I do find the medium dives a bit more now with the longer travel so I figure if I can get the support from the firmer spring I can then back off the compression dial a bit which might help maintain the comfort. Fingers crossed eh?!
What travel change did you make?
If you’re a bit heavier than me then the firm spring might be spot on for you.
Come and report back if do you try it.
Rhid – would that be a question for Vorsprung?
I think part of my issue is that the fork is at 160mm on a bike which previously had a 180mm Zeb, so I’ve had to raise the bars but the geometry is still steeper than I’m used to (albeit about 64deg HA).
I’m going to put it on a more suitable bike before I make any rash decisions.
