Home › Forums › Chat Forum › Not putting the heating on – how’s it going…?
- This topic has 2,011 replies, 324 voices, and was last updated 2 days ago by thisisnotaspoon.
FlaperonFull Member
As a professional cable muncher, it galls me every time I see a ‘central heating wiring centre’ (box of spaghetti with a strip of choc blocks)
I’ve lived in three houses with S-plan systems. All have been wired in this style of zero care. Pretty sure the plumber has been told which colour goes where without any actual understanding of how the system actually works.
All three occasions I’ve ripped it out and re-done it with a semblance of neatness and order. Choc blocks are the work of the devil and should have been banned years ago.
You can get 20-way boxes that make the whole thing a lot easier to both install and understand, including some that take Wago connectors.
I would never trust a plumber to do anything electrical. It makes a mockery of the fact that they get signed off for gas boilers and unvented systems but don’t actually understand how it’s controlled.
mattyfezFull MemberIt’s a strange position to take, a bit of learning and understanding of something goes a long way.
Before the big price hikes I dind’t pay much mind to my boiler.. I just set the temp on the stat, with two on/off periods a day and that was that.But after a bit of learning I’ve fine tuned my flow temp, TRV’s and HW temp and I’m undoubtably burning less gas with no ‘quality of life’ sacrifices.
Yes my bills are higher but thats because prices are outstripping pretty much any efficiency gains the end user makes – but i’m certainly paying less then I would be if I just stuck my head in the sand.
Currently im running a set back temp of 15c, but will boost it to 19c for an hour or two, but it becomes too warm and stuffy after a while.
I’ve no idea how folk can run at 21c or 22c…Computers are an interesting analogy to boilers – they both have an air of myserious wizzardry about them to the layman, but a bit of learning and knowledge, and the misty veil clears and things are often less complex than they first seem when you have no understanding of a particular system or piece of hardware.
You could even use cars as an anology… the amount of people who don’t know how to do an oil change, or even check the oil properly, or fit a spare tyre is pretty shocking.
paladinFull MemberWas doing pretty well in reducing has consumption by installing some tado kit, and have been experimenting with different schedules and temps. Was down to 60kWh/day average in December which is half of last years.
Had boiler running happily at 50 flow temp, so making some savings there too.
17 year old boiler has found the ultimate energy saving solution tho and has died, so consumption is now 0kWhtrail_ratFree MemberEPC calculation reckoned my house as i received it in 2012 should be using £2700 of oil…… – baring in mind that the oil price has significantly risen in that time.
we have over time insulated and improved our way down to >£1000 this year……
id like to see that down to £500 by ditching the oil hot water.
IFTTT didnt work yesterday so my house stayed on away mode all night unknown to me…… but no one noticed even though it was -1 outside. The insulation upstairs is working.
Solar is on the up and up./ its the 10th of jan and we already produced more than december full month. – solar really is incredible for 10 months of the year…..
matt_outandaboutFree MemberA question, and I think this is the right thread, which I am struggling to explain.
Regarding energy prices and them being dictated by a global market:
– how come petrol and diesel, also bought on a global market ahead of time, has such a variation from country to country even after tax is removed? The prices also seem to be less volatile in the current situation.
– can a country, region or even individual town or village create a smaller market, an energy cost independence if you will? It seems that this ought to be a goal of more and more places?
chakapingFull Member– can a country, region or even individual town or village create a smaller market, an energy cost independence if you will? It seems that this ought to be a goal of more and more places?
I believe France wanted to cap energy price rises with legislation this as the current crisis took hold, but swiftly learned that they couldn’t dodge global market forces. So they ended up subsidising a price cap.
Socialised energy is a different matter, either on a local or national level it should be possible – and even desirable – but I suspect the build cost for nuke stations, wind farms etc. are subsidised by promising the firms involved a slice of future profits.
singletrackmindFull MemberSome woman im Wales orgamised a village funded turbine iirc.
She was pn the new years honors listmolgripsFree MemberI haven’t posted on the thread in a while. My heating’s working really well with a higher flow rate and a lower temp still.
Could be many reasons – demand, also subsidies (I think diesel is subsidised in many places) and I think that if you have refineries with a particular product then that product is cheaper, they may get crude from different places and refine different amounts. I seem to remember reading that fuel is cheaper closer to refineries in the UK so that suggests distribution costs are a factor.
