Home Forums Bike Forum Shimano alfine 8 speed shifter to Derailluer?
Viewing 11 posts - 1 through 11 (of 11 total)
  • Shimano alfine 8 speed shifter to Derailluer?
  • cbike
    Would an indexed shifter for an 8 speed alfine hub work with an 8 speed Cassette?
    tomhoward
    I’m pretty sure it won’t, due to cable pull reasons. Happy to be told I’m wrong though.
    johnners
    No, like Tom says, different pull. Shame as I’d like to be able to do it the other way. I’ve an old XT 8 speed shifter that’s way less ugly and clunky than the Alfine.
    cynic-al
    No way.
    I’ve used friction on hub gears though!
    cbike
    Thanks.  The bar endplug equivalent must exist though for triathlon bikes.
    thepodge
    Alfine is rapid rise so most shifters wouldn’t work even if the cable pull was correct
    Jtek do a bar end alfine shifter
    tjagain
    You can use a twist shift from an nexus for the 8sp – works fine and much neater / easier to use
    ghostlymachine
    Um. No. That’s not how rapid rise works. Any shifter with the correct cable pull/no of ratios will work.
    Yeah. That’ll knacker it.
    thepodge
    The alfine 8 pulls cable for higher gears so maybe technically not rapid rise but standard shifters are backwards.
    amedias
    And only the old alfines are reverse shifting, the current series of 8speed hubs go the normal way (like the 11speed ones)
    but as for the OP the answer is as above, no, cable pull is all wrong annoyingly.
    ghostlymachine
    Which is exactly what rapid rise does. There’s no such thing as a rapid rise shifter.
    So it’d work fine. Except for the bloody cable pull…….
The topic ‘Shimano alfine 8 speed shifter to Derailluer?’ is closed to new replies.
