Home Forums Chat Forum WCA Shed Thread
Viewing 40 posts - 81 through 120 (of 178 total)
  • WCA Shed Thread
  • jota180
    5thElefant
    jeez, how much did that cost?
    I bet you could build another shed for the price of that. 😯
    WorldClassAccident
    It will be used to run the tub and sauna, both with 32amp rating plus other electrics in the shed. It is over specced so I can use the new consumer unit to run stuff in the garage more safely as the present unit trips quite easy.
    Future proofing and it wasn’t that much more than 16mm which was just about okay for the tub and sauna
    andyl
    why not us a wood burner for the sauna? Doesnt have to be in the room, could be out in the main bit with some pipes and a heat exchanger in the sauna room.
    willard
    That would be the true STW way but, with WCA’s past form, I can only see that ending badly. Mind you, the amount of electricity going down that new cable would lend itself to a pretty scary outcome.
    You are getting someone else to put that it, right?
    WorldClassAccident
    I am getting a qualified and registered sparky to connect the house end, the consumer unit in the garage and the wiring to the isolator switch and the tub.
    Once that is done we get the tub craned over the garage, fitted and commissioned.
    Then I can finally get the rest of the walls and the roof up and make the place water tight.
    Then we can get the rest of the wiring in place.
    So slow at the mo
    Murray
    Make sure you get pictures of the tub being craned over (just not from underneath it 😉
    thestabiliser
    Make sure you get pictures of the tub being craned over christened.
    [Wrong
    Wrong
    Wrong
    Wrong
    Wrong]
    WorldClassAccident
    Not much of an update but a reminder that the shed gets craned over the garage tomorrow which should give some more interesting pictures.
    Anyway, here is the new garage supply leaving the house
    Here it is buried under the garden. The white conduit is for the garden lights that were fitted ages ago. You can’t actually see the cable as it is buried but it does give you the chance to comment on the leaves, uncut grass and unkempt borders
    Here it is coming into the garage and into the new consumer unit
    Out of the garage and to the isolator switches for the tub and sauna. The cable out has been left on the reel so we have lots of spare when the tub is dropped in place
    wwaswas
    I love the label: “New Garage Supply” 🙂
    WorldClassAccident
    Truck turns up
    Tub turns up
    Tub moved to the bottom of the drive ready for lifting
    Reversing the crane onto the drive
    Stabalise the crane and unfurl the arm
    Start lifting the tub before realising someone put one of the straps through the trailer and that was lifting too
    All clear now so up and over
    Crane leaving
    footflaps
    Cool set of photos!
    When do the hookers and coke turn up?
    eddie11
    ‘WCA Headquarters’? 😆
    WorldClassAccident
    WCA Headquarters’ I couldn’t afford a hollowed out volcano
    stumpy01
    Was that driveway designed with getting an HGV down it, in mind?!
    scaled
    that sequence makes it look like you’ve had to bend the lamp post and gatepost 😀
    AlexSimon
    wow
    WCA doesn’t disappoint!
    drlex
    Another +1 for the WCA signage.
    (Also: professional driver/crane-ists earn their money.)
    nbt
    DT78
    Impressive skills by that driver
    boblo
    I’m sure the neighbours will be delighted when Dirk Diggler and his chums turn up for the opening ceremony 🙂
    bland
    Are the Kegs of beer for the coke and hookers party? when do we get our invite?
    footflaps
    I can sell you front row tickets for £250 + £60 booking fee.
    Paypal gift only.
    WorldClassAccident
    Work meant I didn’t get started on the shed structure until later than I wanted. I was happily working away when it started to rain. It was only when I got the tarpaulin over I realised it had gone all dark and it was time for beer.
    Hot tub in place with the cover over. Side wall now in place and large gap on the left where the sliding door will go
    Sauna in structure is good to go. Roof is deliberately lower than the main shed to intensify the heat inside.
    All wrapped up for the night (who ordered the wrong size tarp?)
    Russell96
    Finally dawned on me its a cunning plan to correct the errors made in youth.
    WorldClassAccident
    What did you do when you finished work today?
    I noggin’d my shed roof
    I have never made errors.
    What has happened to me is a conspiracy by the Gods!
    piedidiformaggio
    Any update for the weekend?
    hooli
    Good progress for a evening project.
    andyfla
    I think you probably need to ask Southampton General Hospital that …..
    WorldClassAccident
    Sorry – bit slack on the updates as I have had family down for the weekend. Managed to get the board for the roof down and some of the cladding completed.
    Not sure how one piece of cladding grew between being cut and being fitted but there is a bit of trimming to be done
    The green stuff is vapour wrap to stop the dampness getting in. I will need to fit this to the inside too to stop the steam escaping out.
    You might also notice that the tricky last length of cladding beneath the roof hasn’t yet been fitted. That should be fun as it involves cutting one 4.8 metre and two 3.6 metre pieces of cladding along the length and along the grain and ensuring a flush fit with the roof board.
    The roof board then gets trimmed flush with the cladding and the rubber roof and edging is fitted.
    Hoping to order the double glazed glass units today. Not looking forward to paying for 9 big windows though.
    footflaps
    Borrow a table saw….
    hammyuk
    One here if you need it
    WorldClassAccident
    Just come in for a rest after sawing the long lengths and Now I read this 🙁
    WorldClassAccident
    Rubber roofing material
    Unroll and let it relax for 1/2 an hour
    Water based glue for the middle, evostick stuff for the edges
    Rubber laid and needs the edging fixing
    granny_ring
    Can only admire your speed of work sir, well done.
    How much was the rubber roofing?
    WorldClassAccident
    About 350 for 3.6 by 4.8 roof with all eding and flashine and glue etc
    rubber roof dot com
    Their website is good AT WORKING OUT WHAT YOU NEED. pHONE AND ASK FOR A DISCOUNT. i SAve £60
    granny_ring
    If you can get some pics to show how you’ve gone about doing the edging that would be great ta.
    AlexSimon
    granny_ring – Member
    Indeed – took me months!
    stumpy01
    Cripes! I’d have probably only had the holes dug for the footings by now! Great progress.
    Took me about 6 months of half hearted weekend working to get rid of our pond (half sunken, half raised – about 4x2m in total), fill it in and stick some cheap slabs down to meet the existing patio!
    I had better not show this to the Wife, or it’ll confirm her suspicions that I do things incredibly slowly!
The topic ‘WCA Shed Thread’ is closed to new replies.
