Nice Peregrine, that’s most welcome here – i used to own one of the early 853 ones but unfortunately it was too big for me.
All white industries build including double/double gearing.
Not done much to my Tripster, still waiting on the cranks but they’ll be here next week so i carried on putting it together.
I had an initial problem with the USB charger headset expander bung (internal 24-26mm) as the Kinesis steerer tube is sized for an internal 22-24mm steerer bung.
So i improvised by using the Kinesis steerer bung and attacked it with the dremel, 10mins later and i had cut enough away to pass the usb charging wires through, i cut a small groove in the bottom plug as well for the wire to the dynamo to pass through.
I wired up the front Schmidt Edelux II light to the hub.
Wired up the rear Son K920 to the front headlight.
And wrapped the Jones Loop bars with Lizard sins tape.
