Hello, having some issues with my trusty tech 3 e4, they are probably 4 years old, little use, on 3rd set of pads and been faultless in that time, however todsy I swapped them to a new bike, internal routed, I’ve bleed the brakes lots of times and I get no bubbles, even back bled system. I do have alot of lever travel, the lever pulls in near the bar, if I then pump it a few times it firm’s up when held in, let go of lever then pull again and it’s near the bars again, the master cylinder makes a weird noise when this happens also, like a puff noise? Will a simple replacement of master cylinder piston solve this?
