Home Forums Bike Forum The bike/frame/part you would most like to see launched in 2017 is…
Viewing 40 posts - 1 through 40 (of 64 total)
  • The bike/frame/part you would most like to see launched in 2017 is…
  • duckman
    For me; a 29 version of the new P7. Failing that, a revamped Solaris with a rear through axle.
    mikewsmith
    Wirelessly chargeable lights and computers, not having to remove the rear lights from the bike to charge them would be great
    metalheart
    Frame paintwork that can withstand the rigours of bikepacking luggage and Scottish weather/conditions…. 😥
    cyclelife
    Hope carbon frame.
    giantalkali
    An electric bike, imagine that.
    blader1611
    Shimano to release 105 di2 with a far cheaper price tag than the current basic ultegra di2
    jruk
    A Kona Honzo-esque frame in a decent steel so it doesn’t weigh a tonne. Or make the Alu frames available.
    LAT
    Widespread adoption of 142×12 hub spacing.
    mattsccm
    Campag disc brakes but at a lowish level.
    Retrodirect
    A cx frame which can be run as a fixed-wheel, with gears, with discs, with v-brakes and with the full complement of braze-ons.
    I like rebuilding my bike into different guises. Cross-check/straggler comes close but you then have the choice of disc OR v. NOT both.
    humbug.
    Edit:
    oh! and a fork-crown mount for an exposure light. (the exposre brackets are brilliant but only for handlebars.
    Edit2:
    and a 27.2 dropper that works!
    adsh
    Full carbon Salsa Spearfish with rear travel increased to 100mm.
    poah
    nowt
    P-Jay
    a 650b Cove G-Spot frame that doesn’t weigh as much as the moon, nor cost £3k.
    mildbore
    26″ forks
    ScottChegg
    Soooo last year. 148 and wider is the future.
    peaslaker
    26″ forks
    I’m not sure I’d be able to utilise that much travel.
    sb88
    Some amazing way of holding wheels in the frame and removing them quickly. It would be light, universal fitting and would last years, and all bike shops would stock them.
    I would call it the ‘Velox Sejungo’
    fooman
    Properly sealed maintenance free bearings would be nice. I can dream can’t I?
    CheesybeanZ
    A Pinion type gear box and belt drive at a sensible price .
    phutphutend
    Starling Cycles Beady Little Eye, full sus singlespeed…
    cookeaa
    My old 456 SS frame but in carbon/27.5/27+compatible with a tapered headtube, interchangeable QR/142/148/slot ‘swapouts’ and 31.6 seatpost sizing…
    Oh and I want it for under £100.
    And a similarly cheap ‘old school’ Marzocchi type open bath 120-140mm fork that can magically swap between 20mm/15mm/boost hubs. Oh and only weighs a kilo…
    tomhoward
    To mirror most of what has been said above.
    A(ny) specialist product that is as good as the best, for the price of the cheapest mass market one.
    That or a flight to the moon, for the cost of an easyJet flight to Benidorm.
    richardk
    Time machine so I get a chance to ride
    allthegear
    Transparent (or, at least, translucent) frames. Will make all those bare metal frames look so last year…
    Rachel
    P20
    Ritchey Outback
    jimw
    A non-boost Cotic Flare max. So That I can use my existing forks and wheels on a new frame. I can’t justify buying a whole rolling chassis but I could just about afford a frame only…….
    monkeysfeet
    29er Cove Stiffee.
    jambalaya
    Quick release pedals to make putting the bike in the car easier
    IvanMTB
    70mm wide, 29er, CF, single wall, tubeless rims…
    Cheers!
    I.
    coomber
    Revised parkwood. So needs to be as cheap as chips, boost and bolt through, swap out dropouts too, and at least 60mm more reach.
    timraven
    [quoteTime machine so I get a chance to ride[/quote]
    This, only this.
    metalheart
    Nothing, surely, stopping you using ‘old’ forks and front wheel?
    Can you not Boostinator your rear wheel? At worst it’s a new rear wheel (£250?).
    jimw
    boostinating means altering the dish I think. Not likely to be successful with a four year old Mavic Crossmax ST
    Singlespeed_Shep
    A bigger Stooge. (For Me)
    Awesome bike but an extra inch or two and ability for me to run a dropper and it would be spot on 🙂
    Singlespeed_Shep
    would this work:
    Linderets Boostinator kit for standard hubs
    chakaping
    I’d like to see more brands using shorter seat tubes, now that we have nice long droppers – to give us stumpy-legged folk a greater choice of frames.
    So many great interesting bikes ruled-out by unnecessarily long seat tubes these days.
    400mm on a medium and 430mm on a large would do it.
    Turnerfan1
    Sram Force E-tap.
    Thanks,
    Max
    coomber
    430 on a large? Wowsers
    I’m not used to droppers but even with seat post slammed I still prefer a longer seattube than that else it feels like your riding a kids bike. 150mm dropper is plenty I’d say.
    ahwiles
    Cranks in a proper range of sizes (down to 130mm, to go with xs frames)
    matt_outandabout
    650b carbon ht, with shimmed 27.2 seatpost, boost, 120mm Fox32, 2×10 Deore, 35mm rims and 2.6 tyres and a £1k c2w price tag…. 😉
The topic ‘The bike/frame/part you would most like to see launched in 2017 is…’ is closed to new replies.
