Home Forums Bike Forum Reba – Red rebound adjustor on right lower leg will not come off, any ideas?
Viewing 7 posts - 1 through 7 (of 7 total)
  • Reba – Red rebound adjustor on right lower leg will not come off, any ideas?
  • neiloxford
    I can turn it a couple of times, thats it 🙁
    RustyMac
    spray a little WD40 over it and give it a wiggle. It is only held in place by a ciirclip in a small grove.
    Lots just fall out on jumps so it will come off.
    wolly
    Pliers and a rag 🙂
    takisawa2
    It’s not meant to unscrew…
    Just pull it.
    PeterPoddy
    It just pulls out. Pliers help if its stuck.
    neiloxford
    I cant get past this:
    I have tried putting my feet over the end of the fork and pulling with pliers without success !
    I have also tried separating the red knob away with a chisel, again without success !
    haggis1978
    you’re not supposed to see threads there as those allen head bolts hold your forks together. screw it back in and skoosh with plenty of WD40/GT85 then pull only
The topic ‘Reba – Red rebound adjustor on right lower leg will not come off, any ideas?’ is closed to new replies.
