The next thrilling installment follows:
The bolt that wouldn’t undo last night came away fine earlier with a) proper daylight b) a squirt of GT85 and c) a better allen key (ironically from CRC who did get back to me with some suggestions).
I can confirm the the centre fixing bolts do come out of my non-series calipers with some faffing.
I can also confirm that after reassembly it does not work as well as it did previously even though I had an untouched rear caliper as reference (I was pre-warned about this).
I’m surprised how small the bolts are – the rear’s threaded bolt only protrudes out of the back of the caliper body by 13mm and the front is 26mm which threads into a 41mm(!) long mounting bolt which is recessed into the back of the fork.
If I can get a longer mounting bolt I could use 2 x rear 6700 calipers, or still get away with these calipers if the rear bolts are closer to 26mm long rather than 13mm. I think I might even be confusing myself now.
I’m off to investigate 😉
