Home Forums Chat Forum Rate my Brickie….
Viewing 40 posts - 521 through 560 (of 749 total)
  • Rate my Brickie….
  • footflaps
    ‘The Mausoleum’
    You jest, but there was an Italian neighbour who sold the house but kept 80% of the garden and then once the new owners had moved in he applied for planning permission for a huge Mausoleum in their garden. Didn’t get approved!
    http://www.telegraph.co.uk/property/3303568/Death-wish-in-suburbia.html
    footflaps
    Roofers will finish this morning – only 18″ of slates to go and the ridge tiles to bed in place:
    [/url]
    4 Dec 2012 08:25[/url] by brf[/url], on Flickr
    [/url]
    Almost there![/url] by brf[/url], on Flickr
    [/url]
    Edge slates[/url] by brf[/url], on Flickr
    Only slight spanner in the works is the back door I bought seems to have been pre-dented:
    [/url]
    Pre-dented door…..[/url] by brf[/url], on Flickr
    I am tempted just to fit it anyway, as it’s just cosmetic….
    granny_ring
    Surely not……
    trail_rat
    Pre bashed in back doors ???
    * someone had to say it
    footflaps
    I know, it just feels dirty…..
    qwerty
    my builds a blur
    2unfit2ride
    Great thread, keep on with the updates.
    Tom-B
    Fix this effing glitch!!.!!!
    pleaderwilliams
    Glitch bump?
    Tom-B
    Max clifford
    footflaps
    Had the first shipment of Celotex this morning:
    [/url]
    Celotex arriving[/url] by brf[/url], on Flickr
    [/url]
    1st shipment of Celotex (38/68 sheets)[/url] by brf[/url], on Flickr
    This is for rafter infill (70mm), line walls with 100mm between pillars and cover the floor (100mm). Walls and rafters then get a 50mm/12.5mm plaster board bonded layer, which arrives next week.
    Should be quite snug by the time all this is installed…..
    kiwijohn
    You’ll never get that lot in a Focus.
    footflaps
    Don’t be silly, we’ve got roof bars! 😉
    wrightyson
    Going over old ground here flaps but what’s stopping the damp coming thro the walls?
    footflaps
    Paint the outside and even if some damp does get through, 100mm of Celotex is impermeable, so it won’t go anywhere.
    The whole inside is drying out quite nicely now the roof is on, even though its been pissing down outside recently.
    boblo
    Nah, he got it from B&Q not Focus… errrrmmm…shuffle, wibble, shuffle…
    matt_outandabout
    Whatever stops damp coming in any solid wall house, of which there are millions in the uk.
    wrightyson
    I’d suggest Matt that there are sod all 4″ construction houses around!
    bigbloke
    We need internal pics now too Flaps please the build needs to move on 🙂
    heckler73
    some amount of money spent on that structure. better built than some houses, must be some bikes in there, did my garage into a gym,workshop sauna years ago, lucky im a carpenter and cost me peanuts, enjoy though the escapism rocks
    andylaightscat
    In sheltered areas 9″ walls are accepted as being weather resistant,
    however as far as I can remember Celotex shouldn’t be applied to 4″ walls
    cotic853
    Went passed on the train today and was pleased to see the roof on – but have you painted the render pink or were my eyes decieved ?
    nealglover
    Never heard that before.
    What’s the reason ?
    maccruiskeen
    not bikes 🙂
    trusslebabes
    I’ve been enjoying following this thread thanks footflaps. I have got planning permission now to pull our old outbuilding down and rebuild it. I am impressed by your roof structure and would like to do something similar, I’m guessing you had a structural engineer to work out size of rsj and do you have any cross beams to make it like an A frame or don’t you need any?
    Thanks and keep pics coming
    footflaps
    Errr yes. But we can’t see the painted sides. We had a sunny weekend, so nipped round to Ridgeons and the trade masonry paint had either Black, White, Grey or something called Suffolk – so we went for that. Turns out it’s Suffolk Pink – we were quite surprised. NB Trade paint tins are all just white with a name on….
    footflaps
    Pretty much all Victorian houses are 9″ walls, and they are everywhere in the UK – make very nice dry houses…..
    Utter nonsense. Cellotex is an polyisocyanurate closed cell foam bonded between two sheets of aluminium. Last time I checked, aluminnum wasn’t water soluble and neither is the foam. As for damp pouring through 4″ of concrete, we’re having a rather wet autumn right now, and I’ve got a very dry workshop shell…..
    It’s even more nonsense eg when you build a standard cavity wall house, guess what you have in the gap right next to the 4″ wall – a layer of celotex or equivalent….
    JoeG
    A PINK mancave? 😆 😆 😆
    footflaps
    A PINK mancave?
    Er yes… I’ve had quite a lot of stick from the neighbours about it…
    footflaps
    As for progress, I’ve just finished a 14 hour shift fitting the bloody stuff – horrible to work with – fine dust everywhere. I now have the lung function of a squirrel.
    The first phase is 100mm in between the pillars, to make the walls flush. 70mm in between rafters. Then phase 2 is 50mm bonded to 12.5mm plaster board (damp proof board) will go flush over everything. So final depths will be 150mm on 4″ walls. 50mm on pillars. 120mm on the roof and 100mm on the floor.
    [/url]
    8 Dec 2012 17:00[/url] by brf[/url], on Flickr
    [/url]
    [/url]
    8 Dec 2012 14:26[/url] by brf[/url], on Flickr
    [/url]
    8 Dec 2012 19:55[/url] by brf[/url], on Flickr
    althepal
    Jeezo- are you allergic to kryptonite but looking to store your collection somewhere??
    footflaps
    I intend to heat the workshop using a candle, so need to get my U value right down……
    EDIT plus you seal the whole thing up with aluminium tape to stop any drafts between / around the panels – basically the Celotex forms a vapour barrier. By the time it’s done, they’ll be something insane like 400m of tape on there as there are so many panels in the roof…
    letmetalktomark
    Brilliant stuff.
    Will you be doing tours once complete 😀
    Ultimate man cave.
    davidjones15
    The world’s first Passiv Schuppen.
    wrightyson
    I’ve been doing it wrong all these years 🙄
    How you fixing top layer of board flaps? You dabbed the first layer on the walls?
    footflaps
    Top layer will screw through to the rafters. For the walls I’ll bond it to the brick pillars, the piers are 1.7m apart and the boards are 2.4m long. They’ll bow a bit in the middle, if it looks terrible, I’ll just cut out a middle stud, be pretty quick to fit.
    [/url]
    First insulation later complete[/url] by brf[/url], on Flickr
    [/url]
    andylaightscat
    Nealglover,
    manufacturers details apparently,had it pointed out to me by building control surveyor
    matt_outandabout
    Footflaps – Fisher make wall fixing plugs ( Termofix) for insulation boards that are ace. See if you can get a box – they do them in screw in wood, screw into masonry with rawl-plug attached and hammer fix epoxy. Means you should not have any bowing anywhere.
    maccruiskeen
    I think the phrase ‘something insane like’ can be used as a prefix to all your quantities 🙂
The topic ‘Rate my Brickie….’ is closed to new replies.
