Home › Forums › Bike Forum › Sick as a dog so, show me you Bivi / Bikepacking / Adventure racing gear…..
- This topic has 2,850 replies, 7 voices, and was last updated 6 years ago by NZCol.
HounsFull Member
Just had my Rig 3.5 turn up. How much para cord do you take with you?
daleftwFree MemberAnyone done any bivvying in/around Kielder/Wark/Hexhamshire Common?
scotroutesFull MemberNone
I use 1.5mm Dyneema. I have it already made up into suitable guy lines. IIRC, two are 1.5m and two are 3m. I also use mini Line-loks for adjustment.
TBH, I usually set the tarp up as a flying V so the two guys I need for that are almost permanently attached.
Untitled by ScotRoutes[/url], on Flickr
STATOFree MemberAnyone done any bivvying in/around Kielder/Wark/Hexhamshire Common?
Hammocked in Kielder a few times, typically in winter tho as i avoid Kielder any time when midges are about.
joshvegasFree MemberI am the same as scotroutes. 1.5mm dyneema guys with mini lineloks. When i use my hammock i include 2mm dyneema ridgeline with toggles attached to 1.5mm dyneema loops tied to ridge line with prusak knots for adjusting tension.
Paracords sags when its wet and its quite heavy when its all soaked!
AlexSimonFull MemberThere are loads of dried packet foods in all the supermarkets that are vegan (some Ainsley Harriot couscous, pots and packets of pastas/noodles, etc) all need only boiled water and are very cheap. I tend to take a water filter so that I can have unlimited water.
Occasionally I have porridge too.Can’t say it’s the best food, but it fills a hole!
Then nakd bars, fruit/nuts, clif bars, etc.Tiger6791Full MemberAny thoughts on vegan foods for bikepacking?
Yep, after lots of different tries I reckon I’ve got this sorted to an extent.
Fast, cheap and easy options
Sainsburys Pour & Freeze bags (8 for £1) are my starting point.
For breakfast decant 1&1/2 Oat so Simple pots (3 pots makes 2 breakfasts) into a P&F bag
These just need 200ml water to make a decent helping of porridge.
Pour the water in, squeeze a bit of air out and seal the bag, mix up by squeezing and shaking, leave to stand for a couple of minutes. (add nuts / raisins etc.)For dinner same priciple but use Noodles / Cous Cous / Pot Noodles. Add dried sausage etc.
bobloFree MemberRight ho…. I am now the proud owner of a bag of Alpkit stuff; MTM frame bag, seat pack and s&m style handlebar harness for an existing 12l dry bag.
What do people pack where and do you camelback as usual? Any tips n tricks gratefully received.
I’m a died in the wool pannier man so this is all a bit weird. Best leave in the dark for my first foray lest anyone spots the weirdness 🙂
CheezpleezFull MemberI tend to pack related bits and pieces together, so sleeping bag, mat, bivy and tarp on the bars, spare clothes in seat pack, food and cooking kit in frame bag and tools and snacks in a small top tube bag. I like to ride without a rucksack but have used a Camelback bumbag to carry water and a waterproof.
I like to have plenty of dry bags in varying sizes to organise stuff so it’s easy to find. This also helps to keep wet stuff separate from dry stuff. Packing a couple of supermarket carrier bags is always a good idea.
NobeerinthefridgeFree MemberAfter a couple of trips, I have sorted what I need now, and what I don’t, you’ll be the same. As for camelbak, no, I try not to use it as often as I can, I cable tie a bottle holder on the top tube and plan on getting one of those ones that CTBM sells that go on the top cap. 2 bottles is fine, I have no qualms about drinking from a burn when in the sticks.
SimonRFull MemberPretty new to this but had a great couple of weekends away so far – one of them at the Welsh Ride Thing.
I’ve got a Wildcat seat and bar harness and a Revelate small framebag. “Modular sleeping system” TM 🙂 (bivvy bag, sleeping bag and liner) plus poles goes on the bars. Shelter and some stove bits go in the seat pack. Tools, tubes, miscellaneous heavy bits go in the framebag. Clothes go in a rucsac along with a bladder and snacks.
Tried an Alpkit bar harness but didn’t work on my bike (soon to appear on the classifieds ) – would be fine with a taller front end. Bit more on this thread …. http://singletrackworld.com/forum/topic/bikepacking-colour-choice-poll-help-me-decide
Improvements? I’m going for a bigger bag on the bars (up from 8l to 13l). Looking for a secure side entry bottle cage so I can get a bit more weight off my back. Later on will probably look for a full frame bag but that can wait.
Now the obligatory photos:
Bike and bags:
[/url]
21-P5042197[/url] by Simon_R[/url], on FlickrBike and bags again …
[/url]
30-P5042206[/url] by Simon_R[/url], on FlickrWelsh Ride thing bivvy site (slightly dodgy tarp set up!)
