Home Forums Chat Forum Portable pressure washer spray gun
Viewing 15 posts - 1 through 15 (of 15 total)
  • Portable pressure washer spray gun
  • Divid
    Hi
    Have broken the spray gun connector for my Mobi pressue washer. Chainreaction no longer stock and the equivalent from aqua2go is 3 euro plus 13 euros postage.
    https://www.aqua2go.eu/en/accessoires-uk.html
    Has anyone got any advice as loathed to get another gun and a normal garden one is the wrong size connection.
    Thanks
    toofarwest
    Currently using a normal garden one (cheapie from B&Q) just swap the connections over, they unscrew easily. The jet isn’t as concentrated as the standard Mobi one though but good enough for me.
    notmyrealname
    The Mobi 17 litre is the same as the Sealey PW1712 and parts for those seem to be readily available if that’s any use?
    Divid
    Toofarwest
    It is the connector at the end of the gun that I have broken.
    Are you saying that you change the fitting on the end of the hose as that connection is smaller than the standard male fitting on the end of the garden spray gun that connects to standard size hosepipe.
    Thanks
    toofarwest
    Divid – Member
    Toofarwest
    Ahh, I should have read your post a little better. My gun stopped working so I thought yours had done the same, new gun with the old connector is what I did but I see yours is broken.
    meatychi
    Hi David,
    I have recently broken the same part that you have. I to am loafed to pay that amount for shipping so I am working on 3dprinting one. If you can hold fire then I may have a solution to your problem.
    therag
    Also broke mine. The part that screws into the gun, so keeping an eye on this.
    carlos
    Can’t you just use a standard hoselok reducer fitting, think it’s 12mm to micorbore then a standard garden hose will fit?
    oscillatewildly
    The aqua 2 go one will work i emailed thwm with the same problem
    You will need there hose connector too so i was told so youd need the gun and the hose connector
    It comes in at about 23 quid posted from netherlands
    meatychi
    Nearly there just got a few more modifications
    meatychi
    Oops img link didnt work
    Divid
    Hi Meatychi
    Impressed with your printed solution.
    Have you trialled the fitting and if it works could I purchase one off you?
    Thanks
    meatychi
    Hi Divid,
    Sorry I’ve been a tad busy with other things however I have had chance to test a number of iterations and the results aren’t quite there yet. When the adapter is under pressure there are a few leaks which appear to be coming through the layers. Its going to need more time before a finished product can be produced.
    meatychi
    Woohoo – finally got it water tight with the help of a little PTFE tape
    razorjack
    my connector broke too….
    did you try to use parts from other manufactures? are they compatible ?
    like this one
    https://www.waterirrigation.co.uk/elgo-3-4-threaded-tap-connector.html
    or this one
    http://www.diy.com/departments/verve-3-in-1-tap-connector/1578102_BQ.prd
The topic ‘Portable pressure washer spray gun’ is closed to new replies.
