Home Forums Bike Forum Let's see your 29+/650B+ & other "Nearly-Fat" Bikes
Viewing 40 posts - 81 through 120 (of 156 total)
  • Let's see your 29+/650B+ & other "Nearly-Fat" Bikes
  • ajantom
    Here’s the new set up…
    [/url]
    The Alfine was faultless, easiest set up of any gear system I’ve used! Fit the wheel, hook up cable and take up any slack with the barrel adjuster. Easy peasy 🙂
    I used a Paccenti DL31 rim (currently £40 at On-One), Sapim spokes, and used a 2 cross pattern due to the large flanges. The Knard went on the 31mm rim easily. I know Surly say a minimum of 35mm, but I didn’t have any issues at my normal pressure of about 15 psi. If anything the fact it made the tyre profile rounder meant that it cut through the slop a bit better.
    Paceman
    Lovin’ the Stooge with the fatty up front Kbrembo. The trail look great too, where is it?
    spectabilis
    ajantom.
    Alfine sounds great hope it holds up well.
    I’ll consider building one onto a 650b rim for the rear end of my Stooge in the near future.
    Paceman
    Maxxis Chronicle users, what tyre pressures are you running?
    rosscopeco
    ir_bandito – Member
    on one carbon forks which have ‘just’ enough room
    Which forks? 29er or Fatty?
    I’m running the on one monocoque fork with a Dually rim and there’s maybe 4-5mm each side to spare. It clogs a bit now that the mud fest is here but I’m not too bothered by that. The Chronicle should be here by the end of the week so the fingers are still crossed. In an ideal world I’d maybe go for their new FAT fork or if money was flush I’d go for the Niner ROS9 carbon fork which I believe has a little more room to play with.
    It’s a third hand ‘hand-me-down’ Knard so it’s balder than Kojack! As such it’s not the most confidence inspiring when in deep mud but then again I’m struggling to think of a tyre that is. On wet roots / rocks I’ve not had anything that rattled me too much. If it does slip on something then you’re usually over the obstacle and onto firmer ground by the time your sphincter starts twitching.
    Chainline
    Anyone actually put a 650b+ Trailblazer in a Ti Spaceframe? I dont know if the (pre 2014/15) Steel is the same clearance as the Ti spaceframe but I’d like to put a b+ tyre in there. On paper it looks like yes, I just wondered if anyone has tried it?
    cokie
    trollbikemike
    jameso
    Chainline – how’s that? DrJon’s bike, pic from his flickr page. I’ve offered the Trailblazer on a Scraper rim up to my spaceframe and there’s enough room. Some pics of a SF with them fitted F+R on MTBR also.
    Paceman
    seanthesheap
    Jones steel spaceframe 29plus front wheel.
    BIGMAN
    I want to fit a Knard on Crest to my Singular Swift (old blue one). Clearance looks tight! Has anyone tried this?
    Clobber
    I don’t think a knard on a crest is a good idea, flow-ex width seems to be about minimum for a knard.
    Spacewise in the fork I also think it would struggle.
    Sam had some 29+ forks knocking about, email him to see if he has any left.
    Paceman
    You need at least 25mm internal rim width really to get the most out of 29+ tyres, ideally 35mm or more.
    You might get away with the fork clearance, or if not most of the newer rigid forks coming out are now 29+ friendly. A Knard on a 50mm rim fitted no problem on the front of my old Charge Cooker rigid…
    bigdugsbaws
    Anyone got a full fat front on their Krampus, was pondering this option whilst out in the snow the other day?
    Paceman
    It’s an interesting idea Bigdugsbaws. I know a local guy who runs a fat front on a Jones Spaceframe and it certainly doesn’t slow him down 😀
    coastkid
    Sold on the Grey Karate Monkey frame set, bought a used Pugsley frame set, offset the Krampus wheel set adding a 135mm Surly hub up front, an On One 100mm square taper BB, and now running 2.5 Minions both ends with HUGE mud clearance until i get another pair of 3″ 29+ skins, and i can also add 4″ fat wheels when needed 🙂
    17th Jan 023 by coastkid71[/url], on Flickr
    17th Jan 024 by coastkid71[/url], on Flickr
    17th Jan 025 by coastkid71[/url], on Flickr
    17th Jan 026 by coastkid71[/url], on Flickr
    17th Jan 020 by coastkid71[/url], on Flickr
    Mal-ec
    Mo Stooge. Widelightning rims, Chronicle front Ardent back. Ace.
    takisawa2
    Anyone fitted a 2.3/2.4 “normal” tyre on a Dually rim…
    Ardent/ Ralph/Nic/Dampf
    Keen to know if they get any wider or just flatter.
