Home › Forums › Chat Forum › 9/11 documentary
- This topic has 1,455 replies, 118 voices, and was last updated 6 years ago by jivehoneyjive.
9/11 documentary
mrlebowskiFree Member
I know. Imagine being able to keep a thread going for a whole DAY. Incredible isn’t it.
You’re a sarcastic ass – best head for the EU thread, you’d fit in well over there.
CountZeroFull Memberhttp://www.bbc.co.uk/science/horizon/2001/worldtradecenter.shtml
http://911research.wtc7.net/reviews/NationalGeographic/cache/9-11-science-and-conspiracy-4067.htmlWhathaveisaidnow – Member
WT7 was a controlled demolition,…. please look into it.The video that you posted shows 7WTC collapsing and shows a controlled demolition for comparison.
Why does 7WTC collapse in one corner first?
Many seconds before the rest of the building?
That’s not how a controlled demo happens.
I posted the links above before the quoted posts, if Whathaveisaidnow had looked into them…nealgloverFree MemberYou’re a sarcastic ass
Sarcastic Arse
I’m from Yorkshire not Yonkers
5plusn8Free Memberslowoldman – Member
What’s the relevance of “free fall speed”?It is some kind of conceptual fallacy that the falling building should fall at less than the speed due to acceleration of gravity cos it crashes into itself and has to kind of pause at each level.
tjagainFull MemberAnd anyway they did fall at less than freefall speed precisely because hitting each lower layer slowed it
mikewsmithFree MemberWhat is the relevance? It’s just evidence that is created, covered up or true. Just delete as appropriate to fit your ideas.
What if jfk elvis and marylin did it?5plusn8Free MemberAnd anyway they did fall at less than freefall speed precisely because hitting each lower layer slowed it
Apparently due to the viscosity of the mush in front of it… It is very hard measure as the top bit disintegrated on the way down and defining which bit falls at what speed is tough if the bit you measure changes shape during the movement.
Not to mention that calculating the freefall speed is also complicated by the shape and air resistance of the objects varying as they disintegrate and tumble, some parts be like a lead ball others like a feather. Plus some of the material was ejected sideways which complicated matters further.My understanding is that the “freefall speed” adherents expected it to fall much much slower, and to kind of klunk at every level, whereas it fell more or less in the amount of time it would take a single object to fall. Any pauses were microscopically short because the kinetic energy was massive compared to the energy devoted to the work of destroying the material below.
The implication to the uninitiated is that the close to freefall speed means the building was destroyed from below, ie conspiracy. Woooooo
neilwheelFree MemberI can believe that Trump is actually a lizard, so it all makes sense now, and I want to change sides please.
mcj78Free MemberI can’t believe it’s gone 6 pages & no-one’s mentioned the plane hitting the Pentagon and not a single of the 500000 security cameras in the area seen it happen 😉
Three_FishFree MemberMy understanding is that the “freefall speed” adherents expected it to fall much much slower, and to kind of klunk at every level, whereas it fell more or less in the amount of time it would take a single object to fall. Any pauses were microscopically short because the kinetic energy was massive compared to the energy devoted to the work of destroying the material below.
So, using only the assistance of gravity, 15-20% of each tower was able to pulverise, obliterate the undamaged remaining 80-85%? A small, relatively fragile object was able to almost totally ignore the resistance of an enormous, rigid object and make it to earth before falling apart itself? Or it fell apart on the way down but still remained compact enough to effectively retain its mass, allowing it to continue smashing through the intact structure below without resistance? Why do I not use tea bags to hammer in nails?
