Home Forums Bike Forum Largest chainring on M8000 crankset?
Viewing 8 posts - 1 through 8 (of 8 total)
  • Largest chainring on M8000 crankset?
  • nickc
    Trying to use some spares for a commuter build. and have a M8000 (XT) chainset that I’ll probably use, what’s the largest chainring I can get on the cranks with a 96mm BCD?
    endomick
    Superstar do 36t or snail ones off ebay.
    Asym 96 bcd.
    guandax
    sillyoldman
    Sounds impressive:-
    “Ergonomic shape utilizes the stampede acting efficiently to create more stampede traction”
    That’s the biggest 1x option I’ve seen for those cranks though.
    reggiegasket
    Superstar do 40t ovals
    montgomery
    Chainstay clearance?
    branes
    I’ve had an Aliexpress 38T on no probs, but as mentioned above chainstay clearance is likely to be the limiting factor.
    nickc
    @montgomery thanks for the heads-up, I’ll check that. Should be ok, frame’s a commuter based Cannonale thingy
The topic ‘Largest chainring on M8000 crankset?’ is closed to new replies.
