Home Forums Bike Forum Shimano Road disk pads
  • This topic has 4 replies, 4 voices, and was last updated 3 years ago by DezB.
Viewing 5 posts - 1 through 5 (of 5 total)
  • Shimano Road disk pads
  • woody2000
    Need to replace the pads in my tiagra (4770) brakes bit getting a bit confused. Are all shimano road pads the same? Anyone got any recommendations?
    igm
    No. Not all the same. Shimano’s website will help you with the pad type numbers for ones that will fit. Well Shimano ones anyway.
    Mister-P
    https://si.shimano.com/pdfs/ev/EV-BR-4770-4610.pdf
    These are the part numbers for the genuine Shimano ones to fit those callipers. I run Y8PU98040 finned resin in my GRX callipers, they use the same pads as your Tiagra.
    joebristol
    If you can get sintered pads rather resin I would. My road brakes started with sintered and I accidentally replaced them with resin and I’ve been a bit unimpressed.
    I just replaced my front brake with EBC organic (green).. and now…. It. Doesn’t. HONK. In. The. Wet!
The topic ‘Shimano Road disk pads’ is closed to new replies.