JunkyardFree Memberyou could if you used thirty ton tea bags
yes floor by floor as no floor was designed to withstand the impact of 15-20 % of the mass of the tower hitting it [ why does this surprise you?]- its a cascade fall
jimjamFree MemberJunkyard – lazarus
Why even indulge the argument? If you just assume a devils advocate position and say “okay, it was a controlled demolition, now lets hash that out” you are into an even more fanciful and far fetched conspiracy – ie that thousands of government employees conducted massively destructed and invasive pre-demolition prep on the twin towers which would easily have taken 6 months to a year and no one noticed. No one questioned anything. None of the survivors recall seeing strange men drilling strange holes into support structure,
and none of the giant demolition team came forward.
Find out what the biggest controlled demolition thus far has been and look at the level of work, prep and time that goes into something like that. It’s completely idiotic to suggest the twin towers were brought down by controlled demolition.
5plusn8Free MemberI am only an accountant so I am not used to such big numbers, and I haven’t had my coffee yet however:
It was 20 floors I just read, of 120. So thats 16% of the mass which was 450,000,000 KG. (https://hypertextbook.com/facts/2004/EricChen.shtml)lets get it moving by say 1/2m the gap it fall through when it started to fall.
PEi=mgh
Potential energy (i means intial, lets make that zero)
=0.16x450000000x9.8×0.5 =352million joules. That much energy to give up in the first half metre..it is not relatively small its 16% of the total mass below it, and it only needs to destroy one floor below it ie 1%, the mass is now 1% bigger and still accelerating. By a few more meters. Every floor it increases mass and is going faster.
Plug in the original mass, having now moved a single floor (2 metres) and its 4 times as much energy as we had in the beginning..Edit – as I was typing this junkyard and Jim jam replied with the same point.
bikebouyFree Membermcj78 – Member
I can’t believe it’s gone 6 pages & no-one’s mentioned the plane hitting the Pentagon and not a single of the 500000 security cameras in the area seen it happenmikewsmithFree MemberThey did it to cover up the fake moon landing and the fact gwb was a woman
whitestoneFree MemberSo, using only the assistance of gravity, 15-20% of each tower was able to pulverise, obliterate the undamaged remaining 80-85%?
It didn’t have to, the top 15-20% only had to crush the floor below. Now, instead of it being 20% of the total mass it’s 21% (give or take as there were 110 floors) so it’s got a bit more energy (remember this is kinetic energy not static) on its descent and it crushes the next floor so the total mass is 22%. Some of the mass was ejected to the sides but there was enough remaining that nothing below could stop its descent destroying each floor in turn.
NorthwindFull Memberjimjam – Member
The whole “freefall” thing is classic conspiracy theory thinking- it doesn’t have to be credible, it just has to contradict the official account. A controlled demolition wouldn’t completely take away the resistance of the structure below either so the same “issue” with the official version would also apply to the consipracy version. But that’s not actually important.
jimjamFree MemberNorthwind – Member
Yes I agree, and that’s why debating it is futile. It’s like someone saying “Jesus walking on water is proof he was the son of god” and you start arguing about the surface tension of water or the buoyancy of Jesus’ sandals….no prove that god exists first.
If a secret army of invisible demolition specialists rigged the twin towers to blow up then why not just drive a lorry into it and then detonate the whole thing and claim Al Queda did it ❓
Why the elaborate rouse with Saudi nationals training in Afghanistan, then getting their pilots license then hijaking planes and flying them into buildings, and of course non of that happened because they were radio controlled planes, which were actually missiles designed to look like………gaaaaaaa
People like to think they can peak behind the curtain and see secret hidden details we are blind to. They are Rowdy Roddy Piper in “They Live”. We are blind and we won’t put on the damned glasses.
TurnerGuyFree MemberTurnerGuy, If you want people to think you’re an idiot, just say you like Donald Trump. Saves all that nonsense you posted.
I only really said the documentary was compelling – not true.
It presented their points is a quite compelling manner, which I thought was quite impressive, considering that if you look their web site it is the usual type of mess that is on most conspiricy sites.
I thought the Sand Wars documentary, which was not a conpsiracy theory, was really good and compelling, and posted about that as well.
Most of the argument on the 9/11 documentary was about WTC 7 and how it came down, and it does look like that warrants more investigation.
