Home Forums Bike Forum Which cranks are people running in 1×9 and 1×10 configuration
Viewing 7 posts - 1 through 7 (of 7 total)
  • Which cranks are people running in 1×9 and 1×10 configuration
  • emmodd
    Thinking about running a 9 or 10 speed configuration but unsure what cranks to go for. Can you guys let me know what you are running or recommend?
    Thanks.
    brakes
    Shimano XT, for no other reason than that’s what I had
    seem to work fine, but then why wouldn’t they?
    ChunkyMTB
    XT and deore
    davidtaylforth
    I have some old shimano hones that work well.
    Northwind
    SLX on mine, looks slightly odd but works perfectly.
    ajantom
    Middleburn with an Uno ring is the neatest solution.
    5lab
    whatever you have kicking around?
    Currently run Saint and Truavtiv FireX, have run XTR in the past. If your bashing into rocks with your bashguard the spider may not take the load on a really skinny crank, but otherwise should be fine
The topic ‘Which cranks are people running in 1×9 and 1×10 configuration’ is closed to new replies.
