What happens if I change forks on a bike with integrated deflopilator equipped bike?
I’m guessing it’s built into a headset component somehow, like a steerer spacer that extends through the bearing? So dropping the forks out would be relatively simple?
A mate had a Hopey steering damper BITD.
It was very difficult to ride no handed with it.
I still think it’s not a damper. but the problem trying to ride no handed would be the same.
A damper holds the wheel straight when you get pinged by a rock at speed which might be enough to knacker your wrist in a 4×4. Or to dampen oscillations on motorbike, all bikes oscillate, it’s mostly how they stay upright, but a 200kg motorbike is harder to control them than a 10kg MTB if they build up rather than dampen down.
I imagine that in terms of ride it will feel at most times like a bike with more trail, that is a bike with a shorter offset fork, but without the wheel flop issues.
That’s what I was thinking. In my mind it’s not a problem that needs solving, but it could be the innovation that allows something else (either zero offset forks, or massive offset I couldn’t quite decide). This + more inherent ‘flop’ probably allows some other part of the geometry to be changed for the better which would be the real reason to do it.
