Home Forums Chat Forum Safe Cracking
Viewing 40 posts - 81 through 120 (of 177 total)
  • Safe Cracking
  • bruneep
    okay, how about a case of beer then?
    That would mibbe help.
    We’d have a go, our watch had to get into a safe that the cops took along to the station they they recovered. took a while but we got in, it wasn’t pretty afterwards, depends if we can get the spreaders in.
    …and there was nothing in the safe that the cops took along
    nicko74
    Are you in yet?
    Wow, I had a sudden flashback to Friday night…
    esselgruntfuttock
    Ask George…
    http://en.wikipedia.org/wiki/George_Reynolds_(business)
    He did some safebreaking for the likes of Charlie Kray & other well know bad lads in the 60’s. He now lives in Durham & I bet he’d know how to get into it!
    spchantler
    don’t open it, get it on ebay as it is, i bet it’ll go for a fortune! the world is full of greedy people….
    matt_outandabout
    Richie_B
    Between the inner and outer, shells of a safe the vois is usually filled with insulation, steel and cast iron bars and anything else thy have handy to stop drilling and penetration by an angle grinder
    Looking at the age of the safe did they have portable angle grinders back when it was made… ????
    Your right but its worth bearing in mind that they did have asbestos
    franksinatra
    what would happen if you put it in one of those car crushers that you get in scrapyards (like the one in Superman)
    rusty90
    As far as I can tell from the films, the method’s quite simple.
    You will need :
    An ageing ex-con with a heart of gold
    A bespectacled geek who can hack into any computer system simply by typing ‘Access Override’
    A large tough-looking black guy who’s actually very gentle and abhors violence
    A glamorous girl in a tight fitting black cat suit
    The girl then dangles from the ceiling on a rope with a complicated looking drill whilst the ex-con tells her that there’s only 5 minutes left but she can do it if she stays calm.
    Note that this may only work if the safe is owned by an evil baddie who framed the ex-con in the first place and left the only evidence that can prove his innocence in the safe.
    Hope this helps.
    thisisnotaspoon
    +1 for drilling in the right place, we had a locksmith break into one once. His charge was something complicated, basicly a high hourly rate, but if the safe turned out to have less than his charge he’d take that instead. Spose it worked onthe basis an expensive hard to get into safe takes longer but usualy has somethign worth while in it. So unless he horibly underquoted the job he got his money and the client got some peace of mind they wouldnt be out of pocket.
    He just drilled in the right place (just above the lock) and something clicked open inside. Apparently if that had failed it was down to brute force.
    thegreatape
    I’ve WD-40’d the lock to no effect
    Conclusion = insufficient WD40
    fasthaggis
    Make sure you do it from a safe place 🙂
    haydenw
    How sure are you its not the safe from the ‘lovely bones’?
    maxtorque
    This ought to do it:
    Try Ebay for a s/h one, it’ll be cheaper.
    And if it doesn’t open the safe, then you probably don’t need to worry because the all out nuclear holocaust that follows your detonation of the device will probably render the contents of the safe un-important……. 😉
    (pretty sure that should be enough “key words” to interest Echelon btw)
    d45yth
    Check if the back of it is as solid as the rest…a lot of safes were built into walls meaning the door was the most solid, the rest not so much. Some dodgy characters I used to know referred to them as ‘peely backs’ and would crack the back open with an axe (not sure what kind of axe?!?)!
    project
    You will need :
    Average ST forumites then.
    maxtorque
    Other than the glamourous girl…………… 😉
    meesterbond
    Ok, so tried some more WD40 (didn’t have time to get penetrating stuff, nor the confidence to order it without smirking)… Nothing.
    So gave the mole grips a go…
    piedidiformaggio
    Oh FFS!!!!
    So what happened?
    righog
    Is he locked inside now ?
    matt_outandabout
    So gave the molgrip a go
    How did he help?
    meesterbond
    They didn’t work.
    So I tried with both molegrips and wiggling the key… and that did work.
    suffolk
    No glow emanating from within = sad panda
    matt_outandabout
    *is on seat edge*
    Cougar
    The suspenders are killing me.
    Is it empty? Is it?
    haakon_haakonsson
    TELL US WHAT’S IN THE SAFE!
    godzilla
    Narnia? if so keep away from Tumnus, the fella cant be trusted.
    mattzzzzzz
    Arrrggghhhhh come on we’re all waiting- there’s more people watching this thread with baited breath even fergie and mourinho are watching it
    kingkongsfinger
    *hand in the air waving furiously*
    I mentioned to use the molgrips, it was me who opened it by proxy!!!
    WHATS INSIDE !!!!!!!!!!!!!!!
    bradley
    OK OK CMON JUST OPEN IT AND TELL US DAMN IT!
    legolam
    I can’t believe I’m wasting my evening watching a thread on a bike forum about a man opening a safe. I love STW.
    mattzzzzzz
    Fergie “The OP is making us wait”
    Mourinho ” this OP is playing zee mind games yes”
    meesterbond
    Well… it wasn’t empty.
    But there wasn’t any gold…. something better.
    Actually not better at all. But more intriguing. Slightly.
    soma_rich
    oooh what’s in the bag? awesome thread!
    bradley
    You are an evil man!
    Cougar
    Why would you put a bag of awesome thread in a safe? Someone really takes their embroidery seriously.
    Mr_Mojo
    A TSB Bank bag?
    racefaceec90
    you’re ronnie biggs 😯
    Cougar
    More like Derek Smalls.
    project
    The door is open, he looked inside and was mesmerised by the bright light drawing him in like a myriad of stars glistening like pieces of quicksilver cast ceaselesley on the black velevet looking interior.
    His mind raced at the thought of expensive jewels or Campag or shimano bike parts.
    He tried to close the door,but was being drawn more and more into the ebony void of infinite space, then sudenly without warning a voice was heard behid him, shouting,
    “YOUR DINNERS ON THE TABLE, LEAVE THAT BLOODY SAFE ALONE”.
    Cougar
    (sorry, I appear to have wandered into the Wise Cracking thread by mistake)
The topic ‘Safe Cracking’ is closed to new replies.
