Home Forums Bike Forum Using a smaller disk rotor than suggested in a fork
Viewing 7 posts - 1 through 7 (of 7 total)
  • Using a smaller disk rotor than suggested in a fork
  • mrbigglesworth
    Just putting together a mtb bike for the 9 yo and got the purchasing wrong so got 160mm rotors but the fork says minimum 180.
    I will probably just end up buying the bigger rotor but before I do I was just wondering if the minimum size is typically some kind of geometry limitation or if it is solely weight related guidance. (Revelation 2016 fork).
    If it is weight then obviously my kid is v light compared to an adult and he’s not going to be riding it hard so wondering if could get away with the 160 to start with until he grows a bit more??
    Cheers for thoughts and info in advance!
    scotroutes
    If it’s minimum 180 then the caliper mount is likely not going to allow a 160 rotor
    andrewh
    Something to do with the mounts I think.
    My Rebas and Machette will take a 160 with no adapter, my Maz 66s take a 203 with no adapter.
    I have seen adapters for going bigger but not sure it’s possible to fit one to go smaller.
    [Edit] what he said three seconds earlier
    mashr
    Premier Icon
    scotroutes
    This
    richmtb
    It will be the actual mount. When you attach the brake caliper without any adapters it will fit a 180mm rotor. You can go bigger by adding a +20mm adaptor but you can’t go smaller.
    A lot of forks now have a 180mm rather than 160mm post mount as standard
    mashr
    Dremel make one 😉
    mrbigglesworth
    Cheers for the replies, 180 it is!
The topic ‘Using a smaller disk rotor than suggested in a fork’ is closed to new replies.
