Does anyone know how to service the bearings
on a Planet X super light hub, Getting the freehub body off,axel out etc.
Cheers, Jim.
Just found this in the Search, anybody care to enlighten me and Jim??
Andy
cassette off.
take the end cap off ( one grub screw, 2mm or 2.5mm key ). other end slides off IIRC. support the hub and bang the axle out the NDS, then using 12mm allen key in a vice, or with long bar and someone holding the wheel, undo the freehub body.
new freehub body is the same as the dmr one. look on crc - i put a review up with some details. the bearings are 6000 2rs IIRC. you'll find these online for about 2 quid or 2.50. use the axle to bang out the other bearing on the hub. the freehub doesn't come with a bearing IIRC ( but it's the same as the hub ones ).
HTH.
Thanks Del!!