[/url]
15-P5042191[/url] by Simon_R[/url], on FlickrBig skies
[/url]
27-P5042205[/url] by Simon_R[/url], on FlickrRoom with a view:
[/url]
09-P5252277[/url] by Simon_R[/url], on FlickrGreat spot ….
[/url]
14-IMG_1863[/url] by Simon_R[/url], on FlickrthisisnotaspoonFree MemberStuck with a couple of problems.
1) I’ve got my sleeping bag in a bar mouted bag with a DIY made harness, but the tyre buzzes when the fork compresses. Would paying for one solve this or is it just a problem for 29er’s? I can mount it on top but it’s not too stable (but didn’t fall off on a short ride, just wobbles a lot).
2) Those of you just strapping the drybag to the saddle/seatpost, what are you packing in it, I’ve ended up with all the loose stuff in there (sleeping bag on bars as it’s lightest, tent in frame bag as it’s heaviest). So that leaves clothes, food, cooking stuff, and sleeping mat. The mat gives some shape, but not enough to stop it rattling and setling down and falling off.
joshvegasFree MemberLets talk sleeping bags, I have an alpkit 800orsomethinglikethat which is lovely and warm but I am paranoid about getting it wet so unless its freezing or I have a tent it gets left behind, I also have DD hammocks sleeping bag purchased on a whim, its heavy and bulky when packed but I like the top opening zip because I am always to warm and I like the waterproof footbox because J canstand up in it and get into the hammock or wriggle into the bivvy without bothering about getting it muddy.
Neither of them are particularly great in summer as I get to hot and end up sleeping on them rather than in them, they are also not tiny packed.
I was thinking 2 season bag as I will have a down jacket with me anyway but also wondering about quilts and even consider just sewing some pertex to a very fluffy blanket and using that.
Thoughts.
ChewFree Membertyre buzzes when the fork compresses
Which make of drybag are you using?
Alpkit ones are a bit sausage roll shaped and so end up being quite long. Maybe try an exped one which are round, which will give you the same capacity but in a smaller size.
Also depends on what size drybag. 8l should be plenty for summer use.thisisnotaspoonFree MemberBoth are podsacs bags. The 10l one takes the bag with room for a bivi bag or jacket too, the 7l bag barely holds the sleeping bag, has to be sat on to compress it enough to roll the top over, but it is the compression type so once rolled there’s another splashproof layer keeping water out.
I might try an alpkit one on that basis if they’re longer and thinner. Or do you mean sausage roll like this:
rather than a footlong of gregs finest reconstituted pork and pastry?The sleeping bag itsef I’ve no idea how warm it’s supposed to be, it’s pretty old, but it is down so replacing like for like would be expensive, but buying a less bulky bag might be the nuclear option, I’m rarely cold in it, but then I rarely use it outside of summer.
stills8tannormFree MemberI was thinking 2 season bag as I will have a down jacket with me anyway but also wondering about quilts and even consider just sewing some pertex to a very fluffy blanket and using that.
A Buffalo summer bag might suit you, Pertex and pile, centre zip, waterproof(ish) and not too heavy.
ChewFree MemberMore like this:
Not round, but long a thin in the profile. I always find they rotate and point down through use, which may make things worse for you.thisisnotaspoonFree MemberAhh, I see what you mean.
Might work, the strap guide thingies on the alpkit bags might hold them up.
Got the smaller podsack bag to try first, just means transfering even more stuff to a seatpack.
JohnClimberFree MemberTurned up today, not just stories but advice and ideas
10/10 from mejoshvegasFree MemberI saw him talk at the mountainfilm film festival in edinburgh I liked his attitude!
thisisnotaspoonFree MemberGiven up trying to DIY a saddle bag harness, seems to alternate between prototypes that either settle down and loosen or are too wobbly to start with, is there anything comparable to the Alpkit Koala bag (on price and size), but in stock?
Seeing as I can only just squeeze a sleeping bag under the bars it needs to be big-ish to take
Alpkit 3/4 mat,
myti mug and stove
food
clothes (spare riding kit + down jacket)The revelate one would fit the bill, but a few £ too many.
thebrowndogFree Memberis there anything comparable to the Alpkit Koala bag (on price and size), but in stock?
Ive got a Wildcat Gear seat harness that holds a drybag. Ive used it with a 13l drybag though not sure if you’d get all that kit into it, especially the mat. Have you tried rolling your sleeping bag in the sleeping mat? Lot of us do that as it helps make compacting the bag easier.
Anyhoos – linky below for the Wildcat harness.
http://www.wildcatgear.co.uk/shop/seat-systems/wildcat-gear-tiger/
bokononFree Memberbut the tyre buzzes when the fork compresses.
