Cadair Idris looks interesting – is the bridleway basically ridable on the way up or is it a huge push?
Depends which way you go and how good you are 😉
It can start off pretty easy but whichever way you go the last part is a push
I usually head down the bridleway from Aber then at the bottom instead of turning right towards Cadair head off in the 2 o’clock direction and gain the ridge in front and then join the Pony (?) path. It’s a lot longer but more rideable. Numerous descents from the summit mostly rideable providing you stay away from the Tal-y-lyn side although the descent across Mynydd Moel (sp) is good if your legs are up to it
It’s a day in the hills whichever way you go
