Home Forums Chat Forum Toilet with a powerful flush – recommendations please
  • This topic has 53 replies, 34 voices, and was last updated 1 year ago by Kramer.
Viewing 14 posts - 41 through 54 (of 54 total)
  • Toilet with a powerful flush – recommendations please
  • fossy
    Two 25 year old loos here. Downstairs conventional flush. Upstairs is converted to a soft flush. Existing handle but completely new flush mechanism. Its basically a flap that opens up and the flow is really good. It’s also a soft press on the handle. Brilliant. Hold down for long flush. I’ll look it up.
    Fluid Master Adjusta Flush system.
    chakaping
    I got a “Good Home Winam” rimless bog installed this year (B&Q brand)
    Don’t get one of them.
    gobuchul
    Got to be a Saniflo 33. Now this little babe can cope with anything, and I mean anything
    susepic
    Can you get them to spray GT85 on the sides and surface of the water pre-dump, then the log is lubed as it enters the water, and goes round the bend like a wet otter
    ojom
    Surely you have them prep their hoops with a brush of oil pre motion to coat the forbidden wispa and ease it’s passage to the sea?
    Depending on clubcard deals you should be able to pick up a litre for under a tenner. Personally I’d go with Tesco’s own ‘Light in colour’ olive oil, it’s effective and has a low viscosity.
    matt_outandabout
    I never trust a Saniflo. It is always full of sh*t….
    jamj1974
    Prunes…
    desperatebicycle
    I checked, and no brand names on any of the porcelain. All the cisterns are hidden behind tiled walls too. So I guess they are made to be reliable!
    ratherbeintobago
    Why not a non stick shit pan?
    I’ve heard of people spraying the inside of the bowl with WD40 after cleaning it.
    bowglie
    Hmm..WD40 the bowl….interesting. Y’ know the old ‘what tyres/chain lube for [insert season]’ threads? Maybe we could start a ´what toilet bowl lube/abrasive medium for sticky dumps’ thread? Only of the environmentally friendly sort mind – olive oil is my current fave suggestion 😁
    arnoldm
    Our first house had an outside toilet with a high level cistern, about 8ft above ground with a chain pull. Nothing ever got stuck.
    similar modern bogs (all brass fittings and very designer) are available and our next refurb will have one. All the comments about several flushes rings true in our ‘modern’ water saving facilities..
    captain_bastard
    Instead of spraying the landing strip how about the under carriage? Assume that’s what the straw taped to the side of a can is for
    funkmasterp
    Just build a small extension so that there is no u-bend. Like a wising well but for poo!
    Kramer
    Is this going to be an STW getting divorced thread in ~18 months time?