Even if it was all a planned job, with controlled explosions, then why bother at all with WTC 7, not sure I see any point in that as the twin towers were the ‘main show’ and bringing down WTC 7 just opens the door wider to the conspiracy theorists.
CountZeroFull MemberThose who think it’s a government conspiracy keep ignoring those who point out that nobody has leaked the smallest factual detail, and are also ignoring all of the info that’s being leaked by Snowden into Wikileaks, and Shadow Brokers, the hacker group who have access to hacking tools developed and leaked from the NSA and other tools from the FBI, which would, you’d think, mean any files pertaining to 9/11 would be fair game; except nothing has been released, probably because there’s no sodding conspiracy!
https://www.nytimes.com/2017/11/12/us/nsa-shadow-brokers.htmlMost of the argument on the 9/11 documentary was about WTC 7 and how it came down, and it does look like that warrants more investigation.
I’ve already posted up a link to a programme that explores Tower 7, please try reading it, then you might learn the facts behind what happened, instead of behaving like Jivebunnies Mini-me!
dissonanceFull MemberThose who think it’s a government conspiracy keep ignoring those who point out that nobody has leaked the smallest factual detail
There have been some fairly successful secret projects in the past.
Bletchley park managed for many years post war(as an aside one reason it was kept secret was the allies generously sold a bunch of enigma machines after the war to various governments so they could have “secure” communications).
Manhattan project was fairly secret despite its size with most people not knowing what they were actually working on. Although of course in that case the foreign government infiltration might have proved inconvenient.So whilst I think the government conspiracy line is rubbish it is conceivable that for some variations of the theories where the number involved are fairly low it could be kept secret. Of course once it gets to the ones where random police officers, firemen and bbc reporters are in on it does seem rather hopeful.
nealgloverFree MemberSo whilst I think the government conspiracy line is rubbish it is conceivable that for some variations of the theories where the number involved are fairly low it could be kept secret.
Granted, The “whistleblower test” isn’t enough to entirely rule it out in all scenarios.
But when you mix in actual science, rather than the made up version, and real facts rather than the shite normally peddled by truthers.
You really do need to almost brain dead to believe any of it 😉
pondoFull MemberWhy do I not use tea bags to hammer in nails?
Do you have a figure in mind for the number of times you’re going to raise this point and ignore the responses explaining your logic fail? 🙂
bailsFull MemberWhy do I not use tea bags to hammer in nails?
Presumably he thinks this was the work of the big-hobbyist illuminati because the first domino should have stopped when it fell and landed on another.
Three_FishFree Memberlets get it moving by say 1/2m the gap it fall through when it started to fall.
PEi=mgh
Plug in the original mass, having now moved a single floor (2 metres) and its 4 times as much energy as we had in the beginning..You’re overlooking the unavoidable resistance that the lower, undamaged portion of the structure provides. There must be a deceleration as each new layer is reached, no matter what the condition of that layer is. The Law of Conservation of Momentum states that the total momentum of a closed system – which is what each tower (and WTC7) were – does not change. So, whatever the momentum of the upper 15% ( for arguments sake) the momentum of the lower 85% is 0 (zero); therefore unless additional energy is introduced to accelerate the upper portion, which is essentially what it is being claimed the upper portion did, Newton’s Third Law dictates that any damage (distortion) that occurs to the lower portion as a result of the impact of the upper portion will also occur in the upper portion. Kinetic energy is absorbed by both portions until they gradually (a relative term) come to a halt after roughly the equivalent mass of the upper portion has been distorted in the the lower portion. For all intents and purposes, the structure of the upper portion and the lower portion are identical, so the example is even easier to consider than if the upper portion had a greater mass, in which case it might have travelled further into the lower portion before coming to a halt. It’s remarkably easy to test and observe for ones self – go and drop a breeze block onto a breeze block, snowball onto snowball, or pumpkin ont pumpkin – whatever you like and however many times you do it, I guarantee that at no point will the dropped object accelerate through the static object beyond its equivalent mass.
