Home Forums Bike Forum Hope Pro4 – swapping XD driver to Shimano
Viewing 19 posts - 1 through 19 (of 19 total)
  • Hope Pro4 – swapping XD driver to Shimano
  • twrch
    I’ve bought a set of wheels with Pro4 hubs and a SRAM XD driver. I’d like to fit a Shimano freehub – I’ve read that the end caps are slightly different for the SRAM version. Will the SRAM endcaps already on the hub work ok with the Shimano freehub?
    Thanks in advance!
    monkeyboyjc
    No – the endcaps are different lengths to support the bearings (which are in different positions on the two freehubs), but they are available separately.
    If you used the XD endcap will be too long and won’t fit the Shimano freehub.
    benpinnick
    Not enough info… The end cap for XD and old/hyperglide Shimano is the same on a Hope hub, however the new Microspline freehubs use a longer cap. So you need to decide what version of Shimano you want before you know the answer.
    escrs
    As above Microspline uses a longer end cap to XD and Hyperglide freehubs
    Also you may need the hub seal tool to seat the green freehub seal when fitting a new freehub
    If you can find the right size and depth socket you can use that instead but the proper tool is only £10
    https://www.chainreactioncycles.com/hope-pro-2-pro-4-seal-tool/rp-prod194333?gs=1&sku=sku770998&utm_source=google&utm_term=&utm_campaign=&utm_medium=base&gclid=CjwKCAjwkvWKBhB4EiwA-GHjFtp_GmV5PDVJM01TNqGfeP6PeZNo7PquOnDijuzAnoRFeAkl9-aVbhoC5o0QAvD_BwE&gclsrc=aw.ds
    twrch
    I’m using a hyperglide Shimano freehub body. So does that mean the cap currently on the wheel (which has a XD freehub body) will work? If so, that will stop me sinking more of my life savings into Hope endcaps…
    big_scot_nanny
    If you buy the free hub, does it not come with endcaps anyway? so you have to make sure you buy the right hub designation. (i.e. 142, boost, superboost etc)
    twrch
    Judging by all the pictures of the freehub body, no, not unless I’m buying a Microspline freehub. Although that does tell me I’ll probably be ok with what I’ve got.
    hannahjayy
    If you are switching from Shimano HG to Sram XD the endcaps are the same, no problem using your current endcap as long as you aren’t also changing hub spacing. They were different drive side endcaps on the Pro 2 EVO but Pro 4 is all the same unless it is Microspline.
    twrch
    @hannahjayy – many thanks.
    teethgrinder
    If you happen to want to swap your XD for my HG Pro4 let me know. Or if you want to sell it cheap.
    twonks
    To backup what hannahjayy says, I’ve swapped Pro4 freehubs between Shimano HG and Sram XD a few times on the same wheel over different bikes.
    Always used the same end cap and never had any problems.
    twrch
    An update, for future readers – if swapping from XD to Shimano HG, you will need the 1mm barrel spacer. If you happen to have an old Pro2 hub lying around, that won’t help, as they have a 2mm barrel spacer…
    cheekyget
    I had a similar problem last week in the end I just took the bike to the lbs as I needed spacers for both wheels.
    Imo hope don’t make it easy to know what you need
    twonks
    @twrch Is this 1mm barrel spacer you refer to the cassette spacer that fits on the hub before the cassette?
    I’m struggling to visualise what you mean as I have 2 sets of pro 4 wheels and have moved from XD to HG a few times and always used the same end caps. Never had a problem although I accept I might be missing a trick!
    twrch
    No – according to Hope’s hub diagrams, there’s a 1mm spacer that goes on over the axle and before you fit the freehub body. It ends up sitting between the axle bearing and the freehub bearing. I took my other Pro4 rear hub apart, and it’s definitely there.
    nixie
    Sounds like your both taking about the same spacer using different language to me. That spacer is needed for all freehub iirc.
    hannahjay
    The same 1mm internal spacer is used for XD and HG freehubs, it sometimes gets stuck to the grease on the freehub bearing when it’s removed so people don’t realise it’s there but it is always needed. Stops the hub and freehub bearings binding, if you didn’t have it in you’d know about it pretty quickly.
    twonks
    Ah yes, I was thinking along a different track with ‘barrel spacer’ instead of washer.
    I did put one back on the bike without it. Luckily I saw it binding as I tightened the through axle.
    At least I think that was it, must have fished it out the other freehub in auto pilot as I don’t actually remember fixing the problem.
    scuttler
The topic ‘Hope Pro4 – swapping XD driver to Shimano’ is closed to new replies.
