Sorry for the delay guys, can’t access the forum at work and went straight over to see the missus from there…
My proposal is to supply a kit of useful parts – if anyone just wants the driver please let me know but otherwise I’d prefer to supply just the kit to save confusion over who wants what!
The kit will include:
970mA output driver
Three-way switch
Weather-proof boot for above
2.5mm power socket
2.5mm plug with 1.8m of cable
160k resistor to give a low power mode of approx. 450mA
I’ll try and remember to throw in a few bits of wire for those who may not have this to hand.
I’ll do the lot for £7.50 per kit plus £1 postage per order. Paypal payments to address in my profile please. (As with Troutie, sending as a gift rather than payment for goods would be appreciated as it means I don’t pay fees) I’m hoping to have the extras in to send out on Tuesday – I’m away this weekend and won’t have time on Monday to post anything I’m afraid.
One point here – if anyone is intending to drive this from 2x lithium cells, please let me know as I’ll ship a slightly different version of the driver which is better suited to running from low voltages / limited headroom. Three lithium or 8 NiMH is fine with the standard driver.
As an aside, I don’t know how you’d charge them but you can get lithium cells in AA size these days – 14505 size. I’ve seen ones with 2Ah capacity which would give you over three hours run time if you used three of them and you could use a standard AA battery box.
Just to clear up a few other points…
The dimming resistor on the driver – the lower the resistor value the lower the output current. If you do R / ( R + 200k ) then this gives the approximate fraction of full power you will get. You will need a fairly large value pot if you want the level variable, again the above equation will help you work out what current you will get. A logarithmic pot is better as it gives a more linear response.
The spec of the resistor isn’t important – you are passing microamps through it so it doesn’t need to be high power or anything like that.
Ermm… Someone mentioned sticking the LEDs down rather than screwing them – I’d not recommend this as there will be a lot of vibration so a mechanical fixing would be more reliable.
