pics of the light… this is Mark 2..!
[/url]
[/url]
[/url]
not the prettiest of things.. reminds me of Number 5 from Short circuit..
It was going to have a piece of plastic or something in front of the clear perspex front to make the front look neater but found they interfered with the beam when next to the reflectors..
shifted the heatsink upwards in the case too to the top as when the LEDS where at the bottom the bottom of the case it cut off part of the beam and stopped the light shining downwards to where the front wheel is..
oh.. and if you do use one of the oval / laura type optics they are about 2mm shorter than a regina reflector… so i cut a square of aluminium to put behind the LED and space it to the same level at the front. So as not to block the periphery of the oval beam being blocked by the Regina’s either side..
will take some beamshots tomorrow night and post them on here if i remember! 8)
and yes there is a minimum order of £20 at Farnell..
its pretty near to where My other half lives in Leeds though so i might pop in over the weekend as ive seen big billboards advertising a trade counter and see if i can pick up some of the new Laura Optics and see if they are any better..
