800 miles in. Lockring came off on a ride over xmas. Tapped up tight with a drift and some loctite.
All the nuts holding the battery tray together rattled lose – fortunately they stayed captive, but bit random,.
Chain is about 60% worn, which is impressive.
However, its knocking – i thought it was the motor moving slightly, but all tight. Turns out its the BB bearings as there is play in the crank.
So need to work out how to replace those, without messing up the torque sensor or the wiring.
