Home › Forums › Bike Forum › Ibis warranty dispute – chainstay damage to Ripmo V2
- This topic has 53 replies, 29 voices, and was last updated 3 years ago by greeny30.
coolbeanzFree Member
I’m looking for some advice. Within the first month of owning my brand new Ibis Ripmo V2, I noticed that the metal chainstay protector had come off during one of my rides. This left the chainstay exposed to chain slap, which caused some pretty severe chipping of the paintwork, and even gauged the carbon beneath it (photo below).
My bike shop made a warranty claim with Ibis on my behalf. However, Ibis responded that the best they can do is to send me a replacement metal plate to glue back on.
Obviously, I’m not happy with this response as this is clearly a manufacturing/design fault on the part of Ibis – the protector failed to do its job within just a handful of rides. You will also notice that the drive-side chainstay swoops down, thus sitting closer to the chain than on most frame designs – this is because Ibis wanted to keep the chainstays as short as possible (otherwise they would interfere with the chainring). Knowing this, they should have probably thought about reinforcing this area better against chain slap.
Now, I know that this is predominantly just cosmetic damage, but I’m annoyed as it will hinder the re-sale value of the bike. I just expected better from a brand like Ibis.
Here’s a picture of the damage:
For reference, here’s an image of a Ripmo V2 that I found online with the metal plate attached:
andrewhFree MemberJust the remainder of that one ride without the plate?
I still think costmetic damage is pushing it a bit though, sorry.jamesoFull Memberclearly a manufacturing/design fault on the part of Ibis
Not necessarily. See it from the POV of a company who’s probably seen a few of them jet-washed off, doused in bike cleaner that’s killed the tape, etc.
It’s a manufacturing defect if the tape was duff and it fell off but that’s hard to prove either way. So while the damage isn’t a warranty-able fault the reason the metal plate came off could be up for discussion.
Outcome might depends on the stock they have and how it’s approached by you or the dealer – it may be down to goodwill rather than a clear warranty case.Knowing this, they should have probably thought about reinforcing this area better against chain slap.
Looks like they did as it has the metal plate and to be fair to them it’s a sensible way to do it. You could bolt it on but then some high chain pressure (a jam etc) might damage the carbon more easily. The way it’s fitted is a bit like a mech hanger, it’s a fail point / saver. Drawback is it needs spotting early before damage happens.
scotroutesFull MemberTBH that amount of chain slap on one ride suggests a poor choice of gears.
coolbeanzFree MemberJust the remainder of that one ride without the plate?
I still think costmetic damage is pushing it a bit though, sorry.I don’t know exactly when the plate came off, but I would say 1-2 rides max, as I would have noticed the plate missing while doing a regular wash (it’s been nothing but mud this summer). I live in the Alps and the trails here are rough, so this could easily happen within a single ride.
coolbeanzFree MemberTBH that amount of chain slap on one ride suggests a poor choice of gears.
Please do explain…
tthewFull MemberChain slap or chain suck that close to the chainring? I’d have thought slap occurs in the middle of the stay. Was it a new frame or full bike? Reason I’m asking is if it was an old drive chain that ‘sucked’ and knocked off the protector, then that’s user error IMHO.
coolbeanzFree MemberNot necessarily. See it from the POV of a company who’s probably seen a few of them jet-washed off, doused in bike cleaner that’s killed the tape, etc.
It’s a manufacturing defect if the tape was duff and it fell off but that’s hard to prove either way. So while the damage isn’t a warranty-able fault the reason the metal plate came off could be up for discussion.A quick online search suggests that this is a pretty common problem on Ibis bikes:
https://www.mtbr.com/threads/ripley-v4-glued-parts-falling-off.1147837/
coolbeanzFree MemberChain slap or chain suck that close to the chainring? I’d have thought slap occurs in the middle of the stay. Was it a new frame or full bike? Reason I’m asking is if it was an old drive chain that ‘sucked’ and knocked off the protector, then that’s user error IMHO.
Brand new everything.
DickBartonFull MemberI don’t have anything to offer in terms of whether it should be replaced or whatever, but I always get concerned when people talk about resale value of a bike – I don’t understand why people buy a bike with thoughts of how much they’ll get when it is sold on…I don’t tend to buy stuff and look to sell it on as it tends to wear out, so I’m sure I’m not thinking the way I should be for resale value. It strikes me as odd.
A mountain bike ridden hard is going to show signs of usage, so accept it, enjoy the ride and don’t rely on a massive amount as a resale amount if you do decide to sell it on.
Can you wrap that bit in inner tube? It will provide a bit of protection and could also dull the noice a bit.
