Home Forums Bike Forum Yeti 575 – Differences between models/years?
Viewing 5 posts - 1 through 5 (of 5 total)
  • Yeti 575 – Differences between models/years?
  • IsaacClarke
    Had a trawl on web, and looked at owners' manuals, but help from the STW thinktank would be great…
    I know the 05/06 share the same manual, and the 07 has its own, so must be slightly diff…
    Ta – Rick
    tog575
    It may be that the later ones were designed for longer forks but try yetifan,
    charliemort
    Early ones had the hole in the frame knuckle thingumy
    newer ones redesigned with slight changes in geometry to take longer forks, supposed to be stiffer, hydro-formed top tube a la Nomad, no knuckle joint
    peakmonster
    The early manual had the set up info for the 2004 to 2006 rear shock package with either the 5th element(model year 2004/2005) or RP3 shock (2005 on).
    2007 they removed the earlier info for the rear shocks and included the RP23 information only, if i remeber correctly.
    8)
    peakmonster
    Frames are all the same for all model years 2004 -2007 but options of semi carbon rear was introduced as option in 2006
    you can find more info on the yetifan forum
    http://www.yetifan.com/
The topic ‘Yeti 575 – Differences between models/years?’ is closed to new replies.
