Home Forums Chat Forum Heating oil – how much!
Viewing 40 posts - 441 through 480 (of 495 total)
  • Heating oil – how much!
  • sharkbait
    * heads off to dip the tank to see how accurate the app is compared to the calculated volume in a partially filled horizontal cylinder!*
    And if anyone is interested its a 225 x 120 (2500L) tank with a current oil depth of 13cm – which seems to be a volume of 149L.
    Take away 2cm for the height of the outlet and the useable oil volume is about 116L
    ….. my app says there should be 119L left.
    Happy with that and knowing exactly how much oil is used every day makes figuring out when to buy much easier.  If I didn’t know my actual daily usage I’d be pooping myself right now.
    blokeuptheroad
    Just ordered 1000 L at 72 ppl, including VAT and delivery. South Shropshire. We checked one of the online price match things but they were no cheaper than the local firm we normally use. Plus we have restricted access and need a smaller tanker, the online place would have charged more for this but the locals do it as a matter of course because they know loads of places round here are tight to get in and out of. Over 10ppl cheaper than our last fill up in the autumn.
    Edit to say, we have a Watchman fitted but I don’t find it that useful. I prefer to eyeball it. It was down to 2 bars and flashing 10 days ago, but an eyeball shows we still have just over 300L left in a 1300L tank.  Enough for a good few week probably.  We get a discount for orders of 1000L or more, so we alway have to judge that there’s enough space in the tank to accommodate that much before delivery.
    Anyone know how I can get a guide to the volume at different dip heights for the tank we’ve got? It’s one of these:
    https://www.kingspan.com/gb/en/products/storage-tanks/oil-storage-tanks/ecosafe-slimline-bunded-oil-tank/?v=1000
    sharkbait
    I use this:
    https://www.omnicalculator.com/construction/tank-volume
    But my tank is not bunded, so you’ll need to contact Kingspan and get the actual internal dimensions.
    If I enter 135 x 45 x 158 I get a total volume of 960L which isn’t going to be too far off.
    gobuchul
    Quoted 53p per litre ex-vat yesterday.
    sharkbait
    I’ve still got about 400L and hardly using any now – 1.7L/day if anything at all recently as the heating is off and the PV does most of not all of the hot water now.
    I’d like to buy 1000L which would probably see us though the next 12 months but I’d actually like to turn the heating up a little next winter, so I may need 1500L.
    I’ll keep an eye on the price but I’m not sure it will drop much more.
    boblo
    I just bought 500L via Boiler Juice for 56.7p/L plus VAT. They were doing a £15 off voucher which negates their service fee. I’ll see how it goes price wise but will probably get another 500L before Winter. Heating is off now so we’ll probably use less than 250L between now and October.
    longdog
    We’re just flashing on the second bar, so planning to fill up (1000l) by the end of the month while the prices seem low.
    longdog
    Just ordered 1000l for £614. Happy with that. We’re only using it for hot water now unless there’s a particularly cold spell.
    trail_rat
    We have been on 2 bars for a month now.
    Heatings set at 10degrees now – has been for 2 weeks.
    I’ll worry about filling up when I get to one bar.
    Hopefully be on solar for hot water before too long as well which should help.
    trail_rat
    Can’t be far off one bar and with Saudi posturing I’ve opted to fill.
    Looked back on my previous sales orders .
    Feb 2021 I bought 1200l for 40p/l
    Feb 2022 I bought 1200l for 64p/l
    It’s now June 2023. I’ve bought 1200l at 58pence with little chance of getting it all in. -1400l tank.
    Good to see the insulation and the smart thermostat system is making at odds.
    steveb
    We have a village syndicate that places a bulk order 3 times a year, I usually partake once a year on the mid-june order. But with the Ukraine situation I decided not to wait and ordered 1000l myself today, £619 inc vat.
    Last 12 months only used about 960l, (4 bed detached), WFH but keeping thermostats at 18. Plus about 3-4 m3 of logs.
    intheborders
    Just ordered 1000l today, the two places that deliver to us are 74.55ppl and 79.08ppl, inc. VAT.
    Chap said that prices were at a low in June but since then have risen (which is unusual for this time of year).
    thestabiliser
    What are folks thoughts about the oil boiler phase out? There’s no way we could get our house insulated enough to make a ground source heat pump work be looking at 30-40 k for insulation and system. Going to be nursing our green star like a baby panda!
    SSS
    Mines was new in 2021, when the old one broke down
    https://www.telegraph.co.uk/money/net-zero/how-to-sidestep-the-planned-2026-oil-boiler-ban-heat-pump/
    So renew now, and renew sometime in 2030/40. Wait and buy a vegetable oil boiler (see article)
    As to heat pumps. In my house its unlikely to work due to age without need for significalt reinsulation etc.
    I will just keep burning things. In fact i’ll be going out this weekend to cut up some fallen/aged trees to add to my wood pile stock.
    Bear
    A heat pump doesn’t need the house to be insulated, it does need radiators upgrading usually and may be pipework but the only work in a super insulated house is not true.