I’m assuming you are running a clutch mech? If so, is the clutch on? I’d have guessed a clutch mech would reduce that amount of skelping – however, looking ta the picture, the stay does dip quite a lot so could be right at the point where the chain does ‘flick’ so strikes may be very common there.
dc1988Full MemberI can see your frustration but from the POV of Ibis, I can’t see that offering a whole new chainstay is reasonable for some scratched/chipped paint. The protector was a glued/taped on part rather than an integral part of the frame so comes under wear and tear I would suspect. Yes it failed early but perhaps it took a bit impact without you realising.
devashFree MemberA quick online search suggests that this is a pretty common problem on Ibis bikes:
Regarding the above link, I think the OP’s got a pretty good reason to be peeved off if this is a known problem and Ibis hasn’t put out a general fix / notification to customers to keep an eye out for this issue.
Yes, we should all be checking our bikes over after each and every ride, but little things like this can and do get missed.
I wonder sometimes what you really get for your money with these ultra-premium, expensive brands. The glue-on chainstay protector on my lowly Giant has lasted 4 years, 3,000 miles and multiple washes and still hasn’t budged an inch. That bike cost at most a third of what the OP probably paid for his Ibis so I’d be rightly narked off.
muggomagicFull MemberTBH even if they had offered to send you a new rear triangle (which as annoying as it is, IMO seems a bit much for some paint chips) you could be waiting months for it right now anyway.
Maybe you could ask them to send you some touch up paint as well as the new protector.DaffyFull MemberFWIW – Ibis have had the same or similar metal protector on their bikes since the original Mojos and the DW Link design with the dropped DS chainstay is also common.
To get that amount of chain rub/slap, you must’ve been toward the bottom of the cassette for a decent period of time…perhaps a bit more b-screw tension would’ve helped?
coolbeanzFree MemberI don’t have anything to offer in terms of whether it should be replaced or whatever, but I always get concerned when people talk about resale value of a bike – I don’t understand why people buy a bike with thoughts of how much they’ll get when it is sold on…I don’t tend to buy stuff and look to sell it on as it tends to wear out, so I’m sure I’m not thinking the way I should be for resale value. It strikes me as odd.
Each to their own on this one. With bikes getting crazy expensive these days, I just like to reclaim some of their value and upgrade every 2-3 years. Exactly the same as most people do with cars. I think it’s best to save this discussion for another thread though.
It’s a good tip and exactly what I have done:
Yup, I always keep my clutch on while riding.
enigmasFree MemberI think I’d be happy with a new plate and some form of written confirmation that if there’s a future issue in that area the damage would not go against a warranty claim.
I wouldn’t expect a new rear triangle – I think it’s fair for Ibis to assume that you regularly check the bike over for defects like this before it does that sort of damage.
honourablegeorgeFull Memberscotroutes
Yes, a slightly different gear would have changed the angle of the chain by several degrees, it could have been millimetres further from the chainstay
LOL
AlexFull MemberI’ve had a few Ibis’s. Never suffered that problem but sticky things not sticking has definitely been an issue. Luckily with no consequences.
My V1 RipMo is 3 years old and after a year I noticed the (cosmetic) damage behind that plate under the DS chain stay. Ended up putting two layers of clear tape on there, and replacing when necessary.
I’ve not warrantied any of my Ibis’s, but I have spoken/emailed them quite a lot and they’ve been fantastic (even sending me out need badge screws after mine fell out).
tthewFull MemberAh, now I see the full photo, I can well imagine the slap. I’m not cosmetically precious about my bikes, but I’d be annoyed by that on a boutique steed.
coolbeanzFree MemberI think I’d be happy with a new plate and some form of written confirmation that if there’s a future issue in that area the damage would not go against a warranty claim.
That is a good tip actually – thanks.
Again, this damage could easily have happened during the course of a single day out in the Alps. I frequently do uplift days, where I descend 5,000m+ in very rough terrain. This category of bike should be more than capable of taking this kind of riding. After all, the exact same frame is being raced in the EWS.
coolbeanzFree MemberI’ve had a few Ibis’s. Never suffered that problem but sticky things not sticking has definitely been an issue. Luckily with no consequences.
Thanks for sharing your experience. To be honest, I think that most bike brands are flooded with work due to the ongoing covid biking boom. I suspect my interaction with Ibis would have probably gone a little better under ‘normal’ circumstances.
coolbeanzFree MemberUse a better adhesive than Ibis did.
I’ll pass that message onto Ibis 😉
NorthwindFull MemberDaffy
Yup, and they’ve been falling off for most of that time too. The official fix used to be “araldite it back on and it’ll stay on”, which seemed to actually be true, which raises the question what the hell are they doing in the factory.
But that’s a hell of a lot of chain slap damage for one ride. Not casting aspersions on the OP or anything but I suspect their warranty dude’s looked at that and gone “one ride, my arse”.
coolbeanzFree MemberAh, now I see the full photo, I can well imagine the slap. I’m not cosmetically precious about my bikes, but I’d be annoyed by that on a boutique steed.
