Home › Forums › Chat Forum › 9/11 documentary
- This topic has 1,455 replies, 118 voices, and was last updated 6 years ago by jivehoneyjive.
9/11 documentary
jimjamFree Member
Did we figure out how many conspirators there were? Did jivehoneyjive give us his opinion on the roundness of the earth?
nealgloverFree MemberThe real winners here are those of us who will enjoy lampooning future use of “the Lower Manhattan Defence”
TurnerGuyFree Memberimpossible to take anything he says seriously
nobody here takes anything I say seriously anyway !
5plusn8Free Membernobody here takes anything I say seriously anyway !
You made the fatal mistake of taking what I said seriously!
TurnerGuyFree MemberYou made the fatal mistake of taking what I said seriously!
you serious ?
5plusn8Free Memberyou serious ?
I am, but like you, nobody takes me seriously either..
jonnyboiFull MemberTurnerGuy – Member
you seriousAhh, the troll is trolled 😉
ctkFull MemberI like this guy’s attitude. I assume that it makes a big difference that the towers floors are more connected than in his experiments. Edit experiments start at approx 5 mins if you find his droning on a bit boring 😉
slowoldmanFull MemberYep, none of those models appear to match the actual structure.
So I’m compelled to say I remain unconvinced.
nedrapierFull MemberI’m going to dive back in again, why not! 😀
I wouldn’t want anyone to think I ran away, especially with 5plusn8 keen to talk at the time. I had some long meetings yesterday and things had moved on when I came back.
All I wanted to do in the first place was to have a poke. I find the whole set of circumstances baffling, and I find some people’s 100% certainty in one explanation of what happened baffling. It annoys me that people accuse others of logical leaps, reliance on assumptions and rigid beliefs while not realising they’re guilty of much the same.
The whole set of events is implausible, discounting objections because an alternative might also be implausible seems a bit… rigid.
“Give me Evidence!” TJ screams. NIST used no physical evidence in analsing WCT7 whatsoever, and say so on their website.
“Give me one piece that you think is credible and I will demolish it citing real scientists” then takes something off Wikipedia citing Jesse Ventura (on youtube, btw).
“There is no scientific doubt whatsoever!” NIST’s report is ENTITLED “Probable causes…”
So I’m awarding TJ the rabid intractability award.
amedias, you’ve been very reasonable and patient throughout. 10/10. :-), I’m happy to admit that my main issue is, as you say “it looks a bit funny” especially building 7. NIST say planes weren’t a factor, collapses of 1 and 2 weren’t a factor, debris from those collapses wasn’t a factor, fuel oil not a factor. Scattered office fires (no photos I’ve seen show them to be especially raging), leading to thermal expansion of steel supports around the building, one girder becomes detached from one main column, which buckles, leading extremely quickly to the whole thing dropping out of the sky like a house of cards. Looks a bit funny – quite happy to say it again. 46 storey building, 20 years old.
They’ve produced a computer model to provide an animation of the progressive collapse, but what are people (outside of this discussion) quite happy to say about models? Sometimes useful, and… something else…?
amedias, you know more than me about physics, but essentially (as you’ve admitted you can’t fully explain it) you’ve got a model in your head of weakened supports in 1&2, load sharing, collapsing, pancaking that you play over you don’t have a problem with it. I can play that one as well, seems fair. I can also imagine asymmetric damage, leaning, (you’ve said it’s impossible, but I think there’s a picture of the top bit of one of the towers leaning?) one side being under more pressure than the other due to the movement, and steel being much stronger in tension than compression the leaning being exaggerated, rather than corrected.
I can’t say that one or the other is impossible, but you can. Despite you having more physics knowledge than me, I’m still not convinced 100%.
So that’s me, nedrapier, remaining compelled but unconvinced. Doesn’t mean I know what happened, or even that I have a position on what I think happened, or even that I’m unaware that alternatives also have difficulties, but a lot of difficulties were overcome that day. and a lot weren’t, and aren’t.
tjagainFull Membernedrapier. MY point was no one has been able to come up with a single credible shred of evidence that the conspiracy theories are true or that the official line is not true
No one on this thread has posted one piece of “evidence” that stands up to the slightest scrutiny. NO one world wide has come up with the slightest bit of credible evidence that the official line is not true
ctkFull MemberBut why should we take the official line as gospel?