This is less likely to be 29er related, and more likely to be stack height related. The maximum size bag is clearly going to be a function of the stack height, bikes with a really low stack will buzz when the forks compress. The bloke I rode the WRThing with had this very issue with a wildcat harness – not Wildcats fault, it strapped everything up perfectly, but the distance from handlebars to crown wasn’t big enough for a dry bag.
I tend to roll stuff up in my sleeping bag or in my mat – out front is the sleeping bag, with stuff for the night rolled into it (spare socks, food etc. out back is the sleeping mat, with suff for the night in it (more food, bivvi bag), in the frame bag is stuff I might want in the day plus cooking kit and repair stuff.
dknwhyFull MemberLast weekend, I set off with a mate up to Edinburgh to cycle Sustrans Coast & Castles north route from Edinburgh to Aberdeen.
The route itself is pretty flat, bar a few hills and steady drags. It’s a nice route, mainly tarmac with the odd gravel section (Kinross and along from Montrose). It’s a nice scenic route with plenty of towns along the way to stop off at. A cross bike or road bike with sturdy tyres is ideal for the route. My mate had 25mm road tyres and had a couple of punctures.
Kit wise, I travelled my lightest yet – SMD Lunar Solo, Neoair Xlite, Exped pillow, Lifeventure Downlight 660 bag, 1 pair riding kit, shorts, T shirt and socks for off the bike (forgot to pack undies so went commando!) Montane Fireball smock and Montane single track jacket, tools etc on bike. All carried in 2 dry bags, deter frame bag and a montane bat pack.
We camped at campsites to make things slightly less daunting for my mate who’s first trip it was. This worked well as we were able to leave the bikes locked up at the site and head into town for dinner and drinks. Train connections were great (they run the length of the route). On the Sunday night, we grabbed a train back into Edinburgh and stayed in a hostel by the station which meant that we could do some sightseeing on the Monday before returning home.
Day 1 we rode from Edinburgh to Kinross (approx 35 miles), day 2 was 80 miles from Kinross to Montrose and day 3 around 45 miles into Aberdeen:
IMAG0312 by DKNWHY[/url], on Flickr
IMG_1192 by DKNWHY[/url], on Flickr
IMG_1206 by DKNWHY[/url], on Flickr
IMG_1190 by DKNWHY[/url], on Flickr
IMG_1213 by DKNWHY[/url], on Flickr
IMG_1195 by DKNWHY[/url], on Flickr
IMAG0317 by DKNWHY[/url], on Flickr
More pictures on my flickr stream:
scotroutesFull MemberIt was (just gone) the solstice so I took time out for a wee loop around bits of the Cairngorms.
http://www.blog.scotroutes.com/2014/06/twa-lairigs.html
Can’t say I really recommend the Lairig Ghru with a bike (though everyone should do it once)
mtbmattFree MemberHas anyone tried the Karrimor bivvy bag?
Looking for a cheap, summer, dry weather only option but something that will keep my down bag dry.scotroutesFull MemberMountain Warehouse are doing cheap bivvy bags. I got one as a bit of a spare/back-up option. Much lighter and smaller packed than my expensive RAb Event one – but I’m betting a lot less breathable too.
daleftwFree MemberIs anyone bikepacking/bivvying in or around the North East? If so, fancy letting me tag along? I’m not a dick, honest.
Suffering huge mojo losses at the minute, hoping company will resurrect it.
stills8tannormFree MemberCan’t remember my login details!
An email in the right direction could sort that out: stuart@bearbonesbikepacking.co.uk
rj2djFree MemberHave read this entire thread over the last week – inspiring stuff from everyone who’s contributed. Intend to set off down the Celtic Route West in October. Currently working out just how much of my kit should be waterproof!
MidlandTrailquestsGrahamFree Member…is there anything comparable to the Alpkit Koala bag (on price and size), but in stock?
I was wondering this myself, is it just Alpkit or Wildcat? Nobody else makes anything similar?
I’m still working my way through this thread from the beginning, so apologies if this has been covered already and I haven’t got to it yet, but can you get patterns for making seat packs etc.?
I know a few people make their own gear, so is it done by trial and error, or are you making copies of someone else’s design?ChewFree MemberI was wondering this myself, is it just Alpkit or Wildcat? Nobody else makes anything similar?
Apidura, Revelate, bikepack.pl are similar designs and price points.
Plenty of people do make there own, but its generally from scratch and having to make it up as you go along.
Depends if you have the skills/patience/spare fabric as otherwise it could just be as easy/expensive to buy one
steezysixFree MemberI’ve got one of the Apidura seat packs, a little bit more than the Alpkit & Wildcat ones but very nicely put together and works really well.
https://www.apidura.com/product/saddle-pack-compact/%5B/url%5D
I emailed Tori (the owner) and she was really quick at getting back to me about stock levels, etc.
The topic ‘Sick as a dog so, show me you Bivi / Bikepacking / Adventure racing gear…..’ is closed to new replies.