Well, that’s exactly it, I’d just expect better quality/attention to detail from the likes of Ibis.
coolbeanzFree MemberBut that’s a hell of a lot of chain slap damage for one ride. Not casting aspersions on the OP or anything but I suspect their warranty dude’s looked at that and gone “one ride, my arse”.
Fair point. I imported the bike from the UK, since it’s impossible to get your hands on these in Switzerland until next year. The Ibis rep probably thinks that I ride it in the South Downs though (where the shop is located).
FrankersFree MemberWhenever I buy a new bike I always add helicopter tape to the wear points on the frame, and a rubber/fabric chain stay protector that covers the lower chain stay. I wouldn’t trust one of those small aluminium stickers to offer adequate protection. I also like to keep my bikes looking decent so as to keep a decent 2nd hand value as I don’t keep my bikes forever.
DickBartonFull MemberLooking at the picture of the stay and chain in the lowest gear, you can see how close the stay is so I’m reckoning that is entirely possible in 1 or 2 rides of some real rough bumpy stuff. I hadn’t realised it was quite that close, but hopefully the inner tube is going to do a decent job.
NobeerinthefridgeFree MemberNot ideal, I can see how I’d be pissed off if I was you, but see their point too, it’s not worthy of a new rear tri tbh.
I wonder if you could offer to get it repaired at a repairer, and see if they’d help out with costs?. Wouldn’t really take much to make that good, my mate is a spray painter in aviation and does a bit of work with a local carbon frame repairer, you’d never tell the difference once he’s done.
TheGhostFree MemberWhile you are protecting your chainstay I reccomend protecting the rear linkage as well.
I’ve followed what some Ibis owners reccomend and cut a neat flap of tape to divert small rocks from being chewed up in the linkage on my Ripmo AF.
matt_outandaboutFull MemberI would be frustrated by that.
Having said that, I can also see why Ibis don’t think it is new chainstay.
If I were you I would glue it back on, keep the tyre wrap going and in a couple of years time if you sell, it think it will be just part of the patina of a used bike.
FWIW, we just had a new Rocky Mountain fully wrapped and added chainstay inner tube before riding it…. I get protecting value, but it cost my son over £150 to get it sorted, and I am not sure if it will add that at resale.
coolbeanzFree MemberWhile you are protecting your chainstay I reccomend protecting the rear linkage as well.
Thanks for the tip, but my V2 actually came with the Rock Flap pre-installed from Ibis. Saying that, let’s see how long it lasts. My mate has one and lost it after his first ride.
coolbeanzFree MemberFWIW, we just had a new Rocky Mountain fully wrapped and added chainstay inner tube before riding it…. I get protecting value, but it cost my son over £150 to get it sorted, and I am not sure if it will add that at resale.
I actually had the bike INVISIframed, but, ironically, the one area that it did not cover was this darn metal chainstay protector.
coolbeanzFree MemberI wonder if you could offer to get it repaired at a repairer, and see if they’d help out with costs?. Wouldn’t really take much to make that good, my mate is a spray painter in aviation and does a bit of work with a local carbon frame repairer, you’d never tell the difference once he’s done.
I mean, I’d be happy with that. Problem is, it would probably cost more do get that done in Switzerland than for Ibis to just send me a new rear triangle XD
LATFull Memberscotroutes
are you suggesting that he was in the granny when the big ring would have been better?
you have my sympathy op. things like this are irritating.
coolbeanzFree Memberyou have my sympathy op. things like this are irritating.
Thanks XD
kevin1911Full MemberIMO this is the problem with having to go via the bike shop for a warranty claim. You’re never quite sure how well they convey the story to the manufacturer. It might be worth a direct email to Ibis explaining your point of view. Perhaps with some better photos to show that the carbon is damaged and not just stripped of paint. And maybe with some evidence of the distance it’s covered – do you use anything like Strava or komoot for logging rides?
big_n_daftFree MemberI would reverse the direction of the inner tube wrapping personally
big_n_daftFree MemberIMO this is the problem with having to go via the bike shop for a warranty claim. You’re never quite sure how well they convey the story to the manufacturer.
With Kona both the shop and the manufacturer refused to inspect the frame. So the Kona warranty wss worthless to me. Friendly bike shop couldn’t be bothered.
magoos_mateFree MemberThe area where most of your paint damage os isn’t actually covered by the chainstay plate.
Its alot of damage for one ride regardless of where your riding id say though. In ibis’ defence its for chain suck, not slap. You need to weigh up frame protection on your own i guess.
Also, its handy enough to repair, ive got two ibis bikes atm and ive installed the chain suck plate on one of them. Clean it, rough it up, fill the chips, paint and then bond the plate on. Make sure its all degreased and your epoxy is nice and warm. It’ll never come off again.
Ibis warranty have been great with me in the past going above and beyond to help me out when they didn’t have to.
The topic ‘Ibis warranty dispute – chainstay damage to Ripmo V2’ is closed to new replies.
