Home Forums Bike Forum Help, mixing 9 and 10 speed components
Viewing 6 posts - 1 through 6 (of 6 total)
  • Help, mixing 9 and 10 speed components
  • downhilldave
    Hi all, currently running 9 speed Xtr shifters,front and rear mechs & cassette. Would like to swap to Xtr shadow plus rear mech. If i swap to a 10 speed shifter with the shadow plus is this compatible with my 9 speed crank / cassette / chain /? 😯 Thanks in advance
    Hob-Nob
    In short – no.
    shredder
    My understanding is you would need
    10spd rear shifter
    10spd cass
    10 spd chain
    Can keep
    Front 9 spd shifter
    Front mech
    Current c/set ( but could ultimately change rings to 10 spd if they suit your crank)
    I think above is correct but may be wrong
    njee20
    That’s about the gist of it. You will need chain and cassette as well.
    allmountainventure
    Usually sorted with a bit of filing
    downhilldave
    Cheers guys, thanks for the help. Will have to look at another method to stop noisy chain slap on my 5 Spot
The topic ‘Help, mixing 9 and 10 speed components’ is closed to new replies.
