New here hello :)
This thread is what got me to sign on to STW, it has been a very good read with some excellent links and information, i like the leaning to extreme lightweight kit £££ and Lidl specials, keep up the good work.
As valleydaddy pointed out the Lidl special i sort of went into one today for a look, and bought it, for £12.99 you cant go wrong and wont cry if you burn it down.
Some random weights, i bought Mrs ace a Terra Nova laser several years ago, thats 1270grams bagged up, excellent tent.
I also have a british army poncho that i have spent many nights under, that weighs 952grams.
The valleydaddy special :)
Well you get what you pay for, the poles are nasty but usable, overall tent construction seems very good, and it had a dual door of windproof or open with midge net. Hydrostatic head is 2000mm, floor size is 120cm X 190cm and it sits at 90cm highest point by door and comes with a 3 year warranty ! it has some internal pockets in the tent. Overall cant moan at £12.99 if it only lasts several trips its a good base to start from.
Rocktrail Hiking tent by Milomex Ltd (no web address anywhere on packets or manual)
Overall Bagged weight 1600g
Unbagged weight 1512g
Guy Ropes, Flo green x4 29g
Pegs steel 20g each. 11 supplied 217g (factor in a +/- variance on weights to uncalibrated scales and i didnt weigh each peg to check)
Tent, single skin 777g
Poles, fibre glass shock corded, front is 2 pole A-frame with a 3rd running the spine. A-frame 207g Spine pole 274g both 481g.
I reckon with a play around you might be able to ditch the poles and use extra guy lines to hang the tent, also swapping out steel pegs to alloy or Ti or carbon as well could drop the weight down to around 1kg.
Its cheap and ripe for a starter to play with and could be bought down a fair bit in weight, quite a good impulse buy. Just have to put it up and have a look.
