Home Forums Chat Forum The Electric Car Thread
  • This topic has 7,929 replies, 409 voices, and was last updated 2 days ago by mert.
Viewing 40 posts - 7,641 through 7,680 (of 7,930 total)
  • The Electric Car Thread
  • 1
    prettygreenparrot
    If you were warrantying something wouldn’t you want the owner to check it over regularly to make sure any problems are picked up early?
    I see your point. Though it’s a bit of a weak warranty in a way if it requires the owner to pay for assessments that prompt early remediation.
    service costs over a combined 6 years of a Model 3 and Model Y £0. That coolant replacement and associated service checks on the Model S back in the day a MB-style £750 if I remember correctly.
    matthewlhome
    Re: regen making the car a sledge…
    In icy / snowy conditions i turn the regen down to minimum as the car does just this. Lifting off gives too much braking and can cause a slide.
    Wheelspin is another issue.  It may not wheelspin more than an ICE vehicle, but there is nothing to indicate its happening unless looking down at the dash.  With an ICE there are increased revs and no movement, whereas with the EV simply nothing happens!
    mert
    But does the regen setting take into account the road/traction issues?
    Depends on who supplies the brake module and what the manufacturer has paid to be activated in it.
    But mostly, yes. Regen is still “braking” and the same mitigation’s are in place as normal braking. So if a wheel locks the regen should do one of three things.
    1) drop out completely and the brake control will be taken over by the service brakes to give consistent performance, you *probably* won’t get regen back until you’ve done something to tell the car you’re in control, typically accelerated again or used the brake pedal over a certain threshold. Most current cars are doing something like this.
    2) reduce brake torque until the wheel starts moving again (don’t know of anyone who is doing this anymore).
    3) drop out completely and you’ll have to use the brake pedal to slow down. Some early teslas do/did this and some of the smaller/city car types. Again, it’ll come back when you’ve done some thing specific with the controls.
    Does my brake assist take into account the amount of regen i have selected in conjunction with the traction.
    Yes, if your car is in the 1) or 2) groups
    Then there is the collision prevention assist which has three settings of harshness.  Do i need to reduce the setting for the winter.
    Completely up to you, i wouldn’t, and haven’t for years.
    Also, traction control is usually dependant on reducing torque and braking each wheel independently, so they (mostly) have to switch over to service brakes, as regen brakes each axle rather than the wheel itself.
    1
    mert
    Do you get no TC intervention at all? What car is that, i need to go play! Nothing i’ve driven or benchmarked behaves like that.
    1
    molgrips
     If i go into max regen is the car suddenly going to become a sledge and crash when its icy roads and i take my foot off the accelerator?
    Car designer: We’ve poured billions into designing stability systems. Now that we can instantly control the torque of the motor should we also modulate the regen to help with the ESP?
    Car designer boss: Nah, **** it, let them crash.
    I think it’s a bit of a myth that engine braking is better for snow. It allows you to brake nice and slowly but you can still do that with the brakes and you get the benefit of ABS and the braking force distributed over four wheels. I agree it feels better to use gentle engine braking but I don’t think it is.
    The car is designed to deal with you wedging the brakes on in panic so I don’t think it’s going to stop working in snow or if you have regen selected.
    TheLittlestHobo
    Thanks guys.  Plenty to consider there.  I did have lots typed out but im not sure it will help the conversation
    matthewlhome
    mert
    TBH I was messing about to see what would happen when lifting off fully, so no modulation at all.  This was on quiet untreated country roads which were frozen over.
    Car is an Ionic classic, and as i have noted previously, it’s quite wheelspin happy in the cold and damp with too much enthusiasm.
    To counter this, I’m pretty sure that TC and stability have saved me since when I caught a large puddle of diesel on a roundabout.
    1
    convert
    I’m sure I read many pages back reference to avoiding the Jaguar I Pace. Anyone care to expand why?
