Home Forums Bike Forum Crown race stuck on carbon steerer, any tips.
Viewing 11 posts - 1 through 11 (of 11 total)
  • Crown race stuck on carbon steerer, any tips.
  • scruff
    Been on there since new so at least 10 months, currently soaking with gt85. Very small gap all way round can just get electrical screwdriver in but its not budging. No larger gaps to get proper whacker in. Any tips?
    BearBack
    de tuned chisel or
    spread the load
    parkesie
    Proper crown race remover
    johnikgriff
    ^^^^ this
    johnikgriff
    You can borrow mine if your close😉
    Or LBS
    scotroutes
    Apply some heat to it. Boiling water ought to do it. That should expand the “crown race” enough to loosen it off. I use that technique when fitting it too. Makes it much easier to slip it on.
    I also cut my “crown races” to remove this problem permanently.
    fooman
    You can use a blade like on a leatherman (or one of your best kitchen knives!) go round the race with the sharp edge tapping it in with a small hammer, that’ll get it moving, then hide the knife in the bottom of the cutlery drawer.
    stoddys
    I tried the leather an approach before but gave up.
    went to my local garage and used their bearing puller thing, did the job nicely.
    trail_rat
    A knife edge puller is the tool for the job.
    ransos
    I got one off by hammering a Stanley blade into the gap. That was a steel steerer though.
    granny_ring
    Use a proper race remover as it’ll be even pressure. I’ve got the Icetoolz one, I would link it but thanks to the poxy forum at the moment there are no link buttons I can use….around £25 anyway.
The topic ‘Crown race stuck on carbon steerer, any tips.’ is closed to new replies.
