Home Forums Bike Forum Time Pedals vs Spesh Shoes
Viewing 5 posts - 1 through 5 (of 5 total)
  • Time Pedals vs Spesh Shoes
  • Shandy
    I’m recovering from a knee injury (ACL) and I need some pedals which have a good degree of float and can be set so that I can unclip quickly without wrenching my bad knee.
    From previous chat on here I think Time are probably the pedals to go for?
    Has anybody had any difficutly with Specialized shoes and Time Pedals?
    Cheers!
    jfeb
    I had to cut away a very small amount of rubber tread from around the front of the cleat on my Specialized shoes, which I gather is quite common with any shoes. Not a big deal at all though
    HeatherBash
    No, none.
    Times have loads of float but then you need to twist more to release so might not be best option for unclipping quickly.
    If you are looking at Times the new Look pedals are very similar in design
    Shandy
    Thanks!
    I’ve got those hard soled shoes with the serrated grips up the sides so they shouldn’t foul the pedal. Twisting out is ok as long as its smooth, before the op I was using an old pair of Shimanos that are past their best and can be a bit hit and miss for releasing.
    The-Beard
    Nonsense, just as easy to get in and out of as any other pedal if not more so. I have been using them for a while and never had a problem. Used them with Spesh shoes too just fine. Great if you ride in filthy UK mud a lot.
The topic ‘Time Pedals vs Spesh Shoes’ is closed to new replies.
