Home Forums Bike Forum nukeproof dropper post
Viewing 17 posts - 1 through 17 (of 17 total)
  • nukeproof dropper post
  • poe82
    So did I just blink and miss this? Anybody know anything about it? Credible alternative?
    cdoc
    First I have heard of it!
    Just had a look and not much info about..
    cooie
    Was just about to post that.Odd that a product coming out next month has nothing online apart from Facebook!
    Nobeerinthefridge
    Looks tidy, good to have more choice.
    pedlad
    From that picture it looks like the hydronic hose connects at the seat post clamp end not the top seat end?
    So like a ks lev rather than a loop of cable you get with a reverb?
    cooie
    Cable operated?
    cookeaa
    hydronic hose…
    Is that what the kids are calling a really obvious cable these days?
    cooie
    Disappointing, as it says hydraulic control in the MBR piece.
    Northwind
    I think they’re saying the movement is hydraulic- so cable op but hydraulic post. Seems very much like a copy of the older KS designs really but that’s no bad thing
    remoterob
    Isn’t most of Nukeproof’s stuff from other companies? Is this a whole new design?
    pedlad
    Ah hadn’t seen that photo. Spelling not my strong suit 😳
    That cable is so exposed to crap so I’m out I think. I think cable makes sense in a stealth post but the only one I can find is the ks lev which is v expensive and had mixed reviews. Anyone know of any others?
    breadcrumb
    Only available in 31.6 too.
    hainman
    Looks very similar to my Giant contact seat post
    PrinceJohn
    Looks very reminiscent of the KS as others have said, must admit I baulked at the price when I saw it as MBR was bigging it up as a cheap dropper…
    goingdownhill
    Its a cracking post. I’ve been running it for around a year. Its from a far east manufacturer.
    Its pretty low maintenance but the mechanism at the back of the post that the cable operates is prone to get full of muck which eventually stops the mechanism working, once washed out it works fine again.
    Has slight side to side play in the saddle from new but its minimal. After a year its got a bit worse but no worse than the play that develops in a reverb.
    BigDummy
    Thomson are cable-operated. Again, pricey.
    FWIW, the continuous cable run on the non-stealth Thomson really isn’t a significant problem. You’d want to change it as often as you’d change a gear cable, but that’s easy enough.
    Speeder
    Why even bother with this version at this stage in dropper post development? The cable should be stealth or at worst fixed.
    Price will be ok once it’s discounted but the RRP is more than I paid for my Reverb.
    IMHO
The topic ‘nukeproof dropper post’ is closed to new replies.
