemberI’m really sorry, but you appear to be struggling to make any kind of coherent point in your posts.
I just want someone to explain to me how they new WT7 was definitely going to collapse, seemingly to the minute.
outofbreathFree Memberthe explosives could have been strategically placed below the impact zone, the drone planes hitting exact spots. Entirely plausible.
Neither drones nor planted explosives are remotely plausible. [1]
[1] If drones you have to explain how the aircraft went missing without anyone finding out (or any whistle blower coming forward), if explosives you have to explain how nobody noticed them being installed (and why no whistle blower came forward).
GreybeardFree Memberare you happy that both airplanes(aluminium framed and skinned) hit both towers with sufficient force
It’s irrelevant that they were aluminium – that mass of water at that speed would have made the same size hole
My calc is near 6GJ – and I did also calculate once that the chemical energy in the fuel is about 3 orders of magnitude bigger.
Unlike most buildings, the cores in WTC 1 and 2 were not the primary structure, that was the perimeter columns.
Until the Ronan Point partial collapse in 1968, nobody really considered progressive collapse, but after that the UK building codes required larger buildings to remain stable if one column was removed. The US codes didn’t make this change until after 2001.
Below the impact zone?
Of 7 WTC?
You’re losing the suspension of your disbelief.the rest of your post
leaves a bit to be desired……is plausible. 💡
jonnyboiFull Memberthe explosives could have been strategically placed below the impact zone, the drone planes hitting exact spots. Entirely plausible.
You seem like a gullible chap, care to help out a Nigerian prince looking to hide his money?
cheekyboyFree MemberNearly every large building has a redundant design that allows for loss of one primary structural member, such as a column. However, when multiple members fail,
Ok
What other steel failures ? columns ? trusses ? which ones ?
So if the angle brackets failed all around the outer of the core and the inner of the perimeter tube, they must have failed simultaneously or the remaining angle brackets would have slowed the falling of the floors ! it still doesnt explain the total collapse of the core of the building, may I suggest you have a look into that before accusing folk of trolling.
Unless of course it was the impact of the planes which you vehemently refute.
maxtorqueFull MemberCould people stop asking for “things to be explained” and then not listen to that very explanation!
I have explained in multiple posts how, using science, engineering and physics, the events of that terrible day most probably occurred. If you are so blinkered as to choose to ignore those explanations that is fine, that is your decision, but if so, you can’t then ask for it to be re-explained to you.
nedrapierFull MemberUntil the Ronan Point partial collapse in 1968, nobody really considered progressive collapse, but after that the UK building codes required larger buildings to remain stable if one column was removed. The US codes didn’t make this change until after 2001.
greybeard, are those changes covered in these recommendations below, or were they made by someone else? Or were they made to the codes without recommendation? Given NISTs conclusions of single column failure being the cause, I would have thought that would be definitely be in here, but I can only see recommendations to fire protection of steel and items for life safety and evacuation.
What specific code changes based on recommendations from NIST’s investigation of the WTC towers have been approved for inclusion in the International Building Code?
The eight specific code changes adopted in the International Building Code based on recommendations from NIST’s investigation of the WTC towers include:
1. An additional exit stairway for buildings more than 420 feet in height.
2. A minimum of one fire service access elevator for buildings more than 120 feet in height.
3. Increased bond strength for fireproofing (nearly three times greater than currently required for buildings 75-420 feet in height and seven times greater for buildings more than 420 feet in height).
4. Field installation requirements for fireproofing to ensure that:
installation complies with the manufacturer’s instructions;
the substrates (surfaces being fireproofed) are clean and free of any condition that prevents adhesion;
testing is conducted to demonstrate that required adhesion is maintained for primed, painted or encapsulated steel surfaces; and
the finished condition of the installed fireproofing, upon complete drying or curing, does not exhibit cracks, voids, spalls, delamination or any exposure of the substrate.5. Special field inspections of fireproofing to ensure that its as-installed thickness, density and bond strength meet specified requirements, and that a bonding agent is applied when the bond strength is less than required due to the effect of a primed, painted or encapsulated steel surface. The inspections are to be performed after the rough installation of mechanical, electrical, plumbing, sprinkler and ceiling systems.
6. Increasing by one hour the fire-resistance rating of structural components and assemblies in buildings 420 feet and higher. (This change was approved in a prior edition of the code.)
7. Explicit adoption of the “structural frame” approach to fire resistance ratings that requires all members of the primary structural frame to have the higher fire resistance rating commonly required for columns. The primary structural frame includes the columns, other structural members including the girders, beams, trusses, and spandrels having direct connections to the columns, and bracing members designed to carry gravity loads.
8. Luminous markings delineating the exit path (including vertical exit enclosures and passageways) in buildings more than 75 feet in height to facilitate rapid egress and full building evacuation.wobbliscottFree Memberthe explosives could have been strategically placed below the impact zone, the drone planes hitting exact spots. Entirely plausible.
No it’s not plausible at all. Drone planes???? The location of every 757 and 767 ever made is known. It is tracked. So where would you source a 757 or 767, make it ‘disappear’ only to re-appear as a drone? Also aircraft parts are serialised so the manufacturers have confirmed the serial number of every component retrieved from the site. It’s impossible.
Even if they were drone aircraft you couldn’t fly them accurately to a specific floor. I can’t believe you really think this is more plausible than terrorists hijacking aircraft and flying them into the buildings.
The topic ‘9/11 documentary’ is closed to new replies.