    Back at the research again and the I Pace ticks a lot of boxes (apart from the silly high insurance group because of the unnecessary silly fast acceleration).  Obviously as a new buy it was pretty woeful as it devalued like a stone…but that means it’s now affordable 2nd hand to grunts like me. A colleague at work has one – looks ok. Mind you – never considered myself a “Jaaaag” kind of bloke.
    sharkbait
    I believe it is/was rather unreliable. Might be wrong.
    julians
    Unreliable, and crappy dealers, coupled with a relatively slow DC charge speed, but a very large battery
    There was/is a common issue with the battery that meant quite a few needed new cells, which jag were/are replacing under warranty, but because of a parts shortage it was taking months to get the cells replaced, and during that time the car limited you to 75% battery capacity.
    Others issues included a leaking front windscreen that causes the dash electronics to get wet.
    Shame really, nice looking and driving car by all accounts.
    1
    DrP
    Back to servicing – my P2 runs out of warranty next month..
    obvs i’m going to get it MOT’d as a legal requirement, but…Iam I being daft saying “I genuinely can’t see any point in a service”?
    When I bought it I’ve already replaced the cabin filter. I think I’ve used the brakes 6 times in a year (!), and I top the washer fluid up when needed…
    WHAT ELSE DO THEY DO??!!
    I’ll deep dive on the polestar forums (as, looking at Molgrips post and seeing his Ioniq needs engine coolant, I don’t want to miss anything)…but SURELY there’s not much more to do??!!
    DrP
    1
    DrP
    An AI search suggetion brings up:
    A Polestar 2 service can include a number of things, such as:
    Cleaning: The Polestar 2 can be cleaned as part of a service
    Pick-up and delivery: Polestar can arrange to pick up and deliver your car for maintenance or repairs
    Brake system maintenance: This can include a full brake report, checking the brake pipes, and adjusting the handbrake
    Suspension and steering check: This can include checking the suspension operation, steering and suspension joints, and wheel bearings
    Cabin air filter replacement: The cabin air filter is one of the only parts that requires regular attention
    Software updates: Polestar releases software updates, which can include new features
    Literally nothing I can’t assess myself, or will come up as part of an MOT (Brake and handbrake are checked).
    I think it’s money for old rope!
    DrP
    1
    molgrips
    Put yourself in their position.  Imagine talking to the general public:
    “X has gone wrong and this has ruined the car, how dare you, fix it now!”
    “Well, if you’d checked Y and fixed that before it went wrong you would have been fine”
    “I checked it, I know what I’m doing, my cousin did a night class in motor vehicle maintenance”
    etc etc
    There are YouTube channels dedicated to the incredible idiocy of motorists when it comes to maintenance.  So yeah, I can totally sympathise with the manufacturers on this one.  £370 for the 4 year service on my car is harder to swallow when they still did basically nothing, but that’s the dealer being disingenuous. The coolant refresh is the reason the bill is usually £500 but it didn’t need doing because it had been done under recall. However the dealer only knocked off the cost of the coolant itself and not the labour that would have gone with it.
    matthewlhome
    I’m not looking forward to my next service as that’s going to be another coolant replacement 🙁 I avoided the cost of the first one by having my service done at the same time as the recall too.
    Getting dealer servicing has definitely been worth it for me as it keeps up the warranty, which is a reasonable 5yr / 100,000 miles.
    Have had to have a good few items sorted early on – charge port, coolant fix, 6 wheels (corrosion under the coating)and about to have a window motor as the window often winds up and then goes down again!
    I’ll probably stick with the dealer services once the warranty runs out next year as the costs are not too bad for peace of mind to keep everything checked and in good order.
    The minor services are maybe a little frustrating as it does seem to be not much more than an expensive clean.
    prettygreenparrot
    you are not required to have dealer services to sustain a warranty are you? I thought this was established some years ago. If the warranty depends on service history then any valid service is sufficient. https://www.themotorombudsman.org/knowledge-base/do-i-have-to-have-my-vehicle-serviced-at-an-authorised-dealer
    And as Martin Lewis has said: ‘warranty shmarranty’ you have statutory rights. That being said, LR Tesla battery and drivetrain warranty is ‘8 years or 120,000 miles, whichever comes first, with minimum 70% retention of Battery capacity over the warranty period’ https://www.tesla.com/en_GB/support/vehicle-warranty
    molgrips
    No but I think you are required to have services of some kind.  And whilst you do have statutory rights regarding something being fit for purpose, it would seem that on a thing that needs regular inspection and maintenance it is not unreasonable to expect that maintenance to have been done. It’s a bit like making a claim against Fox for worn stanchions when you haven’t ever bothered to check or replace the lower leg oil and it’s run dry. Fox could hardly be expected to cough up for that when they say something is specifically needed and you don’t do it?
    matthewlhome
    In the interests of research, and having a white icy road this morning, i tried it out.
