If anyone didn’t manage to get the DIY pack I’ve
(a) Tidied my desk and found another switch lurking
and
(b) bought a few double-pole switches from Rapid
I now can supply another 4 packs if anyone needs them.
(Jazid, you pack with extra switch is on the way!)
Is the AAA electrically conductive or insulative? (This usually depends if it is metal or ceramic-loaded) The two small holes on the driver can be electrically connected together but not to anything else.
Certainly worth using insulating washers when screwing the LEDs down to avoid any potential problems. Temperature shouldn’t be a major issue – if you are getting over about 80C at that point you are frying the LED die anyway…
