Wood flooring insul...
Singletrack's forums are sponsored by...
Forum sponsored by Saracen
Wood flooring insulating underlay
3 Users
1 Reactions
Offline  scruff9252
Share this post
We’re midway through doing a full downstairs Renovation just now - removing wall between kitchen / dining room, new kitchen, new fire the works.
We’re now choosing the flooring - 14mm thick solid beech is the preferred option. This is to laid over our concrete subfloor. I need a good insulated underlay and looking at xps.
Question becomes what thickness is enough? I don’t want to go too thin and have a cold floor. 5mm / 6mm or 10mm? It’s the whole downstairs so don’t have to worry about height transitions into any other rooms fwiw.
Is there any downside to going 10mm?
thanks.
Posted : 26/01/2025 3:14 pm
kormoran reacted
Offline  ajc
Share this post
When you say 14 mm solid beech is that a thin beech layer on ply? Why xps insulation? Higher performance pir proably a better bet. And at that thickness all you are really doing is taking the edge of chill on the floor. The u value isn’t going to be great. Thickness is down to how tall you are and how near to the door frame you want to be. I assume you realise it will stuff up your stairs and you will be forever tripping on the different height riser as well as it not complying with building regs
Posted : 26/01/2025 3:50 pm
Offline  trail_rat
Share this post
Thicker is better in this scenario but all are doing minimal lifting on a non insulated slab
Posted : 26/01/2025 4:09 pm
Secret Diary Of Benjamin Haworth Age 47 3/4
Last Minute Tuscany
Digital Detox
singletrack issue 159 cover image
Issue 159
