Epoxy doesn’t stick well to alu. Don’t know about anodised finishes.
Nothing really sticks well to ally unless it’s prepared in a specific way.
Not entirely correct chaps 😉
Epoxy glues are widely used to bond aluminum to aluminum and many other things.
why not try araldite 2014?
Araldite® 2014 is a high-strength epoxy adhesive paste that cures at room-temperature. Demonstrating superior environmental and chemical resistance, it is ideal for applications where elevated temperatures are likely to be encountered and is commonly used to bond metals, electronic components and GRP (Glass Reinforced Plastic) structures. It bonds metals, including steel, stainless steel, aluminum, brass, and copper as well as wood and polycarbonate among many others. It offers a high resistance to wear and weather, excellent chemical resistance, and low shrinkage. Thoroughly clean and degrease items to be repaired to remove all oil, grease, or dirt. Araldite 2014 is compatible with standard paints and coatings.
Hope this helps, in my experience it has been super strong and will probably be perfect for your application.