    Early days, but anyone looked at 650b+ yet ?
    Paceman
    Very nice ride Mal-ec 😀
    takisawa2 – Member
    They come up wider with a full profile (see the rear tyre on Mal-ec’s phot above). They lack the volume and floaty feel of proper 3″ 29+ tyres though.
    singlespeedstu
    2.4 Ardent on a 50mm rim on the rear of this.
    Comes up much bigger than it did on a Flow.
    20140420_122631 by multispeedstu[/url], on Flickr
    How many different sizes. by multispeedstu[/url], on Flickr
    whitestone
    Interesting to see that (nearly) all these steel frames are running 1x drivetrains. To my eye having a single chainring just looks right on a steel frame, elegant even.
    shedbrewed
    Just going to leave this here…
    24×3 up front.
    letmetalktomark
    Also just going to park this here:
    29er Inbred, 80mm Reba 29er fork, 26×3 upfront
    whitestone
    There’s always someone … 🙄
    letmetalktomark
    24+ & 26+ shouldn’t be excluded.
    This is a friendly inclusive forum 😉
    shedbrewed
    I can feel your love
    letmetalktomark
    Paceman
    24+ and 26+ are very welcome, it’s all about tyre girth not diameter 😆
    BillOddie
    This may or may not be of interest but I converted my Dually/Maxxis Chronicle set up to tubeless last night.
    Very easy, track pump, 2 wraps of gorilla tape, bit of sealant and they went up first time.
    cupra
    Somewhat annoyingly I think this will be up for sale shortly 🙁
    pinetree
    Does anyone still use 26+? What’s the general consensus?
    I’ve been in Southern Bavaria the past few days, and on Tuesday borrowed a fat bike and went for a ride with a mate in the proper deep snow.
    Being a bit critical of them, I was really hoping not to like it…
    …but…
    It was a lot of fun, but we were riding down the side of a mountain on a trail which was up to my knees in powder. That doesn’t happen often if you live in SW England like I do, so I certainly wouldn’t have a full fatty. It got me thinking though… I have access to a 650b frame with sliding dropouts, which can also accommodate a 29″ wheel, would a 26+ fit?
    The following day I was chatting to a dude who had such a set of wheels (26″, 50mm rim, and 2.8″ tyre) so we tried it, and it fitted with bags of room to spare. Could possibly even go 3″ wide.
    I was really hoping it wouldn’t fit, so I could put the idea to bed. Now that I know it fits though, I think I’m gonna have to get one…
    mos
    Go on then. Intention is that it will have a Travers Prong fork & LB 38mm carbon rims, but that could be ages away. Here it is prior to me recording my slowest ever time on the climb back home.
    20150301_113243 by marcusandcath[/url], on Flickr
    anotherstan
    any excuse 😳
    Paceman
    ^^^ Now that looks like serious fun ^^^ 😀
    epicyclo
    pinetree – Member
    Does anyone still use 26+? What’s the general consensus?…
    Transforms the feel of a bike like the 1×1 and makes my 29ers redundant.
    Also pretty good in light snow.
    Paceman
    ^^^ Love the paintjob on your Surly 1×1 Epicyclo ^^^ 🙂
    What’s the framebag you’re using?
    AlexSimon
    cupra – 3″ tyres in a Longitude?
    Much clearance?
    epicyclo
    Paceman – Member
    The paint job appeals to the long lost petrolhead in me. 🙂
    Framebag is a cheapie from eBay, about £15. Seems to be holding up ok, and amazingly waterproof. I’ve left the bike out in some howlers and expected to find water in the bag, but no sign of it.
The topic ‘Let's see your 29+/650B+ & other "Nearly-Fat" Bikes’ is closed to new replies.