What if the official line was controlled demo? Could you prove otherwise?
tjagainFull MemberGive me one piece that you think is credible and I will demolish it citing real scientists” then takes something off Wikipedia citing Jesse Ventura
The wiki piece has 3 reference to proper peer reviewed papers that completely debunked the nonsense about thermite. which was the only bit I was looking at.
jonnyboiFull MemberBut why should we take the official line as gospel
You shouldn’t. Use your own critical thinking. Watch and read the news from different sources, look into the reports that have been published. Consider expert testimony.
maxtorqueFull MemberRE: The video up there^^^
Someone who isn’t a physicist once again gets the wrong answer!
You cannot directly “scale” experiments because not all physical properties scale linearly with absolute size. For example Froude number (the ratio between inertia and gravity) Reynolds number (the ratio between inertia and viscousity) and many more critical parameters (Weber, Mach, etc etc) must be carefully scaled in order to produce a valid comparison with the full sized event.
Funnily enough, this science has it’s own name, and history (Dimensional Analysis) and is generally not something a layperson understands implicitly.
The reason a 6foot model made of paper doesn’t collapse like a 1200 foot building made of 1000’s of tonnes of steel and concrete is precisely because of these non linear scaling issues (and also incidentally why a bumble bee can fly, despite basic physics suggesting it can’t! (At the BB’s scale, the air appears significantly more viscous, making flight possible)
Let me give you a simple example. He uses thin paper walls as supports. But paper has a very low density, so the viscosity of the surrounding air actually supports and damps a paper wall by a significant factor. meaning a small model with paper walls is massively more resistant to buckling that if that scale model was actually life sized, where the viscosity of the air is much less significant.
or another example, surface tension. if you are a small insect, you can walk on water due to the surface tension. try that as a human and you’re going to get wet!
All these factors and many more invalidate basic scale modelling unless it is done extremely carefully indeed!
nickcFull MemberNIST’s report is ENTITLED “Probable causes..
so, all this demonstrates is you don’t understand the scientific model
I’m oot, pigeons, chess, arguing, idiots…rearrange to form a well known phrase or saying
maxtorqueFull MemberFor me, the collapse of the main towers looks absolutely to follow basic, expected patterns. Even if you hadn’t seen the aircraft hit, the fact the towers buckled at the fire zone, and that the tower with more mass above that point fell first, all makes scientific sense. Add in the poor lateral connection between floors and the exoskeleton design of the main towers and a pancake style collapse from the point of impact isn’t unexpected.
WTC7 is indeed different. It does look to collapse from low level first, btu that to me doesn’t scream conspiracy, it screams that the collapse was due to a different mechanism.
Immediately the presence of a large underground void under the complex springs to mind. That void held up both main towers and WTC7 in some way (i’m sure the load sharing is extremely complex!). Considering that half a million tonnes of building had just fallen down, i’d suggest that a lower level structural failure, resulting in WTC7 being undermined is a likely possibility.
Undermining can bring down a structurally sound building, let aloe one already compromised by fire and impact.So, here’s the question:
Which is more probable:
1) WTC7 collapse through complex, not that understood and difficult to prove factors, but those factors do carry a weight of sensible and understood science behind them
2) WTC7 was for some (unexplained reason) deliberately blown down after the Towers Fell.
Given that 2) requires an enormous number of people, huge pre-planning, massive costs, has no proven benefit, and the fact that the same result could be achieved without the planes and tower bit (a lorry bomb, or simple fire could have been used to destroy what ever “evidence” was to be destroyed with a lot less hassle and chance of discovery) even without any evidence i’d suggest sane and logical people (in fact the majority) think the Conspiracy theorists are idiots…..
nealgloverFree MemberScattered office fires (no photos I’ve seen show them to be especially raging)
You’ve not seen this one then ?
nedrapierFull Membermax, you’re making stuff up. NIST ahve done a model that completely discounts what you say.
And you bring me back to my original point back on page humtytum: either neat collapses of buildings are extremely hard to achieve and demand huge time, planning, resources, skill and disruption, or they are (WCT1&2) the inevitable result of asymmetric damage and heat in a localised area or 7) can happen as the result of random buckling on one vertical tower and some other damage by thermal expansion at hundreds of degrees below design parameters following some scattered office fires.
The two positions are hard to reconcile, even more so when you’re being told that one follows from the other: that a neat collapse is so hard to co-ordinate that it must have been completely unco-ordinated.
TurnerGuyFree MemberThe fact that the report was entitled Probable and they started clearing the site so early smacks of something strange – you would think they would want to conduct some more forensic examinations to move towards a better snd less questionable understanding of what happened.
You don’t get a chance to examine such an unexpected failure mode often.