It’s fundamental, foundation physics. Uncomfortable, I know, but physics says that all three buildings were demolished. I’ve absolutely no idea by whom, though looking at who profited (considerably) might shed some light.
JunkyardFree Memberphysics says that all three buildings were demolished
Nothing you said whether true or false proves that hypothesis
Is the pyramid above a controlled explosion as well?
neilwheelFree MemberIt’s fundamental, foundation physics.
Seriously? You need to go back to school.
GreybeardFree MemberI did promise myself not to get involved but…
No, they weren’t closed, they were attached to the earth.
Acceleration is the result of applied force, not energy. In this case, gravity.
Try dropping a raw egg onto a raw egg. The structure below was not strong enough to withstand the force necessary to decelerate falling part above. Specifically, the outer columns buckled at the joints; you can see that on the videos, just below the dust cloud.
maxtorqueFull MemberThree_Fish, i guess being a conspiracy theorist also limits you ability to read?
I explained, in some detail, about 4 pages ago how the structure of the WTC, which differs markedly from most lowrise steel framed buildings results in the floors pancaking very easily compared to a high mass, cross braced steel or concrete building.
Go back and read it.
What is also notable is how many of these nutters happily say things like “Newtons 3rd Law” and then go on to demostrate they haven’t got a fricking clue what Newtons 3rd Law actually means in terms of physics!
for example:
“Newton’s Third Law dictates that any damage (distortion) that occurs to the lower portion as a result of the impact of the upper portion will also occur in the upper portion”
er, no. no it doesn’t! Here is Newtons actual 3rd law:
It says nothing about damage, and nothing about accelerations (that’s his 2nd law f=ma)
maxtorqueFull MemberIt should also be noted that i (correctly) used Newtons 2nd law about 4 pages ago so simply demonstrate that for the collapsing build to exceed 1g, it would have to experience a net downward force, and due to the buildings huge mass, to make even a noticeable difference to the accelerations, that force would require something like 15 Saturn 5 moon rockets all firing downwards simultaneously in order to be applied.
Now, as we didn’t see 15 Saturn 5 moon rockets firing the building downwards into the ground, i think we can safely say your theories are complete twaddle eh…..
maxtorqueFull Memberdissonance
The Manhattan project was fairly secreter, nope, not even slightly secret it turns out!
More moles than the average school footy pitch 😉
I recommend reading Richard Rhodes seminal work on the development of the atomic bomb:
(838 pages of rigorously researched, cross referenced and often first hand information on the project)
Three_FishFree MemberIs the pyramid above a controlled explosion as well?
Does it look like a controlled explosion? Would it require a controlled explosion to make 000s of unconnected blocks collapse into a pile? Would the same thing happen if all the blocks were glued to their adjacent blocks?
You mean the lower structure was unable to provide any resistance? None at all? And yet the upper part was strong enough to withstand (resist) the force that destroyed the (structurally identical) lower part?
cheekyboyFree MemberI explained, in some detail, about 4 pages ago how the structure of the WTC, which differs markedly from most lowrise steel framed buildings results in the floors pancaking very easily compared to a high mass, cross braced steel or concrete building.
No you havent actually explained anything …..Go back and read it.
Are you aware of how the 2 towers were actually constructed,
If you buy into the pancake theory of collapse why did the cores not remain in situ ????
JunkyardFree Memberit really is pointless I have more chance of persuading the pope there is no god as his belief is more rational than this guff
cheekyboyFree Memberit really is pointless I have more chance of persuading the pope there is no god as his belief is more rational than this guff
Why does it always have to be about you ?
JunkyardFree MemberIt was about me , some folk on here and the pope – Not sure how you missed that as normally you have such a great understanding of things 😉
The topic ‘9/11 documentary’ is closed to new replies.
