Home › Forums › Chat Forum › The Electric Car Thread
- This topic has 7,929 replies, 409 voices, and was last updated 2 days ago by mert.
molgripsFree Member
Like I say it uses different regen rates.
Rate meaning what, exactly?
Braking force is provided by the motor generating current OR the brake pads. If you slow down at 2m/s/s then it will generate X amount of current, regardless of how you signal to the car that you want to slow down – lifting off the accelerator or pressing the brake pedal. All changing the regen setting does is change how much braking is applied when you lift off.
Selecting a higher regen rate doesn’t mean more energy is recouped over the course of a journey if you are slowing at the same rate. All it changes is how frequently you need to touch the brake pedal.
DracFull MemberAll changing the regen setting does is change how much braking is applied when you lift off.
Would more engine braking not mean there is more regenerated too?
molgripsFree MemberNot for the same rate of deceleration no.
It never uses friction brakes unless you need them i.e. you are braking hard. If you slow at a normal speed it’s regenerating the same amount, regardless of which pedal you are pressing. Cha ring the regen setting just changes the pedal behaviour not how much energy you actually get back. If you put the regen setting to zero, the car coasts when you lift off; but when you press the brake pedal it regens just the same.
Also, they faster your road speed the more current the motor can generate which means the more regen force is available. Therefore at low enough speeds there is hardly any available. So when you leave your car for a few days so the discs get rust on them, and you set off, the first time you slow for the junction at the end of your road you don’t hear rusty disc noise until you get almost to a stop then you hear them cut in.
shintonFree MemberShouldn’t the question be, does the more aggressive regen result in a better mpg?
molgripsFree MemberNo, because if you slow from 60mph in say 250m it makes no difference if you are pressing the brake pedal or lifting off the pedal. The car is doing the exact same thing.
DracFull MemberThere’s a definitely a noticeable amount of how much it slows in the different modes, something I never noticed as much with the Golf. It makes a huge difference though, descending Glencoe added 20 miles of range. I’m still experimenting with manual vs auto though. I do know I use regen way more that the Mrs and I get far better miles per kw.
M pet KW but yes.
molgripsFree MemberThere could be other reasons you get better m/kWh than your wife of course.
You would have added the same miles descending Glencoe if you’d had your foot on the brake pedal as you did with higher regen settings. The regen setting isn’t .ore regeneration overall, it’s just more regen when you lift your foot. If you get less regen when lifting your foot you apply the rest of the available regen with the brake pedal instead.
Yes, if you lift off it apples more braking force via regeneration; but if you want to slow at a gentle rate you end up not lifting off as much, you feather the pedal. Net result is identical to if you set no regen and just touched the brake pedal lightly.
Pressing the brake pedal in an EV or hybrid activates regen first, and only activates the friction brakes if you brake hard.
EdukatorFree MemberI reckon yes, Shinton. Using mode B I almost always slow with regen to 7kmh when the service brakes take over anyhow. Using D I’d have to back off so early to avoid using service brakes it would annoy other road users or the passengers who wouldn’t appreciate regen braking + service brakes just before the junction. I find mode B ultimately smoother as it avoids needing to brake hard enough to activate the service brakes.
Regen braking is progressively less efficient as you slow so using it fully as soon as you want to slow down will get the best recharge and reduce service brake use.
molgripsFree MemberUsing D I’d have to back off so early to avoid using service brakes
No, pressing the brake pedal doesn’t activate service (friction) brakes unless you brake hard. It’s still regen.
EdukatorFree MemberI know, Molgrips. Thing is the car is far better at calculating how hard it can brake without the service brakes than I am -especially as it’s variable being highly temperature dependant. If I try to do it myself I’ll either have to back off earlier or judge exactly how hard to brake without activating the service brakes.