    On a hard lift off, the car does lock the front and start to slide, but then i did notice a bit of anti-lock happening. Thanks for making me aware!
    I still prefer to dial regen down to a minimum on icy roads as in the moment of panic lift off, i’d rather the slowing be more gentle.
    matthewlhome
    Re: warranty.
    Maybe dont need main dealer servicing, but Hyundai definitely challenged the service history on one occasion when dealer hadnt updated the digital records.  When the service at main dealer is around £60, and I can work in there while waiting and drink their free coffee I dont mind going to them.  I’m not sure an independent would be any cheaper, and I doubt they would have the tools for the coolant flushes on the big service (Hyundai had to wait for special kit to do this).
    mert
    Not quite *any* valid service. Then are some caveats about authorized service centres, competent persons and the use of OE or authorised alternative parts.
    Nice! Just tried mine too, couldn’t even get it to lock up or slide, just braked to a stop.
    dove1
    Re. EV servicing. Took my Kia EV6 for its first annual service last month. Sat in a Starbuck’s opposite the garage working while I waited for the car to be serviced. I had a clear view of the dealer’s car park and could see my car.
    After about 2 hours they took the car to the workshop. 25 minutes later it was back in the car park and I got the call to say the service had been done. Those 25 minutes included the technician making a video showing me the brakes and underside of the car, a wash and vacuum!
    roverpig
    Manufacturers used to make a decent profit on every car they sold and then a fair bit more servicing and repairing those cars. With EVs a lot of manufacturers seem to be struggling to get their costs down to the point where they can make any sort of profit even with the current “EV premium” and helpful tax breaks. So, I can see why they are keen to hang on to as much of that servicing revenue as they can. The problem (for them) is that there really isn’t much that needs doing and there is only so much people are going to be willing to pay for a wash, vacuum and visual check.
    I think they are relying on the fact that ICE car drivers are used to paying for dealer servicing, at least for the length of the warranty and they hope they wont mind too much paying a similar amount to service their EV (even if very little actually needs to be done). Over time I guess independent service centres will spring up that will do an “EV service” while you wait for a lot less than the main dealer. A bit like the jiffy-lube places that Americans use for their regular oil changes. At that point I can see franchise dealerships disappearing as cars are bought online direct from the manufacturer and serviced at independent centres. But who knows, maybe they’ll find a way to carry on.
    1
    maloney19710776
    Re. EV servicing. Took my Kia Ev6 for its annual service a month ago. Dropped it at 8.30am, as requested, and went to work. The Kia app notified me the doors were unlocked at 4.15pm, the bonnet was opened at 4.18pm. I had the phone call at 4.28pm to come and come and collect it. I gave watching the video a miss 🙂
    roverpig
    That’s funny 🙂 I guess with modern cars that have cameras all over the place and an app that let you view then, you could watch the service being done.
    molgrips
    It has long been alleged that dealers make most of their money from servicing and EVs will erode much of that. It’s usually Americans saying this so I don’t know how much that applies here. But if it’s true dealers will have to reduce the discounts they can give.
    boomerlives
    Good luck with that without the computer
    DrP
    My point was the handbrake will only need adjusting if it fails the MOT handbrake check.
    Thus, I’m doubtful Volvo/Polestar adjust everyone’s handbrake EVERY service!
    DrP
    EDIT – also, it seems, that if present a handbrake issue comes up on the infotainment, so a few prompts to guide towards if an issue is/isn’t present.
    uponthedowns
    Not just alleged. Andy Palmer former COO of Nissan and CEO of Aston Martin admitted it on Xitter.
