Home Forums Bike Forum How to remove a burr from hub bearing seat
Viewing 6 posts - 1 through 6 (of 6 total)
  • How to remove a burr from hub bearing seat
  • gmtfd
    I’m working on changing the cartridge bearings in my rear hub. While tapping out one of the old bearings, the punch slipped and slightly damaged the bearing seat, creating a slightly raised area. I’m not sure how to go about trying to smooth this out. A file maybe? Or should I just not worry about it? Basically I’m worried it will make the new bearing go in crooked.
    donkeysled
    Silverline deburring tool
    endomick
    Sharp blade can remove raised dings in aluminium.
    bigyan
    The bore or the seat? If its the bore in an alloy hub I use a disposable snap off knife and shave off the protrusion
    lotto
    Round the lip of the bore for the bearing? If so, oversize drill bit.
    tjagain
    craft knife and / or a bit of sandpaper
The topic ‘How to remove a burr from hub bearing seat’ is closed to new replies.
