Downhilldave you win the friendly poster award, thanks for your helpful advice. The system should indeed be closed but that doesn’t mean it is impervious to breach. It would be unusual but then so are the symptoms – usually tapping the hose while working the lever will bring any air bubbles up to the reservoir, if there has been fluid loss it can then be topped up. If water had *somehow* got into the system it would sit below the oil, being denser, and so flushing from the bottom might not remove it all, hence speculation that bleeding top down might be more effective. Water, while not as compressible as air, is not incompressible. I hope I haven’t damaged your self confidence too badly – keep trolling, practise makes perfect xx