    Greybeard
    I took my e-Up for service to maintain the warranty. They changed the cabin air filter. Nothing else.
    TheLittlestHobo
    Just wanted to update on my EQA with regards to regen settings, collision prevention settings and all the other settings in the snow/ice.
    I have intentionally (Where safe to do so) been a little ham-fisted with lifting off the accelerator when in max regen on slippy roads.  It has resulted in zero issues.  The car just takes care of it.  Absolutely delighted with it so far.
    Must say compared to my previous RWD C Class AMG it seems to be a lot better
    oldtennisshoes
    Thanks @Molgrips
    That’s the info I wanted on the Ioniq. I did have a quick look at the Kona and I need to investigate more.
    The local Renault garage also does Hyundai, so should manage to get something sorted.
    I’ll report back.
    Update – not much.
    After much debate and considering options we’ve now sold the battery lease Zoe – I wouldn’t trust Arnold Clark to not balls up taking on the lease, so I sold it to someone who bought the battery as part of the deal.
    Not settled on anything yet. Was supposed to be test driving a Hyundai Kona and newer Zoe today, but the weather has put paid to that. My head says that the Hynudai is likley to be a better long term buy than the Zoe, but the smaller size and slightly longer range of the Zoe does appeal.
    The search continues!
    boomerlives
    Probably.
    My point was the simplest tasks on current cars requires the right laptop to be plugged into it. It’s why dealers are always the best bet in the first 5 years.
    1
    DrP
    Oh..I agree on that…
    My warranty runs out in about 3 weeks…
    I’ve had a few issues dealt with in the year I’ve had it:
    -new ‘ipad’ screen – has a crack in it,behind the digitizer, from purchase. (Bought it second hand(. Went straight from purchase to Volvo (well, a week) and they warrantied it.
    -faulty parking sensor… Volvo kinda implied it had a stone chip, but swapped it anyway.
    -creaking suspension top bearing – seems to be a known issue with a technical journal recall present, so no issues getting that done… Has been agreed..waiting for the parts in the next few days.
    This is the newest car I’ve ever owned (was 3 years old when I got it), but I think all these errors are exactly the kinda thing to appear in the first few years, so not overly fussed.
    DrP
    deadlydarcy
    Smart already booked in for faulty door handle. Stupid bloody design. Looks funky but is essentially a bit silly. I’m all for keyless entry, but handles like the PS2 were just fine. These things that pop out. Ffs.
    1
    dove1
    Pop out door handles: is there any actual benefit?
    In the icy weather last week mine froze and wouldn’t pop out when I unlocked the car.
    Took me a while to get the driver door handle out so I could get in the car. Stupid thing then froze in the out position and wouldn’t fold in.
    2
    Just had Michelin CC2 fitted. I think we can safely say that’s the last of the snow for this year 🙂
    roverpig
    That’s one of the things that is putting me off the Smart. I don’t mind flush door handles as long as you can manually operate them. For example, I think the Tesla (and Renault?) door handles are flush but you can pop them out manually if they fail to pop out automatically, which is OK. But having to rely on them to pop out and retract automatically just seems like a problem waiting to happen as soon as it gets cold.
    Mind you, I’ve considered so many EVs over the past few months and every single one of them has something that makes me think “no way, I couldn’t live with that”, which is why I’m still driving my old ICE car. Hopefully one day soon something major will go wrong with it and I’ll be forced to finally choose an EV and just live with its issues 🙂
    1
    wbo
    Re. Snow , ice.  i have regen on max and drive in eco mode, plus winter tyres
    And I see plenty of snow and black ice, and more than anyone in Britain for sure.
    B.A.Nana
    It really hasn’t been, you just open the app 5 or 10 mins beforehand and put the heating on or put it in defrost mode. Which if  its freezing outside, you’d want to be doing anyway. Door handles have always worked for me
    roverpig
    What car is that @B.A.Nana?
    RustyNissanPrairie
    Bit late to the game with this one – but yes engine braking is better than foot braking. As each individual cylinder compresses it builds braking torque until it reaches TDC then braking torque ramps down until the next cylinder compresses. It’s kinda like ‘soft’ imperceptible ABS pulses.
