You should be able to get my address by clicking the ‘Member’ link next to my username. I’m guessing posting it direct in the forum is an invitation to spammers…
I’ve not claimed payments yet, partly because I’ve been busy but also because I’m waiting for the parts to arrive.
Regarding batteries and battery life, the output power drain of the unit will be about 7.5W on full beam including the losses within the driver. Multiply the battery voltage by the capacity (amp-hours, if it is in mAh, divide by 1000) and that gives the power available in the battery. Divide this by 7.5 to get the approximate run time on full power.
It might be worth considering going for the type of batteries that keep their charge – standard NiMHs discharge fairly quickly once removed from the charger. Sanyo Enloop and Gp Recyko+ are two that have this property. You could make a nice little permanent pack and use a plug-in charger rather than having to remove the cells each time you want to charge them up. I find CPC (cpc.farnell.com) have a good range of chargers and batteries but you need to spend £45 with them to avoid a small order surcharge. Otherwise, I’m sure eBay will come up with something or Maplin if you don’t mind paying their price premium.
(That said, I’m surprised that Maplin aren’t that much more expensive than Rapid for the Hammond enclosure.)
