For the eagle eyed amongst you, the frame for the Velux isn’t finished as it’s only single timber cross beams, it’s just marked out for size right now.
footflaps, sounds like you’ve enjoyed being so involved with the build
Was that always plan or just ‘cos of the now infamous bricky ?
I was always going to PM the whole thing and do as much as possible DIY, but originally I had expected to do more stuff myself, eg joinery, but it sort of dawned on me that it was a bit larger than I’d realised and so many jobs are better suited to 1.5 men or two men, that it made more sense to hire professionals in, plus I’d quite like to get it finished asap, so I can do the fit out.
50 mm back door will be a lock formed steel hinge door with two 1.2 mm (18swg) zintec sheet type door with a rebated 3 sided frame, circa $100 from ping pong land. Great door for this application with three point locking in a primer finish. Expect to pay £300 fitted. 900 x 2100 mm standard size. You can get in em with a crow bar if you know what your doing. Easier to drop through the velox though. 😆 ( may have a U value of 1.43 W/m2K)
It is great to see the walls going up on my project that Google/STW have helped out on. The difference between the brickies blocks and my attempt with the retaining wall is pretty stark to say the least!
You could buy a car several really nice bikes for that !
The way I see it, is a small family car costs the same, but you only get 10 years out it, plus massive running costs. This workshop will still be here in 100 years time and will require very little maintenance…..
Their local blocks for local people. made in South Cerney, available nationally, fair faced, costa lotta but leaving as single skin nekkid so no render (except maybe to hide my 4 courses of butt fugly block work).
I’m considering using the length of the wall as a climbing wall for our son.
The weak point of that door is the euro cylinder lock, takes me about 20 seconds, tops, to break into one of those, so I expect scrotes to be off with your bikes in no time at all.
Footflaps its a problem witht the board when threads get to long, the problem on the Rugby threads get people very vexed 😆 it’s better than it used to be but is a pain.
The weak point of that door is the euro cylinder lock, takes me about 20 seconds, tops, to break into one of those.
I’m not too worried about the lock, I can just bolt it from the inside or possibly weld a plate over the external key hole so you can’t access the barrel from outside.
or buy a decent anti snap lock for about £40 and not worry about it?
I’ve looked at these, not really sure how good they are eg Avocet do anti-bump and anti-snap euro locks.
I’m not sure the one that comes with the door is a standard Euro lock as it has two installer keys which only work until a ‘standard’ key is used, at which point the installer keys no longer work – not seen that before.
14 pages and no one’s asked if Mrs flaps seemed unduly upset by him leaving?
I once saw a house where the man cave was built by a guy who owned a building reclamation yard. It was a miiturised church complete with stained glass windows, solid oak door, gargoyles, the lot! I did wonder if the workbench was an altar.
After everything else it’d nice to see you managed to get a good joiner! Nice few bits of attention to detail, nicely trimmed out for the velux’s etc! Onwards!
Cheers wrightyson, good to know he’s done a good job!
I’ve often wondered why designers use steel at the ridge, if you thini about it it could be a thin pice of board really (The two sides/ pitches of a properly designed roof should balance out hence no steel required)
Steel ridge the garage is no bad thing . Some where to anchor the block and tackle 🙂 – just lifted an old boiler into my van on my jack jones and regret it ….. Wish i had an aframe sometimes.