In mode B I can get down the Col d’Aubisque without the service brakes in mode B. In mode D I can’t calculate as well as the car and invariably end up on the service brakes at some point.
molgripsFree MemberB mode might mean something different in a hybrid. In my Prius, B mode meant that when coasting down a hill it coupled the engine and wheels so that actual engine braking slowed you down rather than friction or regen brakes. This was meant to assist you if you were coming down a long hill so you could avoid riding the brakes all the way down. Because it had small motor and small batteries there wasn’t a large amount of regen available. It was plenty for normal driving but not for big hills. And by big I mean Alpine etc not most of the UK.
How do you know you’re on the service brakes?
EdukatorFree MemberBecause the blue line stops moving. The Zoé has a big circular display. If additional braking doesn’t make the line swing anti-clockwise you’re on service brakes. And you can feel the difference.
Mode B on a Zoé is just a different programme to mode D which increases the level of regen at a given speed. When the battery is warm at 70kmh or over it’ll go to 47kW before the service brakes kick in and give about 30kW without touching the brakes. Slower and colder and you get lower numbers. In D in theory you should get the same maximum regen but I’ve never seen it. You get what feels like about half the regen you get in mode B when not using the brake pedal.
molgripsFree MemberI can’t imagine any reason for the computer deciding to use friction brakes when regen would do. Provided it’s not icy and the battery’s not full etc.
X newtons of braking force at Y speed should always result in Z regeneration current regardless which pedal is in use or not.
DracFull MemberThere could be other reasons you get better m/kWh than your wife of course.
Yup but that is the one thing she doesn’t use. I’ve set her profile to use the auto regen to at least get some from that breaking.
I never used the brake pedal down glencoe as there was no need. There’s some very geeky Norwegians on one of the groups I’m on. They’ve crunched some huge data for all sorts on the E tron. I may see if they have any on the regen comparison.
molgripsFree MemberFrom Renault
The driver can engage B mode on demand with a simple push on New ZOE’s electronic gear lever. Returning the engine brake to normal, unlocking the car’s inertia, is as easy as switching back to D mode. In both cases, New ZOE still converts as much kinetic energy into electricity as possible through regenerative braking.
molgripsFree MemberI never used the brake pedal down glencoe as there was no need
Yes, and you would have used it if you’d been in a different mode BUT the end result would have been the same.
Hob-NobFree MemberIoniq 5 – Swiss Toni salesman, really quiet to drive, infotainment system not very good, boot is small. Looks stunning though.
Funnily enough went to look at one today too. We have a TM3 Performance and are at the point of looking for a replacement to the other car. I haven’t been in a car showroom for about 10 years – doesn’t look like anything has changed, we had Swiss Tony on ‘roids, which put me off from the word go 🤦♂️
Looks. Diversive. In white it looked turd. They had a matte grey one which looked better, but not great.
Interior – looked really cheap, which is saying something as the Tesla isn’t exactly premium quality, but it was still a significantly better place to be. The infotainment system was especially bad.
Have been playing the game of planning routes with the normal ICE car alongside the Tesla & suffice to say if you need to be out and about a bit for work, it’s a total pain in the arse. For that point alone, I think I’m just going to stick it out and wait for the Model Y. The supercharger network is a massive positive, still.
Hob-NobFree MemberIoniq 5 interior gets rave reviews from the press.
Which just goes to show, it’s important to go and see one.
EdukatorFree MemberI get all you’re saying, Molgrips. What you’re failing to see is that in mode B the car automatically often gives you max regen the moment you lift off a lot of the time. There are many temperature and speed situations when pressing the brake will get you no more regen than you have in mode B and simply add service brakes. In mode D it’s almost impossible to replicate that level of regen without tipping over onto the service brakes sometimes.
It’s getting a little frustrating but I’ll find a way of explaining it that you understand eventually. Does everybody else get the point I’m trying to make? : The car is better at slowing down at the maximum level of regen than I am in many situations – that means less use of the service brakes during the stop.
pedladFull MemberIt’s all opinions I guess but I’ve sat in both M3 and now ioniq 5 recently. Much prefer the feel and build of the latter. That’s coming from VW and BMW last two cars.
Tesla have the charger network advantage but ioniq the looks and imho the interior too.
Small range win for Tesla but (given the right charger) a charge speed advantage for ioniq 5.