They are still examining the Grenfell tower site for example.
They might have been told that things have to turn around quickly on the site for some other reason, not necessarily a suspect one though.
nedrapierFull Member“Probable” is there because they’re scientists and they recognise there’s always scientific doubt.
nedrapierFull Memberneal, I can’t see any fire in that shot. fair bit of smoke (or dust?), bit of soot round a few of the windows.
nealgloverFree Memberneal, I can’t see any fire in that shot. fair bit of smoke (or dust?), bit of soot round a few of the windows.
Yeah, that’ll be it. Probably dust pouring out of virtually every window.
The cleaners emptying hoover bags or something. That can be really dusty.
Certainly wouldn’t be the fires that were known to be burning unchecked for hours.
nedrapierFull MemberI said I’ve not seen pictures of raging fires. you show me a picture with no fire in it. The only evidence that fire has come out of any windows is a bit of soot round 8 of them windows. It’s a small photo, so it’s difficult to say for certain, but some of the windows are broken, all the ones with soot round them obviously, and you can see some of the interior frame, same with a few below and a few at the top. The rest are flat black. Does that mean a lot aren’t broken?
I mentioned dust because it reminded me of this. Buildings near the water weren’t on fire, and have dust (or smoke?) pouring off the leeward side.
jonnyboiFull MemberI said I’ve not seen pictures of raging fires. you show me a picture with no fire in it. the only evidence that fire has come of of any widows is a bit of soot round 8 of the windows.
Damnit, I’m gonna have to finally share a you tube video
maxtorqueFull MemberTurnerGuy
you would think they would want to conduct some more forensic examinationswhy? Some jets hit the towers, they fell down. You’d have to be a complete idiot to conduct a forensic examination of a scene where the cause was plane (sic) to see by anyone with eyes and an iq of more than 7……
So not only did they not conduct a forensic exam, it probably didn’t even cross their mind they might need to do so, so that in 15 years time they could provide “proof” as to why the building fell down (when they’d just watched it fall down with their own eyes after being hit by jet aircraft)
Funny enough, all these conspiracy theories have taken years to come out the wood work. You know why? It’s because if the day after the event, when lets not forget, over 3000 people died, you said “ooh it was all a government plot” or whatever idiotic rubbish you freely spout today, you’d have been linch’d!
Please stop disrespecting and tarnishing those 3000 ordinary people who died that day, in an effort to get attention for yourself!
nealgloverFree MemberI said I’ve not seen pictures of raging fires. you show me a picture with no fire in it.
You can’t see the fire because of the massive amounts of smoke it’s giving off.
Covering the whole side of a massive building.What would that suggest to you ?
A : Tiny fire.
B : Massive fire.maxtorqueFull MemberIt’s also easy to miss the scale of WTC7. It was 47 floors tall. For reference, the Grenfell tower is/was just 24 floors tall, pretty much half the height!
outofbreathFree MemberThe whole set of events is implausible
Perhaps it seems unlikely that a load of criminals would get hold of 4 planes and be competent enough that 3 of the four would get to their targets and hit them. However, implausable or not the evidence that that happened is overwhelming.
No, the alternatives aren’t implausible. They are utterly impossible. There’s no hint of any other credible way these events could have happened. This is why quibbling about the ‘official’ version is a waste of brain energy. Even if the official version was fundamentally flawed (it isn’t) the alternatives are so insane and logically impossible that you’d discount them as well and have to admit you couldn’t explain it at all.
amediasFree MemberThe whole set of events is implausible
Well, you need to differentiate a bit here.
It was highly unlikely that a bunch of hijackers would get hold of some planes and successfully fly them into two of the tallest towers in the word. That’s fairly improbable, I’ll grant you that, but not in and of itself implausible…
But from that point on what happened is rather plausible indeed. Massive damage the building, jet fuel explosion, raging fire… it’s not at all implausible that this would cause the buildings to collapse, I’d even go so far as to say probable.
just want to say a few words about this bit in case some clarity around my comments is required…
I’ve not said, and will not say, that differential weakening, or localised sagging/tipping/leaning is not possible, as not only is it clearly visible in pictures and video, it’s to be expected. But as a whole (and thats the important bit) the twin towers couldn’t collapse in any other way than ‘down into a localised area/their footprint. There may be minor deviations at a local level, but not on the overall scale.
