Home Forums Bike Forum Wolf Tooth light action remote for Hope Tech 3 levers
Viewing 9 posts - 1 through 9 (of 9 total)
  • Wolf Tooth light action remote for Hope Tech 3 levers
  • Weasel
    While I am going to change the cable on my dropper, I’ve looked at other levers to replace the rattly stock Race Face one.
    Wolf Tooth have a Hope version for the type 1 Tech 3 levers but for the life of me cant see how it fits, or what to.
    There’s no tech doc on the Wolf Tooth website, but of course a simple email to them would probably get one. Or just go the standard light action lever on a bracket..
    honourablegeorge
    Hooe Tech 3 levers have a hole underneath to accommodate Shimano I-spec shifters, it connects to that.
    Weasel
    Perfect thank you
    kane
    I’ve been using a wolftooth remote with tech 3 levers for a while. I don’t know of the design has changed but mine didn’t work without some mods. The remote came with a 4 mm bolt and an aluminium square nut that fits behind the lever clamp. This required a bit of filing to make it fit well and have a solid connection for the dropper lever. Later I stripped that in a crash and replaced it with a hope square nut. These take 5 mm bolts and so I had to drill out the the hole on the dropper lever to allow a 5 mm rotor bolt to fit. Great dropper lever once it’s attached though.
    nixie
    Mine was simple to fit. You don’t need all the bits the ispec version comes with.
    Weasel
    I couldn’t find the Hope version in stock anywhere so went with the standard clamp. I’m sure someone will now say they’ve got a Hope one for sale..
    nixie
    If it bugs you long term you can always replace the clamp part at a later date.
    greeny30
    Has anyone attached a reverb remote or other sram style fitment remote using Hope’s clamp for their duo lever on a tech3 lever, looks a lot neater than their other option and comes in colour options.
    benpinnick
    Not sure anyone will agree with you that the duo option looks neater than the bolt on one.
The topic ‘Wolf Tooth light action remote for Hope Tech 3 levers’ is closed to new replies.