They have to buy their energy from somewhere unless it’s renewable.
sharkbaitFree Memberid like to see that down to £500 by ditching the oil hot water.
I’m not sure you’ll do that quite, but it depends on a couple of variables.
To take a 200L tank of water from 12c to 55c requires 10Kw energy – lets be generous and say you use 2L of oil to achieve that (it’s probably less as 1L of oil contains about 10Kw of energy) for 6 months of the year*.
(180 * 2) * 80p/L = £288It’s good but not £500.
* It’s doubtful that you’d be heating the full tank from 12c every day so the starting temp would probably be higher thus requiring less KwH/oil to heat it.
trail_ratFree MemberI’ve got a combi with an onboard 40l tank currently not an external tank
It (up till lst month ) fired 3mins every 90 mins all it’s life + hot water demand
My heating was off from April to October and I still got through a significant amount of oil due to the bairns baths
Replacing the hot water side with a 250l tank and solar thermal + manual change over.
This lets me ditch the electric shower while retaining redundancy
tjagainFull MemberI’m sick of feeling cold. Thats how its going for me! I’m trying to be economical but I hate feeling cold!
simondbarnesFull MemberI’m sick of feeling cold. Thats how its going for me! I’m trying to be economical but I hate feeling cold!
Wear more clothes! I’ve had my heating on 4 times this winter, max of 1 hour each time.
sharkbaitFree MemberIt (up till lst month ) fired 3mins every 90 mins all it’s life + hot water demand
That sounds rediculous – 48 mins every day would probably heat a 250L tank (depending on your boiler size)!
mattcartlidgeFull MemberAnyone else had their latest bill from she’ll normally it’s 5th of the month, nothing so far when I log into my account
juliansFree MemberAnyone else had their latest bill from she’ll normally it’s 5th of the month, nothing so far when I log into my account
Not had the bill from shell yet,but do know that it will be about £750 ,ouch.
trail_ratFree MemberThat sounds rediculous – 48 mins every day would probably heat a 250L tank (depending on your boiler size)!
Quite probably . But I don’t have a 250l tank to heat so it’s academic.
singletrackmindFull MemberIs a 5kw battery enough for. Pv set up?
I drain an everage of 200w an hr according to octopus. That’s not really trying to not use electricity.
Some floating around on ebay at affordable prices.trail_ratFree Member5kwh is more like a capacitor to allow you to fully utilise the solar generated.
You’ll not be charging at night and lasting all day on that if that’s your plan
But it’s a perfectly workable size if your intention is to be able to put the washing machine on without the sun nipping behind a cloud on a sunny day and you drawing from the grid.
fazziniFull MemberAnyone else had their latest bill from she’ll normally it’s 5th of the month
Nope. I messaged them and apparently “your account has a fault, we’ve asked our technical team to sort…”
Clearly not just my account with a fault.
dyna-tiFull MemberSister got me a SHO oversized sherpa fleece hoodie blanket thing at xmas, and ive not had it off since i got it. Really warm, fluffy lining and big fluffy lined through pocket on the front.
Teyre about £15 on Amazon. Well worth it.
trail_ratFree MemberAka . House coat.
Mrs t-r has one. Just about balances us out. Her in her house coat and me in my tee and shorts…..house at 17.
jamescoFull Memberand ive not had it off since i got it.
Ruined your sex life then ?
I’ll get mi coat !monkeycmonkeydoFree Member^tj earlier.We should start a freezing cold fashion discussion.
thisisnotaspoonFree MemberJust got Decembers bill, £190 for electric and gas.
I’m calling that a win for the efficiency savings on a 4-bed detached!
Thermostats on 17.5C 6am till 8pm as OH works from home.
New stuff this winter:
Rads all balanced
Boiler output temp set to ~63C so the HW cylinder can get to 55C, return is 50ish. This doesn’t seem to change with pump speed so I suspect it’s modulating to only ever have a ~12C dT.
HW comes on an hour before the heating and a couple of other hours during the day so that it’s not pumping cooler CH water through the hot cylinder and wasting energy.
Pump set to minimum speed.
Cavity walls insulated.
Loft hatch properly insulated.