The slight tipping of the top section thats visible is the start of initiated collapse due to the structure failing, it’s not so much tipping (implying a coherent top structure pivoting) as it is sagging/deformation of the structure below. IT’s a result of damage, and once the structure is comprised enough, it starts to give way. As soon as it starts ‘to go’ so to speak, there is nothing present that could divert it from pretty much straight down. The top section lacks integrity and they’re simply too tall, too massive, and have insufficient integrity once compromised to topple or split or anything like that.
I hope I’m making myself clear?
I guess what I’m trying to say is that the observed collapse, to me, doesn’t look unusual in any way. You cna argue the toss about the specifics of where the structure first started to fail and why, but the collapse looks totally explicable for a structure of that type and size.
And here’s the kicker, controlled/initiated demolition or structural failure would BOTH result in an essentially similar looking collapse. The initiation events may be different, but as a whole it’s gonna go down in the same way overall. Which is another reason that neat collapse doesn’t imply demolition*.
I don;t know as much about 7, chiefly because I’ve not read that much about it. And while I keep an open mind about it I’ve really not seen compelling (that word again) evidence of anything fishy. I’ve see a few doubts cast on the official explanation, but most of those centre around scale of impact, eg: fires weren’t big enough, it wasn’t damaged enough. That’s fine, but pointing at a few less than complete aspects of an explanation is very different from providing actual evidence of an alternative.
It somebody says the explanation has errors or holes in it fair enough, lets investigate further and see if we can plug those knowledge gaps, or if some calculations were wrong, or maybe there are simply some bits we will never have enough info on to know for sure, but again, that is VERY different from having any actual evidence of an alternative. And I’ll hold my hands up to the fact I’m an evidence based kinda guy. Right now I’ve got a lot of evidence of a mostly explicable, and at least plausible collapse due to damage. I have no evidence of an alternative, the only thing close to evidence is doubt of the evidence we do have. Lets also be clear, doubt can be investigated and either resolved, or not, but it is not actually supporting evidence of another theory.
*Also, the entire point of controlled demolition is not ‘to blow it up’ but to ‘initiate collapse’. You’d essentially be trying to cause a structural failure, but in a controlled manner, the explosive bit is only used to compromise integrity and start the collapse, hence why collapse is in the same manner.
DracFull Memberthe Grenfell tower is/was just 24 floors tall, pretty much half the height!
Almost a third 610 feet vs 220 feet.
nedrapierFull Membercheers jonnyboi. (Youtube?!?!?!?!? WTAF?)
Same 8 windows, I think, with fire coming out of them, some more round the corner of the same 8, and another fire in 6 windows, which spreads to the next floor. some of the flames are quite big I guess. Raging? guess so. wouldn’t want to be stood near them.
Still, that’s 3 or four sections of 3 or four floors shown in the video. And an awful lot of windows not even broken.
Those 10 words in brackets don’t add much or take much away from the rest of my post, so if that’s all you’ve got to object to…?
maxtorqueFull MemberAlso worth noting that it’s extremely rare to do an explosive demolition of any building without first also weakening the primary (frame) and secondary (walls and floors) structural components first. To take down an un-weakened building with just explosives would require a massive amount of them, and to ensure a clean take down, pretty much every structural component would have to be individually rigged and sequenced.
Added to which, commercial explosive demolition with high speed explosives requires the explosives to be covered, generally with layers of wire mesh and nylon sacking, with the aim of trying to minimise high velocity debris, that can travel 100’s of meters.
In all cases, the insides of the building are gutted first to allow access to the structure and to allow weakening of load bearing components. To do that to a steel framed building that is intrinsically strong and flexible would be hard enough, to do to a building that was still occupied without it being obvious would be beyond difficult.
And no, you can’t build in charges when the building was built (explosives are “Lifed” they degrade and become unstable over time, even modern safety explosives). To rig a building at build would be extremely risky, not to mention i think the builders might notice
nedrapierFull MemberOr you can set a few floors on fire and you’ll get the same result.
jonnyboiFull Membercheers jonnyboi. (Youtube?!?!?!?!? WTAF?)
I know, I hate myself a little bit
Some evidence of a raging fire, no more no less. I’m not expecting you to extrapolate it into anything (which let’s be honest a lot of truthers do with tiny bits of information)
Just add it to the body of evidence to enable a value based judgement
nedrapierFull Membercheers for the long post amedias. You’ve made yourself clear.
You’re not 100%, but you’ve happy enough and you’ve seen no reason to think otherwise.
Not much to argue with there, I agree with a lot of it, and haven’t said any more than you regarding alternatives.
Got your point about the demolition too. You just need to initiate it. one of two floors might be all you need?
The topic ‘9/11 documentary’ is closed to new replies.