The cost for a model3/y with the performance of the dual awd ioniq will be ~£150 a month more by my reckoning.
molgripsFree MemberIt’s getting a little frustrating but I’ll find a way of explaining it that you understand eventually. Does everybody else get the point I’m trying to make? : The car is better at slowing down at the maximum level of regen than I am in many situations – that means less use of the service brakes during the stop.
What I’m saying, on the other hand, is that a normal level of slowing down would easily be covered by regen regardless of whether or not that’s activated by lifting off in B mode, or depressing the brake in D mode. Or in my car, regardless of what level of regen you have set. If you want to ride the limit of max regen for some reason, which would require a fairly high level of braking in most cases, then yes the car would be able to find that line better. But that would be fairly marginal. If you brake hard habitually, but are instead prepared to let the car take over by changing mode/settings, then I can see how you’d gain better economy by doing so. Or I guess if you have lots of big hills.
EdukatorFree Memberis that a normal level of slowing down would easily be covered by regen regardless of whether or not that’s activated by lifting off in B mode, or depressing the brake in D mode.
Come back to us once you’ve driven through the Winter, Molgrips. There are three months of the year when I’d piss other drivers off if I drove only using regen. I try to use as much regen as possible but not at the expense of driving in an unpredictable or unduly slow manner. Mode B makes best use of whatever regen braking is available – D doesn’t.
MurrayFull MemberToday was Tesla Model 3 test drive day. Paint, panel gaps etc as good as the Skoda and Hyundai.
Test drive was from West Drayton and the M4, M25 and M40 were stuffed so the drive was on local roads and dual carriageways around Heathrow. Not the most exciting area.
Tesla’s infotainment system was fast and natural. One pedal driving likewise after about 5 minutes. Adaptive cruise control was great.
Only thing that let it down was back seat room for adults – floor is high so knees a bit uncomfortable.
Roll on the Model Y!
DracFull MemberPaint, panel gaps etc as good as the Skoda and Hyundai.
Must have been faulty. 😉
B.A.NanaFree MemberRoll on the Model Y!
The only negative I’ve found with the Model3 is the boot, it’s big enough for what it is but getting 2 bikes in is just such a faff and you’ve no chance of taking anything large to the tip or whatever.
I’ve just worked out today that following the recent OTA update you can now play video games whilst driving, so expect a whole new level of tesla crashes.
pictonroadFull MemberDrac’s Tesla hate is a tedious lowlight to a good thread. Our Tesla is faultless but apparently that’s just me being a short sighted fanboy. 🙄
Hob-NobFree MemberThe only negative I’ve found with the Model3 is the boot, it’s big enough for what it is but getting 2 bikes in is just such a faff and you’ve no chance of taking anything large to the tip or whatever
That’s why we’re waiting for the Y – need a proper hatchback as the dog isn’t a fan of being shut in a saloon boot for obvious reasons & taking bikes anywhere on the odd occasion we need to is a pain. If they made the Model 3 as a hatch, we would probably have a second one by now.
Then in a few years time when Porsche bring out the GT version of the Taycan & the charger network is actually suitable for someone who uses a car a bit for work & doesn’t want to be crippled, I can get what I really want & use it practically.
DracFull MemberDrac’s Tesla hate is a tedious lowlight to a good thread. Our Tesla is faultless but apparently that’s just me being a short sighted fanboy.
It looks like it ruined your humour chip. Yes, I don’t like them, I don’t buy it into the chargers are amazing hype and I’d not buy one. Plenty people do like them as seem pleased with them.
DaffyFull MemberThen in a few years time when Porsche bring out the GT version of the Taycan
It’s out now. Saw one in a Waitrose (natch) car park on Saturday.