Most of the TRV’s are set to 2 which seems to be ~16.5C and the doors closed, the rest are set to 3 (~17.5C) or 4 (the one on the non-window side of the living room so that one stays on longer in the evening than the one under the window blocked by curtains).Other stuff:
70’s brick built house, half arsed loft conversion where they’ve boarded it out and put more insulation and plasterboard on the ‘roof’ to make it a vaguely useable space. No idea how much actual insulation there is though. Ground floor is always cold underfoot as it’s hardwood flooring laid straight onto concrete.fazziniFull MemberNot had the bill from shell yet,
Just spoken to Shell via chat, and apparently I won’t be getting a bill until the beginning of February due to the tariff change on 1st January. I’m guessing this is the same for everyone with the same billing period. I know my mate is on the same billing cycle as I am.
@thisisnotaspoon – how many people living in that house if you don’t mind my asking? (Our HW comes straight via combi – no HW tanks for us.)FlaperonFull MemberIs a 5kw battery enough for. Pv set up?
I have a 5.2 kWh battery with solar. If you’re an energy skinflint you’ll need to draw from the grid in December / January.
Mine charges from the grid at off-peak hours and then supplies the house from 4.30am onwards. This covers breakfast, lots of lighting, heating (oil) for 2 hours in the morning and 4 hours in the evening, either the washing machine or tumble dryer, and a simple evening meal in a small oven. There’s also a boiling water tap which is on during the day.
Beyond those times the sun provides enough energy to top the battery up during the day regardless of what you do, and April – October the sun is bright enough that no overnight charging is needed.
So while I could get another 2.4 kWh it’s a bit pointless when it’s only needed 90 days a year at worst, and even then can only save 81p/day.
fazziniFull Member👏 @thisisnotaspoon love that, and I don’t feel so bad about our usage given there’s 4 of us
chewkwFree MemberMy December bill increased by another 25% as I used a bit more heating for that one week of cold snap.
Cooking with electric cooker is expensive but somehow this seems to be the favourite for rental property. I am thinking of getting my landlord to switch it to gas but I doubt he would entertain such idea for safety etc.
fazziniFull MemberCooking with electric cooker is expensive
This is eye-wateringly expensive. So much so, I’m even looking at sodding air-fryers now. 😭
zilog6128Full MemberThis is eye-wateringly expensive. So much so, I’m even looking at sodding air-fryers now.
got a Ninja multi jobby about 2 months ago, love it! Only used the oven about 5 times since, 3x big roasts and 2 pizzas. (The ninja actually does a bang-up job for a smaller, 2 man roast). Had an all-day brekkie in the caff earlier and was amused to notice the distinctive 2-tone “done” bing bong of a Ninja coming from the kitchen 😃
neilnevillFree MemberNot bad a bill from shell but they’ve done something when my meter readings as they allowed me to reduce my DD (it has been at the bottom of the allowed range). So they’ve done use calcs I guess.
molgripsFree MemberWe have a combo microwave, you can do oven stuff with part microwave part heat much faster than an oven and it stays just as crispy.
Or just cook things that don’t need the oven.
MrOvershootFull Membermolgrips
Only use the oven once a week now to cook a whole lot of stuff then freeze/fridge it so its either microding or stir-fry for the rest of the week. Have found that shutting myself in my little office with project work means I can leave the heating off all day and its still toasty in here. Going to my girlfriends place at the weekend saves a whole lot on heating but I do treat her by spending on quality ingredients and cooking for her in return 😀
I did laugh reading a forum post elsewhere about getting a bigger girl for the winter “get one with a higher tog rating” 😉 then someone suggested that should be “higher tug rating”!
fazziniFull Memberthen someone suggested that should be “higher tug rating”!
With a username of @MrOvershoot you may wish to be careful 🤔
MrOvershootFull Memberfazzini
Still counts as a happy ending right 😉
singletrackmindFull MemberAny reason why I couldn’t use a 13kw Mercedes car battery as a powerwall?
Then buy 6 x 230w panels, used from a solar farm.
Add in a 2kw inverter, i guess ypu want overcapacity for longevity, heat, safety etc. I can source this on ebay for close to £1k.
Obviously dont know how much use the battery will have had.
Where i live, south coast, its one of the most sunny places in the country.
I have a South facing garage roof, which is kind of tucked behind the neighbours so need to get a protractor and work out the elevation, but i think its full sun March to Oct.mattcartlidgeFull MemberMy shell bill has finally appeared, there goes half my credit balance!
molgripsFree MemberAre you saying December’s bill was more than Nov? When did the cold snap start?