    Your heat load doesn’t alter just because you are using a heat pump.
    Daffy
    No, but to work efficiently without consuming a huge amount of electricity, good insulation is required.  If you have anything less than 12mm pipework, you need a replumb.  We were quoted £8k for the replumb, £4k for the required tank and £9k for the heatpump.  None of that includes insulation, new rads or UF heating.  Even after the government grant we’d be looking at £25k and then the cost to relay all the flooring and redecorate.
    trail_rat
    Rare that I’ve called It but with all the OPEC postulating it was in the post really.
    FunkyDunc
    What will the domestic gas boiler ban in 2025 mean for me?
    Under the government’s current plans, there’s a gas and oil boiler ban in newbuild homes only from 2025.
    Ministry of Housing, Communities & Local Government tells us there are about 25 million homes in the UK – and we build about 160,000 new ones each year according to the National House-Building Council. As such, it’s likely to be many years before a new build gas boiler ban alone has a big impact on greenhouse gases. And some environmental groups argue that the government needs to go further, much sooner.
    Will the gas boiler ban apply to my home?
    If you’re worried about having to ditch your existing oil or gas boiler – don’t be. The gas and oil banner ban in 2025 only applies to newbuild properties. There are no plans to phase out gas boilers in existing homes.
    That said, the government may encourage more of us to ditch gas in favour of alternatives. Using grants or incentives for insulating our homes or installing low-carbon heating.
    I am hoping this is correct on EDF’s website. It does make logical sense to apply to new build homes as they can be built with proper insulation and provision
    intheborders
    This applies to ANY heating/cooling system…
    trail_rat
    There are far far too many folk in places where ashp is not viable for them to stop.
    Wonder what size of Genny you’d need when the Lecky went down our on’t moors to feed your ashp.
    steveb
    Oh, I feel quite smug now having bought a year’s supply in early June. I just order from local supplier, only 3/4 mile down the road.
    Bear
    IntheBorders  has it correct, if you haven’t got good insulation then you will consume a lot of whichever fuel you are using.
    The problem with heat pumps in poorly insulated houses is the amount / size of radiators that are required, and this is where the whole myth starts as I suspect not enough design is done or corners are cut as the install becomes expensive due to the work required to get the system to work on low flow temps.
    if your load is 20kW that doesn’t change, what changes is the how to deliver that with low flow temps, without getting that bit right an ASHP will be expensive. If you get that right and understand how to use it then it will be similar in running costs to natural gas.
    trail_rat
    Just highlighting the key issue there.
    trail_rat
    That time of the year again
    Tanks approaching empty – watchman’s flashing.
    1400l or so since June with an under 1 and a full time occupied house this winter.
    66pence/l at my local supplier Vs 77pence cheapest on boiler juice.
    longdog
    We got 1150l the other week. I think it was 74p/l from Carnegie’s.
    It’ll last us just about a year.
    Daffy
    63ppl down here in the Cotswolds at the moment. Seems about right given the oil barrel price.
    intheborders
    We paid 0.69p in December, Scottish Borders – half way through the tank at the mo.
    expatscot
    63.5p on 4th Dec then 66p at end Jan.
    North Yorks.
    Need another 500l in about a month.
    TheBrick
    I bet that 11p is close to their margin. Lots of these portals have a pretty big margin somewhere along the line.
    Watty
    At just over half pence a litre that’s incredibly cheap 😉
    I was quoted 66p a litre yesterday which is nearly a hundred times more 😢
    intheborders
    #smartar5e 🙂
    Watty
    😁 Apologies.
    FunkyDunc
    So thinking now would be a good time to get the tank filled, even though in reality it’s not fully empty
    Prices are currently as low as they have been but can’t see that staying there long with what’s going on in the world
    trail_rat
    Agreed but I still have 7bars in a 1400l tank so somewhat pointless.
    Social media trying to stir up a fuel shortage at the moment also it seems.
    Hopefully by the end of the day my solar thermal will be commissioned just in time for winter…..but with that comes electric hot water…. That’ll mean I should reach this point next year with 10 bars of oil…..all three/four bars of use this year have been hot water.
    Jordan
    Luckily just ordered a fill up two days ago.
    duncancallum
    Market is up 3p and theres a lot of demand currently.
    It’s still not badly priced but the threatening of bombing irans oil industry is causing a spike
    FunkyDunc
    Just ordered ours at 55p ltr.
    Its showing 4 bars on a 1400ltr tank so I bet that is only about 700ltrs to fill it
    gobuchul
    Gauge showing 700 litres, on a 1000 litre tank, so it looks that I will be filling at the worst time.
    It won’t be enough to see me through until the spring but I can’t order a top up until I’m down to 500 litres.
    sharkbait
    I’d say definitely if you can.  I put 1500L in 2 weeks ago [enough to see us through until spring hopefully] but that was only because my calcs said I only had 25L left!!  I suspect the price is going to go up a bit over the next couple of weeks and then stay there for a while.
    My boiler has been using approx 3.5L of oil to heat a 250L megaflo – but obvs that is dependent upon how hot the water was before the burn started.