DaffyFull MemberI’m also not a fan of Teslas. They look great from the outside (maybe not so much the model 3) and they drive great (I’ve even had the pleasure of a Model 3 Performance at Castle Combe), but I really dislike the interior. The big screen always seems like an simultaneously a design centerpiece and an afterthought. In the Model S/X it felt like they’d gone “right, we need a 17″ touchscreen right in the middle – move everything to make it fit, I don’t care how” and so you get this MASSIVE square plug in a curvy hole. In the model 3 it feels like they get to the end of the design process and went “drat – we forgot the screen – ah, just bob it on the dash, it’ll be right” (I have similar thoughts on the last C-class WRT to the satnav), but in focussing all attention on the screen, they’ve managed to make a cabin that actually makes a Skoda/VW look exciting, it’s just soo bland.
I feel like it’s the interior Tesla envisions when cars are merely robotic taxis and you pay no attention to the interior other than a comfy seat and a TV. But at the moment, it’s still a car first and foremost and, for me at least, it doesn’t feel like it.
Mercedes, Audi, BMW, Volvo etc are a really nice, tactile place to be, everything to hand, no need to take your hands off the steering wheel for most functions, and when you do, you don’t need to look (BMW I drive), it just falls to hand and the palcement and feel of the buttons and controls intuit what you should do.
FlaperonFull MemberI watched the Tesla AI Day presentation last night and came away extremely impressed (if you discount the mad bit with Musk and his “robot” at the end.
An educated guess says that they’re several years ahead of their closest competition from an AI point of view and this will accelerate with their new supercomputer. This is the first time I’ve got the impression that the software might work in the UK*.
The thing that struck me is whether there’s actually any demand for self-driving. I hate driving and would happily pay a premium to absolve myself of the job, but I think I’m in a minority.
* 99% of the time but the occasional “please help, I’m dealing with an idiot” message from the car.
neilnevillFree MemberNumpty basic question here from someone just starting to think an electric car in a couple of years could be brilliant. What is the infrastructure like in places abroad that you might take a car on holiday? France and Spain I guess I’m most interested in.
DaffyFull MemberThe thing that struck me is whether there’s actually any demand for self-driving. I hate driving and would happily pay a premium to absolve myself of the job, but I think I’m in a minority.
@flaperon – I think It’s going to be one of those things like smartphones – only a small minority of people actually needed them when they were clunky things like the big Nokia and Ericsson ones, but as soon as Apple made it slick and easy, everyone realized how useful it could be. “Your phone can connect to the internet? Download songs? Upload Pictures that I’ve taken on it? What?!?!? Why am I carrying around 4 different items and then having to cobble them all together to make stuff work????If you can use the time to your advantage (sleep, breakfast, TV, work, etc) not many people will care if it takes a few hours longer, the ease and simplicity will make it the go-to option.
I think self driving cars will hammer any potential for mass transit Urban Air Mobility (too complex, too inefficient, too clunky) and may even kill some short haul, intra-country flights. General Airport turnaround for a point to point journey and a 1 hour flight is ~4 hours. and you can go about 400 miles in that time. A self drving car would likely take about 5-5.5h to do the same assuming similar, unproblematic conditions.
FlaperonFull MemberWhat is the infrastructure like in places abroad that you might take a car on holiday? France and Spain I guess I’m most interested in.
Not an issue with Tesla. Eg https://www.tesla.com/en_gb/trips#/?v=M3_2020_LongRange&o=London,%20UK_London%20London%20Greater%20London@51.5073509,-0.1277583&s=&d=Madrid,%20Spain_Madrid%20M%20MD@40.4167754,-3.7037902
Can’t speak for other networks. Quentin Wilson published a short video on YouTube chronicling his drive through France in a Model 3. Looked pretty idiot proof.
molgripsFree MemberThe thing that struck me is whether there’s actually any demand for self-driving.
There is, huge demand, but it has to be absolutely bombproof for people to have confidence in it, or it’s no good at all. All-or-nothing scenario.
oldtennisshoesFull MemberI’ve just ordered an eTron to replace the A6 – that’s us fully electric with a Zoe for shorter journeys. Exciting times!
molgripsFree MemberChargemap.com covers France, not sure how good it is mind the map is quite densely populated.
DracFull MemberI’ve just ordered an eTron to replace the A6|
You’re going to be pleasantly surprised. They’re really nice to drive, huge amount of space and very comfy.
